Question about Optoma DS303 DLP Projector
I have an Optoma DS303 Projector and it won't turn on. The power button flashes when i hold it down.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 149 Answers
How old is the projector?? First, unplug the unit and check the lamp--A healthy lamp should have clear glass--not darkened, smoky, bulged, or blistered. Sometimes, by simply unplugging and then re-inserting the lamp, you cause the contacts to get a better connection, thereby making ignition easier. This is the simple stuff. If you have another, known-good lamp, insert it and try to get the projector to fire up. If this fails, or if after installing the original lamp the unit still won't kick on, the problem will need to be addressed by a service facility. When trying to turn on, you hear a "clicking" or small snapping sound but no lamp ignition, that is a symptom of a bad ballast(the circuit that ignites and keeps the lamp burning). Also, no sound may be heard. You can also look into the main lens and try to see small "lightning" flashes as the ballast tries to ignite the bulb. Usually, the ballast will try to ignite the lamp several times and, failing that, the unit is programmed to shut down.Hope I helped you.---Rick
Posted on Sep 08, 2009
Why won't my Optoma DV10 projector won't turn on?
On an Optoma DV10 if its not the lamp timer, then it might be a cooling fan that needs replacing. Take out the old one, and look-up its part number online. If you don't feel confident taking it apart, have a qualified person do this.
May 23, 2014 | Optoma MovieTime DV10 DLP Projector
Optoma HD66 replaced lamp, LAMP WARNING light keeps flashing, still won't turn on?
i just had the same problem i took the top of the projector off and cleaned the color wheel and sensor seemed to have fixed the problem that is for now. seems to happen to me once a year on the dot but last time it was warranty. good luck hope it helps.
Mar 17, 2012 | Optoma Office Equipment & Supplies
Optoma ep 1690, the on/standby led is flashing green but when I try to turn it on the temp and lamp led's flash twice and nothing happens, the on/standby continues to flash green.
The projector lamp life may have exceeded its safe limit, check your instruction manual, sometimes you have to hold the on or off button for 10 seconds to reset this. All manufacturers are different but that may be the problem.
Here is a copy of the manual, I havn't read it, my solution is from experience of other projectors.
http://www.myprojectorlamps.co.uk/projector-manual/Optoma/EP1690.html
Good luck
Aug 04, 2011 | Optoma EP1690 DLP Projector
I went to replace the bulb and when I plug it back in there is no power, no power light or anything. DS303
this is a common problem with optoma projector, if you replace the lamp yourself, it won't start!! let's sue them
Jul 16, 2011 | Optoma DS303 DLP Projector
I have an Optoma DS303 projector. It stopped working. We replaced the lamp and it worked for about 3 hours and then when we tried to turn it on again, it won't fire up. Sometimes if I hold down the...
Check the voltage at the lamp input from the ballast after connecting projector to mains supply. (Warning: Do not switch on the projector while checking the voltage. It will damage your multimeter) The lamp connection shall be removed. If the voltage is around 60 to 80 volts AC, then your ballast is OK. Check for fragments inside the lamp.
sonsunny
Jun 14, 2011 | Optoma DS303 DLP Projector
Optoma h31 stopped suddenly. I replaced the bulb, but the power button isnt flashing green, and I cant turn the unit on.
The little metal plate on the projector next to the bulb housing is not fully depressed (pressed down). The plastic cover is suppose to have a plastic piece protruding from it which is to depressed the metal plate when the cover is placed back on. If the metal piece is not pressed down, the projector will not light.
Feb 10, 2011 | Optoma H31 HOME THEATER PROJECTOR...
The amber led labeled lamp lit up on my optoma ds303 and the picture disappeared. I replaced the original lamp with an after market lamp I purchased online. It worked for 2hours or so then the amber lamp...
the reason that it turns on without hitting the power button is that it thinks it's still in cooldown mode. while it's on, check the lamp hours through the menu. if it's close to 2000 hours (or the inside of the lamp is blackened or bulging), replace it. after market lamps never seem to last that long. if the fans stay on when the lamp goes off, it could also be the colorwheel. listen for chirping. if it chirps, it's the colorwheel.
Nov 17, 2009 | Optoma DS303 DLP Projector
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
Optoma DS303 DLP Projector Logo
529 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
