Question about Hayward H-series Electronic Gas Pool Heater H300
Pool heater green light is on, but when when we tried to heat spa, no light, no heater kicked on. What is going on?
  • A Miller May 11, 2010
    Does your heater do both your pool and your spa? You probably know, the boiler will not fire if there is no pressure. I dont know about your plumbing and how it changes over from hating the pool to the spa but for the heater to fire for any application, you must have water pressure. There is the possibility that your pressure switch is working intermittently but you hint it will heat the pool.
    Champion:
  • 246 Answers
Clean the filter
Posted on Sep 11, 2009
How do you fix a fl 7 firemen's switch open message
connect the firemans switch to the heater pins 1 and 2 on the long green plug then enable the heater on the one touch make sure heater is set to highest setting make sure wires go to pool and com then it will work your aqualink will control heat settings
Jun 30, 2014 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Heater Kicking off breaker
Heaters are dangerous. If you are not an experienced tech you should get qualified help. A tripped breaker indicates a serious problem.
May 18, 2013 | Legacy Jandy Lrz125en Swimming Pool Spa...
When i turn on my spa and heater it states on the outside unit "no air flow" and it won't heat up
that is usually an indicator of water flow not the air flow.
What does the hot tub do when you turn the breaker from off to on?
does it run through the purge cycle?
is it kicking out the GFCI?
if it is not tripping the GFCI then you most likely have either too little water flow for the heater to kick in or not enough water flow to activate the heater.
Try taking out your filter and see if that solves the issue.
you may also have a bad temp sensor if the tub just runs and runs but never heats up.
Rod
US Parts Center
888-521-6183
Feb 08, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Pool heater is not working properly
So I assume you have pressed the button by pool to select the pool thermostat? If this doesn't work sounds like another mother board problem, or try powering down the unit a few minutes then restart. IF you haven't pressed the pool button, the read this: The heater comes factory set at 78° F. for the pool mode and 100° F. for the spa mode. If it's in spa mode it's trying to get to 100F. Using the up and down arrows,you can set the thermostats to a minimum temperature of 65° F., or a maximum of 104° F. If you desire to heat only one
body of water, the thermostat is capable of an off mode. As an example, if you only wish to heat the pool and not the spa simply depress and hold the spa down arrow, and the thermostat will lower its setting to 65° F. then go to an off mode. Here is a link to your manual :http://www.pentairpool.com/pdfs/MasterTempOM.pdf
Jul 07, 2010 | Pentair 460732 MasterTemp Heater 250BTU ...
Spa Heater Does not kick in
Sounds like the heater is dead, check to make sure your getting voltage to the inside of the unit, The power comes into the galvanized box, there is a fuse in there. Depending on how it was wired you should have 120 or 240vac
Mar 01, 2010 | Sta Rite Sr333na Max E Therm Pool & Spa...
Just changed the thermisor and now the heater won't turn on. 4 green lights come on the control panel: pool on,spa on, aux 1 and aux 2. the underside has 3 green led lights lit and one red for cr21.
If all you did was replace the heat sensor check to be sure that you didn't losten any other wires on the header and on the board. Often when you pull the board for inspection you can pull other wires without knowing. Also be sure your baskets and filter are clean. Good luck.
Dec 07, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
Pilot light on pool heater is on but heat exchanger not kicking in?? model h1501
check for 24 ac at the brow wire if 24 change the valve if zero change the ignition control
Oct 08, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H-series Electronic Gas Pool Heater H300 Logo
123 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
