Getting SERVICE CALL 160:FATAL ERROR On OKI C3200N Colour Lazer. Error was 161 but after replacing the Magenta Drum its is now 160
cheetahj25
  • 32 Answers
SOURCE: fatal error 163
What is your printer name and model?
Regards,
Chester
Posted on Jan 11, 2008
  • 97 Answers
SOURCE: 980: Fatal Error
From the Service Manual:
*Service call
980:Error
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Posted on Apr 07, 2008
SOURCE: does anyone know what is
According to the Oki service manual that problem is related to the fuser. The reference is that there's some media stuck in the unit, they recommend replacing the fuser but it's possible just reseating it with power off will allow it to clear the code.
Posted on Apr 21, 2008
SOURCE: OKI C5900
we have the same problem but with Oki c5500
Posted on Jun 21, 2008
rylee_smith
  • 8619 Answers
SOURCE: Oki C5800 prints magenta streaks
Streaks can be caused by a number of things
The fuser
The ETB
The toner cartridge
The firmware
The printer needs a cleaning.
The slot in the printer.
Incorrect Media.
Try cleaning the printer, use a lint-free cloth for the ETB, DO NOT touch the belt with your fingers, the oil from fingers will often make things worse.
Always use a lint-free cloth, if you ever encounter dirt inside the printer, dampen the cloth.
Calibrate the printer.
From the printer's control panel menu
Configure Device-> Print Quality-> Calibrate now.
(Press the Checkmark key to advance through menus)
Posted on Jan 14, 2009
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Aug 12, 2014 | OKI C3200n Led Printer
Printer COki5150n....
I had the same problem. I came across the 160 error after I moved drums around. My issue started with error code 161. which appears to be the Magenta drum. Moving it to other color locations gave me errors 160, 162, 163. 160, I assume, is the cyan cartridge, then 161 is the magenta, 162 is the yellow, and 163 is the black. In my case, the magenta was very dirty. I pulled it out, used an eraser from a #2 pencil to clean the contacts. Used the shopvac to clean toner power out of printer. Turned it back on and it worked.
Apr 10, 2010 | OKI C5150n Led Printer
Oki C3200 message on screen says '171 Fatal
Yes it can be saved, it is indicating the fuser thermister is open or below temperature. Try opening the printer and restarting it. If that does not fix it you may have to replace the thermister or the fuser
Jan 18, 2010 | OKI C3200n Led Printer
I have a Oki C9500 laser, the magenta print is streaky
I have the same problem with my OKI c3100, please help
Jan 13, 2010 | OKI C9500dxn Led Printer
Getting error 142 fatal error
unplug the unit then clean the printer and all drum units and etc with compressed air. Replace the drums and replug should solve the problem.
Dec 10, 2009 | OKI C5500n Printer
Error message OKIC3200n printer
I called the OKI help number, in the manual, and they told me that the second line of the error message, was just an additional reminder, to replace the magenta toner.
Sep 29, 2009 | OKI C3200n Led Printer
141: fatal error OKI Printer
This can be caused by the transfer belt damage or the contact group damage. 141 is an error of Magenta ID up/down. Possible reason though - check the place next to the belt at the right hand side near the Magenta drum location. You'll see the terminals sitting in the housing with the spring. If the housing is fell off or the spring is missing - that can cause this error. Otherways you'll need to replace the transfer belt.
Jul 30, 2009 | OKI C7300 Led Printer
Okie C5400 giving 162: Fatal Error
Magenta toner sensor error. Reseat drum unit. check toner cart. Take out the key that prevents you from putting drums in wrong slot and swap the whole drum and toner assy with another color, if it follows the magenta unit then that is the problem somehow.
Mar 19, 2009 | OKI C5400 Laser Printer
Fatal error 163
Fatal Error 161-Toner Sensor Error, Color:Magenta
When magenta toner sensor error has occurred
Fatal Error 163-Toner Sensor Error, Color:Black
Both are Sensor errors....You would first check the lock levers that hold the toner cartridges in, if everything is fine with them then you could possible have toner dust on the sensors. First take out the cartridge that you are having problems with, then use a dust off can and carefully clean out any axcess toner that you can see where the toner sits. there is a sensor that looks like a clear plastic or glass eye that reads the cartridges and it sometimes gets dirty.
Jan 11, 2008 | OKI C5200n Laser Printer
Fatal error 141
141 Drum Up/Down, Color: Magenta An error has been detected in your printer's Magenta Drum. Did you already get this fixed?
Jun 04, 2007 | OKI C7300 Led Printer
546 people viewed this question
jasbo
jasbo
