Question about Brother MFC-5840CN All-In-One InkJet Printer
Unable to clean
It says "unable to clean" and I have followed all the muser guide instructions several times over but to no avail. Any other tips or do I have to scrap it?
  • ianripper Sep 07, 2009
    why pretend I get free advice when all I get is an ad to sign up for $9?
  • Brother Master
  • 379 Answers
This is very common on Brother MFCs - they self clean excessively and when they've done a set number of self-cleans, they refuse to print and give the error message you quote.
There is a work around - you can reset the self-clean counter - but this carries a small risk the waste ink from cleaning that is normally stored insde the machine in a tank/sponge MAY leak out. I've done the work around on my Brother MFC and, so far, no leakage so if I were you I'd take a punt.
Just Google "brother mfc unable to clean" and somewhere in the results will be how to reset the counter - it's all done from the keyboard so no tools required.
Posted on Sep 07, 2009
Why is my portable dvd player is reading no disc when disc is in?
Over time the laser pickup becomes weaker until it is unable to read a disc. Try a dvd cleaning kit and follow instructions, or get a Q-Tip and rubbing alcohol and gently clean the lens, allow several minutes to dry. If this fails cheaper to replace the player.
Apr 14, 2012 | Insignia NS-8PDVD
Hi How i can get a user guide (manual muser guide) on line for a Panasonic fax machine KX-FP153 ? Thank's Priore.
http://www.telec.com.ar/img/KX-FP153-158AG.pdf
http://www.panazip.ru/manuals/fax/KX-FP153RU_FP158RU.pdf (russian version)
no english found
Sep 19, 2011 | Panasonic Office Equipment & Supplies
I have serviced my IMCT several times per the owners manual. It needs to be serviced again however the manual has disappeared, and the one available on line does not contain the servicing instructions. ...
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Oct 21, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Unable to clean
1) Press the Menu and Mono Start keys. Next press the key four times to make the machine enter the maintenance mode. 2) Press the key several times to display 8 on the LCD and then press the Set key. Again press the key several times to display 0 and then press the Set key 3) Press the Mono Start key several times until the purge count appears on the LCD. 4) Reset the purge count to zero by using the and Set keys as follows: Press the key several times to display 2 on the LCD and then press the Set key. In the same way, enter 7, 8 and 3. 5) Exit from the maintenance mode by using the and Set keys as follows: Press the key several times to display 9 on the LCD and then press the Set key. Again press the key several times to display 9 and press the Set key.
Jul 27, 2010 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean
Take out the ink and clean on a soft cloth the printhead and then try again to clean. If this doesnt work post to me I will instruct you further what to do
Please rate me good
Jul 14, 2010 | Brother DCP 115C All-In-One InkJet Printer
Unable to clean see user's guide troubleshooting and routine maintaince chapter in users guide
Follow this instruction:
- Machine off
- Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
- press 80
- press the “mono start” button several times until you see “purge: xxxx”
- press “2783” in order to reset the purge counter. You will see: “purge:0000”
- press the "stop" button.
- press “99” to exit the maintenance mode.
Oct 01, 2009 | Brother MFC-5440CN All-In-One InkJet...
Will not reconize the disc
You have two options:
1.Get a cleaning disc if this is available to you.follow instructions that came with the disk.insert it like normal disk and let is play for a few seconds
2.press the eject button to open the disc compartment and look for the otical head(looks like a miniature eye). carefully roll a samm a piece of tissue to have a pointed tip and immerse the tip only in water. run the tip on the surface of the eye several times taking care not to lleave any particles on the eye. leave to dry and reinsert the disc. plaese reply if this works for you.
regards,
Luwangula
Sep 12, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Unable to Clean - What are the solutions?
plz search this forum for unable to cklean or error 46. ithas been described soooo many times.. :)
Apr 09, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
348 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
