Question about Mitsubishi WS-65807 65" Rear Projection Television
TV fails to power up. Grn lght clicks on 2 secs then clicks off
Clarification request.
Thank you very much for responding to my request!
"2 blinks, a pause and 2 blinks---it will repeat it about 10 times" is exactly what it did when I pressed input and menu at the same time for 5 seconds.
I would like to avoid buying an entire curcuit board. Which part of the board is most likely to have the problem?
  • rdbjrmd Sep 07, 2009
    Thank you. I found one 10A glass fuse (close to power cord) that was not blown, but, I am unable to find pf04 and pf05 from either side of the TV. Where are they located?
  • 556 Answers
Check fuses pf04 and pf05 if they are blown the convergence IC's are most likely the problem.
Posted on Sep 07, 2009
  • tvtechlady Sep 08, 2009
    These are pico fuses, not glass, they are located on the middle board, the one with the large heat sink with the two large convergence amps screwed to it, The pico fuses are usually green in color some are also yellow.
My TV Panasonic TX-P50GT30 do not work any more. I have the light blinking 7 time in red.
7 blinks means that you're to replace power board (it failed on start test).
May 10, 2015 | Panasonic Televison & Video
Magnavox error codes
check this
The Service Default Mode (SDM) is a technical aid that can be used to display the your TV error code.
Follow these instrutions exactly to place your set in SDM Mode.
For sets that still have video do the following.
  1. Turn your TV on
  2. Using the original Philips TV remote press the following keys. Press each key for 1 sec then press the next.
  3. From the remote press 0 6 2 5 9 6 MENU
  4. You should now see the letters "SDM" in the far right hand corner.
  5. If not do step "3' again.
  6. To display the error code hit the "Status" button on your remote.
  7. The TV can store up to "7" past errors.
For sets that have no video do the following.
  1. Turn your TV on
  4. Wait a few seconds. The red power light should begin to blink.
  5. The blinking sequence will determine the error code.
  6. You will have one long 5 second red blink followed by the error code.
Note: On some sets the TV will automaticaly blink the error code when its powered up without having to go into the SDM menu. If you power light blinks after the set is powered up jot down the sequence.
Example Error Codes from the power light.
( RED 5 Seconds ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 3
Example #2
( RED 5 Seconds ) off ( RED 1 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 12
(Note:) Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
Jul 04, 2014 | Televison & Video
Wont turn on clicks then clicks back off red light blink 7 times
check the capacitors and replace the power components check mother board also .. not handy with electronics and soldering call tv repairman 75-150 dollars Fix ?????
Sep 21, 2012 | Panasonic TC-50PX24 50 in. Plasma TV
Turn power on blu led light after about 5 sec power supply swich off and red led blink 8 times what does it mean? regards
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Apr 25, 2011 | Philips 32PF9976 32 in. HD-Ready LCD...
Daytek DT4660 - at ac on , led grn for 2-3 secs, one blink red, pause, 2 blinks red, pause , 3 blinks red, pause ,then rapid 5-6 red blinks followed by repeat of above. I've unplugged the 12 volt connector...
Hi
I work on Daytek 4660 models. I have seen the problem you are having and have solved it a couple of times by replacing all the capacitors in the power supply. If you use an oscilloscope to measure the voltages they may appear fine, however I have solved this problem by replacing all the capacitors in the 2ndary circuit of the power supply. It doesn't always work, but has worked in about half of the TVs that have come in with this problem. Also, just to make sure, if you remove the shielding from the board that drives the LCD panel make sure the little smt fuse is good. It's right on the 5V power line close to the ribbon connector from the main board.
Feb 20, 2010 | Samsung LN46A650 46 in. LCD HDTV
Lcd tv loses picture, power lght flashes grn; picture return
It sounds lamp is weak in TV and requires replacement.
I would be in better position to help you out if you post model and brand of your TV.
Dec 31, 2009 | Televison & Video
No video,hard drive running but indcator lght not blinking but it is not busted.reset button not functioning
Refresh all the connections to the motherboard and clean the RAM like shown in the image below.025c6b0.jpg
If nothing happens, reset the JCMOS1 (highlighted in the image below).
Shut down the PC first and remove the power cable connected to the power supply. Then change the jumper settings from 1-2 to 2-3 for approx. 10 secs. restoring the jumper to original settings (1-2). Connect the power cable and turn on the PC.
Hope this helps
Sep 29, 2009 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Acer Aspire Blank screen
Take the battery out, press and hold power button for 10 secs, and try again, otherwise you need to call the manufacture for an RMA request.
Jul 28, 2008 | Acer Aspire 5100 Notebook
No power
It sounds like the backlight or an inverter board on the television may have failed. Check your warranty status on the television to see if you can get it repaired by the manufacturer for free.
Sep 06, 2007 | Sony KDL-32S3000 32 in. LCD Television
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
230 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
