Question about Olympus Stylus 1010 Digital Camera
Unknow usb device in Windows XP.
I have tried on my computer to recognize the olympus and nothing.
it always says unknown usb device, vid 0000 pid 0000 ..... if it is a bad firmware how to correct?
Is any recovery method ?
I'm trying to find any help on Olympus web site, but nothing usefull.
Are the usb on the Olympus definitively dead?
    Brigadier General:
  • 11,967 Answers
Try using a separate card reader to download your pics.
Posted on Sep 07, 2009
PnP Device ID: VID = 15D9 PID = 0A41
Device Name: ?USB Input Device
Serial Number: 5&&192F622A&&0&&1
Revision: (Information not returned)
Device Type: Standard USB device -
Chip Vendor: Agilent(???)
Chip Part-Number: A2625
Product Vendor: USB
Product Model: Input Device
Tools on Web: (N/A)
This does not work
Oct 30, 2013 | Cameras
Tip
How to Repair a USB Flash Drive
Most people who work with their computer more or less regularly are sure to have a flash drive (and even several of them). Sometimes a flash drive can become faulty, for example after a failed formatting or due to some errors.
Quite often the file system comes to be recognized as RAW, the flash drive cannot be formatted or even accesses... What can be done if that is your problem?
This manual for repairing a flash drive is intended to deal with all sorts of USB drive issues except cases of mechanical damage. The drive manufacturer does not matter, in fact, be it Kingston, Silicon Power, Transced, Data Traveler, A-Data etc. All actions to be taken are given step by step.
Getting to Know Flash Drive Parameters (Manufacturer, Controller model, Memory size)
It may seem very easy to know the flash drive parameters, especially when the manufacturer and memory size are specified on the drive case. The matter is that USB drives, even belonging to one model range and made by one manufacturer can have different controllers. Hence, a simple conclusion - in order to repair a flash drive you need to know exactly the controller model so that you can select the right fixing utility.
To determine the controller model there are special digital and letter values set by parameters of VID and PID.
  • VID - vendor ID (manufacturer identifier);
  • PID - Product ID (product identifier, i.e. identifier of a particular model);
These will be different for various controllers!
If you are not going to waste your USB drive, do not use utilities which are designed for VID/PID other than yours. Very often, a wrongly chosen utility can "kill" your flash drive.
How Do I Find VID and PID?
You can find VID and PID with the help of special utilities, but it can be done without them as well. First of all, go to Device Manager.
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-5.jpg
In Device Manager, a flash drive is usually recognized as a USB Flash Disk, so you need to right-click on the device and go to its properties.
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-2.jpg
In "Details" tab select "Parent" parameter to see VID/PID. In our case they are as follows: VID: 0204, PID: 6025.
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-0.jpg
Choosing The Necessary Utility to Repair The Drive (Low-level Formatting)
Knowing VID and PID we need to find a special utility suitable to restore our flash drive. It is better to use a search engine, Google or Yandex (a sample query: Silicon Power VID 0204 PID 6025).
Before launching such utilities we recommend disconnecting all other flash drives from USB ports (so that the utility cannot format another disk by mistake).
After treatment by such utilities (designed for low-level formatting) a problem-ridden flash drive should work properly again, recognized quickly and correctly by your PC.
Certainly, this repair manual is not the simplest one (you can't do everything by clicking one or two buttons) but it can be applied in many cases to almost all flash drive types manufacturers.
Yet before you start low-level formatting you should understand it means erasing all user information without a chance to restore it. That is, the part of the drive where data is contained will be cleaned completely. Standard Windows formatting does not do that but only applies quick formatting which is basically remarking your drive.
So if you used your flash drive to store some important data before the problems began, and now you need the data to be recovered, it is possible but only before you start low-level formatting. This operation requires special data recovery software. The best choice to suit your needs will be Hetman Partition Recovery.
on Jun 06, 2016 | Hetman Partition Recovery - Recover...
I have Windows XP. I connected the hard drive according to the directions and the first message read USB device not recognized. The second message read Try reconnecting. If windows does not recognize it...
If it is a desktop computer, try connecting to one of the rear USB ports. sometimes drives won't be recognized properly from a secondary USB or HUB. If it's a notebook go into control panel and see if you can find and delete unknown devices in hardware then attach and see if it connects. XP should not need a driver install.
Aug 24, 2010 | Computers & Internet
My computer which is running Windows XP pro 2002 does not recognize my San Disck cruzer 256 mb memory key. The light flashes upon inserting in to computer and then goes out and then I get message that CPU...
try to disconnect all usb devices and install it again to another port also try to install it on another PC if it workson another PC and yours not then try to remove ur O/S and install a good one like windows Xp SP2
Jun 15, 2009 | SanDisk 4GB microSD High Capacity Memory...
Unknown device received for JVC Everio Gz-MN21U
unknow just means it dose not have a driver list for the device. go on their web paged for driver from the device web site. and install them from there.
Jun 21, 2017 | JVC Everio GZ-MG155 Camcorder
Driver incorrect
Hello, look the device VID & PID in
Control Panel --> System --> System Properties --> Unknown Device --> Details
Es. I Found on my notebook : USB\VID_067A&PID_7561\5&1737F18D&0&2
Then Modify SER2PL.SYS with your VID & PID
Es. :
[ControlFlags]
ExcludeFromSelect = USB\VID_067A&PID_7561
[Pro]
%DeviceDesc% = ComPort, USB\VID_067A&PID_7561
Reinstall the driver
Aug 05, 2008 | ICP DAS I-7561 CR (I7561CR) Serial Adapter
I plugged my Memorex TravelDrive into my computer. It has always worked perfectly. This time I got the message that the USB device was not recognized and I can't get into my files.
THE FOLLOWING IS COURTESY OF MICROSOFT Help and Support
When you plug a USB device into a Windows XP-based computer immediately after the computer comes out of standby (S3) or hibernate (S4), the computer may not recognize the USB device. When this issue occurs, the USB device may be listed in Device Manager as an unknown device, and you may receive the following warning message:
Unrecognized device has been found.
This issue occurs because, when the computer comes out of S3 or S4, there is a five- to ten-second period when the selective suspend feature of the USB driver will interfere with detection of a new USB device connection. The time period depends on several factors. This includes the following factors:• Host controller hardware
• Attached hubs
• Attached devices
• USB driver versions
• Support for USB 2.0
• Additional system hardware or configurations that may change the timing
There may be other reasons that a USB device is not detected
Method 1
loadTOCNode(2, 'workaround'); After the computer comes out of S3 or S4, wait five to ten seconds before you plug the USB device into the computer or hub.
Method 2
After the computer comes out of S3 or S4, unplug the USB device, and then plug the device back into the computer or hub.
Method 3
Use the Device Manager to scan for new hardware. Follow these steps: 1. Click Start, click Run, type Devmgmt.msc, and then click OK..
2. On the Action menu, click Scan for hardware changes. This causes Windows to recognize new devices.
3. Close Device Manager and Control Panel.
Method 4
Disable power management of the USB hub.
Note If you perform the following procedure, you may also reduce the battery life on a portable computer.
To disable power management on the USB hub, follow these steps: 1. Click Start, click Run, type devmgmt.msc, and then click OK.
2. Expand the Universal Serial Bus controllers node, and then follow these steps for each USB Root Hub that is listed: a. Right-click the USB Root Hub, and then click Properties.
b. Click the Power Management tab.
c. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
SIMILAR PROBLEMS AND SOLUTIONS loadTOCNode(1, 'moreinformation'); For more information about advanced troubleshooting tips for general USB problems, click the following article number to view the article in the Microsoft Knowledge Base: 310575 (http://support.microsoft.com/kb/310575/) Advanced troubleshooting tips for general USB problems in Windows XP For more information about how to troubleshoot unknown devices in Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 314464 (http://support.microsoft.com/kb/314464/) How to troubleshoot unknown devices that are listed in Device Manager in Windows XP
Try restarting the computer with the device in. Sometimes if you clear the memory that might help (stating the machine without memory then put it back and start it again).
Jul 01, 2008 | Computers & Internet
Olympus 3000 Zoom digital camera
You have to edit the file:
c:\windows\inf\srusbusd.inf
You'll have to remove two semicolons.
The section:
[Manufacturer]
;%MfgNikon%=ModelsNikon
;%MfgEpson%=ModelsEpson
remove this semicolon=>;%MfgOlympus%=ModelsOlympus
Must become:
[Manufacturer]
And
The section:
[ModelsOlympus]
remove this semicolon=>;%USB\VID_07B4&PID_0100.Device%=Olympus,
must become:
[ModelsOlympus]
%USB\VID_07B4&PID_0100.Device%=Olympus, USB\VID_07B4&PID_0100
After this, if you have already the Olympus C-xxxx in your Device Manager,
uninstall it and run again the new hardware wizard. Let Windows XP find the
correct driver. Windows will attempt to frighten you with a catastrophe
prophecy. Just ignore it and go on (it works perfectly).
You're done. Now your Windows XP will see your Olympus C-XXXX Zoom
without any additional software.
Jun 05, 2008 | Olympus C-3000 Zoom Digital Camera
Olympus Stylus 1010 Digital Camera Logo
566 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
