Reprogramming TV Stations
Help --- how do I reprogram my TV stations for Denver? I received a used Sony 13" KV 13TR28 TV. Currently it has the Chicago stations programmed.
And, I do not have the remote (it got lost by the co-executors).
My email address is kjwelsh131@msn.com. Any help you can provide will be appreciated.
  • KathleenJW Dec 09, 2007
    Thank you Bill ...... and yes, the co-executors were careless about a LOT of things --- this is a minor frustration compared to everything else.
    Thank you again for your help. I have been looking for a solution for several days now and you're the first person that provided a solution!
    From SNOWY Denver ......Kathleen
  • 934 Answers
Kathleen,
Don't you just hate that when the co-executors are so careless. :) (just kidding :)
You will need a remote but that's easy... Go here: http://www.miracleremote.com/ and get a miracle remote for a sony and they are as if you purchased the original remote. We have serveral here in the shop for various brands and they access all the functions of the original for a fraction of the cost...
Then just go into the menu and do an auto-program from setup.
Have a great day!
Bill
Posted on Dec 09, 2007
  • William Rayburn
    William Rayburn Dec 09, 2007
    No problem, glad I could help...
    From lately windy Long Beach Washington... :0
    Bill
How do I delete preset stations? I can add a new preset, but I have to go through all the presets to get to the station I want. I would like to delete a number of them.
The backup battery needs to be removed from the clock radio. Then, unplug the device from the wall and count to 15. Plug the radio back in and see if the presets have been purged. Unplug the radio again for safety, reinstall the backup battery, plug the radio back into the wall and begin reprogramming.
Now, if you really don't want to have to reprogram all your stations, I suggest you look at the company's website for a free download of the user manual which will give you step-by-step instructions on reprogramming the radio.
Feb 03, 2016 | Audio Players & Recorders
Hdtv or converter box
If the TV is already hdtv...no. Try reprogramming tv to find hd stations or if receiving signal from outdoor aerial make sure aerial is digital and facing right direction.
Nov 30, 2013 | Mitsubishi WS-65315 65" Rear Projection...
Turner only selects odd numbered radio stations
this is the frequency settings that programmed in your audio system, reprogramming will be done your problem, if it cant be programmable install a device on antenna output(frequency modulator changer) you will pick-up all station you want but the problem is... the digital cant be set to appropriate radio station
Jul 22, 2010 | Yamaha RX-V663 Receiver
I CAN HEAR WHAT IS SHOWING BUT CAN`T SEE IT.
Your vertical IC will need resoldered. And check near this IC for bad capacitors. And any and all grounds where there are heat sinks attached to other transistors and ICs. This should restore your TV. Find a hobbiest or TV tech to pull the board out for repair!
Apr 19, 2010 | Sony KV-13TR28 13" TV
Jvc av-20cm5 channel programming issue
you have a programing error in the main control ic it ca be repaired but its $$$$$$ my guess is 150.00 -200.00 the control ic has a modified control memory the memory is held in place by a charged capacator if you unplug it and leave it for a week and plug it back in it might be ok for a while if not try unplug it for a month . that might be enough for a reset but the problem will keep comeing back the chip is damaged
Apr 01, 2009 | JVC Televison & Video
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
Digital TV Stations
The term digital in this case is the mechanism used to tune in stations. Rather than making adjustments using a front dial to fine tune the stations, there are digital circuits that will lock in the station. The "digital" stations you are referring to now are the over-air digital broadcasts what use a different method for transfering the signals over the air. These stations now broadcast a digital stream of information rather than an analogue TV signal. If you are using an antenna for receiving these over-air broadcasts, you will require a converter.
Dan
Sep 18, 2008 | Disney 13" TV
TV problem
Bad solder connect inside tuner = un- solder tuner from
PC board and solder bad connect or replace tuner with new..
I.F. block next to tuner should be soldered,also.......T.
Dec 08, 2007 | Sony KV-13TR28 13" TV
Tv repair
First, you need to get the TV to work then worry about the remote. The TV will power on/off using the power button on the TV but thats it. You can try whats called a 'hard reset'. Unplug the TV from the wall and anything connected to it for 4 hours. Then plug everything back in. The manual is on the website: http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV20FS120
Jul 02, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
