Question about RCA R52WH76 Television
Digilogic tvcombo keeps cutting out
After about 5mins of perfect tv set goes dead (no electricity) Switch off at mains wait 5mins ok again for another 5mins .Do this at least twice (sometimes more needed) and all is well for hours .Everything has been tested ie plugs using in different place etc etc any ideas please? TIA maeve
  • 556 Answers
Probably got a bad capacitor in power supply
Posted on Sep 11, 2009
HOW TO REMOVE CODE 3421 IN KONICA MINOLTA 353
Sir/Mam,
Turn off the main power switch, ensure the sub power switch is on. The sub power switch is located on the right side of the control panel. Then holding down the Utility/Counter button turn the main power switch on. Close the front door you must keep the Utility button down. The screen will show TROUBLE RESET touch it sees a "OK" then power off the machine. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back, you need a Fusing unit . Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE! THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 15, 2018 | Konica Minolta Office Equipment & Supplies
How to resove trouble code c-3823
Sir/Mam, turn off the main power switch, ensure the sub power switch is on. The sub power switch is located on the right side of the control panel. Then holding down the Utility/Counter button turn the main power switch on. Close the front door you must keep the Utility button down. The screen will show TROUBLE RESET touch it see a "OK" then power off the machine. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a fusing unit. Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!!
Apr 11, 2015 | Konica Minolta "Minolta Bizhub 363 Copier,...
C3803 code trobleshot
Mar 27, 2015 | Konica Minolta Bizhub 600 750 Image...
ERROR CODE C-3852
Turn off the main power switch, ensure the sub power switch is on. The sub power switch is located on the right side of the control panel. Then holding down the Utility/Counter button turn the main power switch on. Close the front door you must keep the Utility button down. The screen will show TROUBLE RESET touch it sees a "OK" then power off the machine. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back, you need a Fusing unit/ High Current Device for the fusing unit. Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE! THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!!
Feb 06, 2014 | Konica Minolta bizhub C250 All-In-One...
How to reset fuser b501
Turn off the main power switch, ensure the sub power switch is on. The sub power switch is located on the right side of the control panel. Then holding down the Utility/Counter button turn the main power switch on. Close the front door you must keep the Utility button down. The screen will show TROUBLE RESET touch it sees a "OK" then power off the machine. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back, you need a Fusing unit High Current Device for the fusing unit. Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE! THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!!
Feb 05, 2014 | Konica Minolta Office Equipment & Supplies
Bizhub 751 c 3803
Sir/Mam,
Turn off the main both power switch one located inside the front door, second on the control panel, then wait ten seconds. then turn on main inside first. Then holding down the utility/counter button turn the sub power switch on. You must keep the utility button down The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit check. Have a qualified tech look at it. :( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! Fire could occur that would ruin a perfectly good day!!!!
Jan 08, 2014 | Minolta bizhub 350 Black and White Copier
Malfunction detected. C-3924 Konica Minolta C552
Sir/Mam,
Turn off the main power switch, ensure the sub power switch is on. The sub power switch is located on the right side of the control panel. Then holding down the Utility/Counter button turn the main power switch on. Close the front door you must keep the Utility button down. The screen will show TROUBLE RESET touch it sees a "OK" then power off the machine. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back, you need a Fusing unit ( DO NOT KEEP TRYING TO RESET THE MACHINE! THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!!
Dec 16, 2013 | Konica Minolta Office Equipment & Supplies
MY KONICA C450 HAS SHOWED ME AN ERROR C-3752
Sir/Mam,
Turn off the main power switch, ensure the sub power switch is on. The sub power switch is located on the right side of the control panel. Then holding down the Utility/Counter button turn the main power switch on. Close the front door you must keep the Utility button down. The screen will show TROUBLE RESET touch it sees a "OK" then power off the machine. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back, you need a Fusing unit Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE! THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!!
Nov 26, 2013 | Konica Minolta bizhub C450P Laser Printer
Bizhub c200 c-3421
Sir/Mam,
Nov 25, 2013 | Konica Minolta bizhub 250 All-In-One Laser...
Ive been using my ps3 on my lg 42'' lcd tv for 3 yrs now perfectly then this past few when playing a game i keep getting lots of lines distorting my picture after about 5mins of that it goes b
Sounds like a blown capacitor on your board to me. Its a common problem in Samsung TV's and is typically an easy fix, but I think in the LG's its a bit more expense and not as easy as swapping out a Capacitor. I think the main board may have to be replaced there. What actually happens is the capacitor bursts at the top and oozes liquid that solidifies, its caused when the capacitor that is used is underrated for the application (basically some engineer's solution to making us have to buy a new tv in 3-4 years, a slightly underrated capacitor will have a shelf life of use, kind of like a timer, they all do it belive me) eventually the set will not rendure any picture at all and the board will have to be replaced.
Mar 01, 2012 | LG 42LG30 42 in. LCD HDTV
RCA R52WH76 Television Logo
67 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
