Question about Siemens 2 pole 30 amp breaker
Breaker trips almost once a month in one or two rooms
We just had new wiring done throughout our house, but every once in a while two of the upstairs bedroom loses power during the night and we have to reset the breaker. This always happens when we are usually sleeping so most things are turned offer.
    Sergeant:
  • 384 Answers
Change Breaker.
Posted on Sep 08, 2009
Why are my house lights and appliances occasionally flashing on and off?
If it's only happening in one section of the house, it's more than likely the breaker that controls that section shorting out and needs to be replaced. If it's happening throughout the house, chances are, it's the main breaker that's shorting out. The least that can happen when it goes, is you'll be sitting in the dark. The worst that can happen, is it can burst into flames, burn your house down and leave you camping in the park.
They aren't that hard to replace. Once you've removed the face plate from the breaker panel, most breakers can be removed by pulling out on the bottom of them and then lifting them up and out. Once they are unplugged, they are harmless. Loosen the screw that's holding the wire or wires, remove the breaker from them and replace it with a new on. DO NOT ALLOW THE WIRES TO TOUCH ANYTHING IN THE BREAKER BOX!!!!! Once you've re-attached the wires, hook the top of the breaker in place and them snap the bottom back in. Be very careful not to touch ANY metal what so ever while doing the removal or installation of the breakers. replace the breaker cover and switch the new breaker on. See? Now wasn't that simple??? LOL! Best of luck to you. I hope I helped at least some.
Bill
Aug 24, 2014 | Cars & Trucks
Kenmore canister - trips 15 amp circuit breaker
Check specs on unit and amperage. If it is less than 15 then the upstairs breaker is kicking off prematurely - Not uncommon event. If unit is drawing more power than specs there is excessive friction in motor bearings. Also check out brushes for good contact since they wear.
Sep 11, 2017 | Kenmore 25512/ 25513 Progressive Canister...
AC trips circuit breaker not long after a recent power outage.
Sounds like your compressor is shorted to ground. If you are able, unhook compressor, wrap wires and restart. If breaker doesn't trip than u know.
Jun 07, 2017 | DeLonghi Heating & Cooling
We have 2 breaker boxers for my house. 2 nights ago, a breaker got tripped, (too many air conditioners i'm guessing) and i flipped it back and all we well...almost. The power was lost upstairs and came...
Your main breaker may be problematic... GO to your master panel... the one with the meter, and reset everything, and on any sub panels reset everything.... Good Luck...
Jul 23, 2011 | Challenger Circuit Breaker
My es300 electric range is tripping the breaker switch when I have more than one top element on and the oven. A few months ago the breaker switch started to trip when we had more than two elements on top...
Hello Happydude,
I understand that you are having a problem with your electric range. You state that as you turn more elements on the stovee on (ie. the burners and oven) the breaker will trip. Have you had any service done to the range before the problem started occuring?
This sounds like you have a problem with your breaker. As a breaker is tripped it will get weak as many times as your breaker has tripped I would replace it. You also need to verify that you are using atleast a 50 amp breaker. You will need to purchase the same type of breaker as you have (ie. Cuttler Hammer, GE, Square D, etc.). You will need a two pole 50 amp breaker. Follow the below dirrections to change the breaker.
1. Turn off the main breaker.
2. Verify that all electicity is off by checking electric in the house of building (everything should be off, not working)
3. Remove cover panel screws
4.. Lossen the screws on the two wires that are attached to the breaker
5. Remove the wires
6. Remove the breaker
7. Install the new breaker
8. Insert one wire under each screw
9. Reinstall cover panel
10. Turn main breaker on
11. Turn on oven breaker
Once the oven breaker is on check to see if all elements and oven will work at the same time. If the breaker trips. We will have to walk thru some more trouble shooting steps. However, I do believe that this will solve your problem.
Thank you for chossing FixYa.com please post any other questions that you may have about you appliances
Justin
Apr 18, 2011 | Frigidaire Kitchen Ranges
Whynter 13000 sno no power
Could be a lot of things - but I'm wondering if when you are checking the 'fuse at the plug-in,' are you actually checking the outlet for voltage?
I would check the outlet for voltage; i.e. plug in a hair dryer or something to the outlet and see if it (hair dryer) comes on. If it doesn't then I would check your breakers and see if you have a breaker tripped. In homes - you can usually go to your breaker panel (usually in the garage or a store room, i.e. pantry, hot water closet, sometimes in hallways behind doors) and find the breaker panel.
On a small unit like yours it would probably be a 15 or 20 amp single throw (like a light switch) breaker. If it's 'tripped' it can be in a position that resembles half on and half off, or it can look completely 'off.'
Remember - if it's a 'tripped breaker' - just re-setting the breaker might not solve the problem. There is usually a reason for a breaker tripping - although they do on occasion 'trip' for no reason.
In any event - if it's a tripped breaker - i would reset it and then if it happened again, either within a few minutes/or an hour - or within a day or two - then I would suspect something wrong with the unit and I would need more information, or you might need a qualified technician to trouble shoot the unit.
Note: if the breaker is tripped and when you reset it - it immediately 'pops back off.' Leave it off and call a tech - because you have a direct short and it will have to be trouble shooted.
good luck!
May 02, 2010 | Whynter SNO 13000 BTU Portable Air...
Siemens Main Breaker 125 Amp gets warm and trips
sounds like a loose connection ,or possibly a weak main breaker.
Jul 14, 2009 | Siemens /ITE 100Amp 2-pole molded circuit...
Faulty Circuit Breaker? If not, why the flames from the fan?
Not always. It sounds like your wiring burned up. If there is not a lot of load on the circuit it's possible for the wire to catch on fire and not trip the breaker. Breakers will only trip when the amperage exceeds their rating. If the wire is still intact and not shorting to the case it will not trip the breaker. I had the same thing happen to us on a job friday.
I would turn the breaker off, test and ensure the power is off, then remove the light that had flames shoot out of it. Chances are there is a wire in there that is blackened. If there is you can look into buying a new light kit. If you feel you can do it safely and you can get enough wire on each side of the burned part, you can try **** splicing a new piece of wire in. If the inside is all burned up the safest thing would be to replace the whole light kit or fan.
Jan 10, 2009 | GE WPXH214A Front Load Washer
Siemens 2 pole 30 amp breaker Logo
287 people viewed this question
Top Siemens Electrical Supplies Experts
Craig Butler
Craig Butler
john h
Steve
Are you a Siemens Electrical Supply Expert? Answer questions, earn points and help others
