Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Moter cuts out after a few minutes - Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
  • Dyson Master
  • 378 Answers
The motors have a "trip" to protect them, and you if a serious problem caused a fire, which can be tripped if the filters are blocked and causing the motor to overheat.
The filter at the top of the cyclone (the bit on top of the dust container) should be cleaned regularly (more often than Dyson suggest), and under the dust container you may not have noticed there is another filter - called the post motor filter. This isn't mentioned in the user book but does get clogged after a few years of use. It can be removed and can be replaced - eBay has companies that can help.
If all filters are clean and okay, it is probably the early stages of complete motor failure. If you're good at DIY, the site www.dysonmedic.com has some good info on how to change a motor. Again, eBay will help find a motor.
If you dont fancy having a go, either ring Dyson or a local vacuum repair company.
Posted on Sep 07, 2009
Dyson Vacuum cleaner cuts out after a few minutes use
sounds like you have a blockage in one of the hoses and it's making your machine to over heat and cut out,check for blockages
Nov 06, 2012 | Vacuums
Why doe my hoover mach3 stop during operation? I have to wait until the moter cools down.Then i turn on the switch normal way.Then a few minutes latter it stops again.
Your Hoover is stopping because it is overheating. This is a sure sign that there is a blockage somewhere. Find the blockage and clear it, and that should solve the problem.
Mar 20, 2010 | Hoover U6630-900 WindTunnel Bagless...
My dyson turns on only when in the tilted
it sounds like the wires attached 2 the moter are lose need hex drive 2 take a part moters verry fidley stripped quiet a few moters were gone
Oct 20, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hoover 1900w keeps cutting out
opened it up little senser near the moter on a wire moved away from the motor dont cut out anymore
Sep 23, 2009 | Hoover Vacuums
Nutone central vac vx550
It's a known problem. I bought my vx550 last year in July and it stopped working this year in May. On for 5 minutes, shut down, can't run for a few hours, runs for another five minutes, etc. I called the Nutone customer service department and they exchanged the unit for a new one, cross shipped, via UPS. Mine was still under warranty though. It has to do with some defective thermostat or controller in the electronics of the vacuum.
Good luck
Sep 11, 2008 | Broan-NuTone VX475 Bagged Central System...
Dyson Quits
cut out switch on the motor needs replacing this overheats and cuts of the motor when the motor cools down it will start again you have to keep both filters and cyclone clean and free of dust or after replacement the same will happen again
Sep 04, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
MY CLEANER CUTS OFF
Check that the bag is not full, check that is not a broken contact in one of the wires.
Jul 13, 2008 | Hoover S3639 WindTunnel Bagged Canister...
CUTTING OFF
Ok What is probably causing the problem is an internal error inside the vacuum. What I recomend you to do is take it back where you bought it and tell them what ever is wrong with it.
PLEASE RATE MY ANSWER AS SOON AS POSSIBLE!
Hope it works! Tell me if you have any questions later on!
Jun 17, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
MY CLEANER CUTS OFF
My Hoover S3639 on/off switch stopped working. I don't hear the 'click' any more. I removed the top of the vacuum but can't determine how to replace the switch.
Aug 18, 2007 | Hoover S3639 WindTunnel Bagged Canister...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
133 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
