Question about Gaggia Syncrony Logic 74884 Espresso Machine & Coffee Maker
Hi, Our Gaggia machine will not disburse water through coffee dispenser. Sounds like its operating normally till water flow should happen. Then the motor slows down to nothing. Have descaled to no effect. Any Advice? Thank you.
    President:
  • 1,618 Answers
Try this press the button for ground coffee then when it lights up press the coffee brew button, if water flows normally then the grind on the grinder needs to be adjusted coarser, if no water then the screen on the brew unit is blocked.
Posted on Sep 17, 2009
    Problem Solver:
How do you fill boiler manually with water on gaggia syncrony logic
Posted on Jun 12, 2010
Giaggia Brera descaling problem
been talking to Gaggia (Philips) and they told me that with the newer Breras, you need to ill the water tank, put the machine into standby, then press the long and short cup buttons together for 6 seconds. This will start an auto descale programme (that they didn't mention in my manual!). A small amount of water will be dispensed through the coffee nozzles, then it will stop and the warning triangle and the prime warning light will come on. Place a large container under the panarello, then turn the knob to the right to dispense water. It will dispense about 50 - 100 mls (cold) water, then stop for about a minute. Just leave it and eventually it will empty the tank. Refill it and start again, but it will stop after a few seconds. Turn the knob back to central position, then it will dispense another small amount of water from the coffee nozzles, then stop with warning lights again. Turn the knob back right to dispense water, if it stops because of empty tank, just refill it. Eventually, the machine will stop and go to standby. Turn the knob back to the centre, refill tank yet again and the machine will start normally WITHOUT that descale warning light. HOORAY !!
Jan 22, 2013 | Coffee Makers & Espresso Machines
Hello! my 102534 gaggia esppresso machine has liquid/espresso dispensing after the 'espresso dispenser' has been turned off. if i turn the entire unit off, it does eventually stop. i've have...
HI JULIE,....MAKE SURE YOU ARE NOT FILLING THE WATER DISPENSER PAST IT'S OVER-FLOW...THERE IS A HOLE TOWARDS THE TOP...YOU DO NOT WANT TO FILL PAST.
HOPE THIS HELPS!
Sep 03, 2011 | Gaggia 102534 Espresso-Color...
Gaggia titanium - between cups of coffee, we leave the machine on. After only a few minutes, the machine makes a loud clicking noise, and then the noise speeds up. A very loud, clicking noise, very...
Hi, That loud noise is the pump, pumping without water running through it. Thats not good. Will do expensive damage to whole machine if let go. It needs flowing water to stay operating for a good life. Already sounds like an ECU board. It may only be trying to rinse itself, but is cloged, and cant get enough water into it. It needs to be looked at by a repairer. I can helpyou there if you live on the sunshine coast. Dazza
Aug 21, 2011 | Gaggia Titanium Espresso Machine
Too much water is dispensed resutling in a weak espresso. This happened after rinsing the brew unit. Greatful for any assistance with this. I have a 1 year old Titanium.
Hi
Try reprogramming the button that is dispensing to much.
Push and hold the button for the coffee you want, but hold it all the way through the process. Don’t release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button.
If that doesn’t fix it, then you might need a new flow meter.
Jul 20, 2010 | Gaggia Titanium Espresso Machine
Water continues to flow after dispensing coffee
Sounds like there was a high pressure buildup at one time that affected the spring and valve in the grouphead. Remove the shower screen and then the 2 allen wrench screws, check the spring and valve to make sure it is seated properly.
Feb 19, 2010 | Gaggia 102534 Espresso-Color...
After the coffee is ground and pressed, no water goes through to brew the coffee and dispense it
Sounds like the brew unit is blocked, to be sure try this, use the pre grounds button to brew a coffee, if no water comes out then it is the brew unit, remove unit and look under red o-ring, you will see a shower screen, clean shower and tube that flows to the discharge(top, you will have to remove the 2 screws up there, be careful not to lose the small plastic ball under the spring). Reassemble and try again.
Jan 18, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Gaggia titanium espresso ventilate is on the screen.I press button 26,nothing happens
Hi
When you push the water button, then open the steam knob. This will allow water to flow. If you don't get water to flow check the water tank and make sure that it is down on the machine completely. The other thing that will not cause water to flow is a restriction in the flow meter.
Nov 02, 2009 | Gaggia Titanium Espresso Machine
Gaggia Synchrony wont work after decaling
Check the thermostats on the boiler and the boiler element?
Jul 14, 2009 | Gaggia Syncrony Espresso Machine
No water coming through on rinse cycle
try to make a cup of water (tea), if you not get any water that way i think you have to replace the flow meter in the machine.
Best regards
/Mirran
Oct 24, 2008 | Gaggia Titanium Espresso Machine
Gaggia Syncrony Logic 74884 Espresso Machine & Coffee Maker Logo
696 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
