Question about Pioneer SX-315
Pioneer sx 217 home theater system
Best buy never left me a manual, cant get front speakers (depending how they wired it ) to work
  • Anonymous Feb 16, 2009
    AhHHHHHHHHH
  • 3 Answers
You have to put the red and white cords into the tv section of the receiver and the yellow cord into the dvd console.
Posted on Jun 20, 2008
Yellow red and white were to put in back of t.v
Posted on Feb 03, 2008
How do I hook up a powered subwoofer to a pioneer sx-316?
Many subwoofers accept both line level (RCA jacks) and amplified inputs (+ and - speaker terminals). The Pioneer SX-316 does not offer line level output, only amplified outputs via the PURPLE + and - speaker terminals. This means that in order to use any subwoofer with an SX-316, the sub woofer will need to accept a + and - speaker wire connections for input Your manual speaker connections are on page 11 of the manual which can be found here: http://www.manualslib.com/manual/260358/Pioneer-Sx-316-S.html#manual
Starting at the rear of the SX-316; run a speaker wire from the PURPLE + and - terminal (SUBWOOFER) to the + and - speaker input terminals on the subwoofer. See your subwoofer manual or experiment (at your own risk) with connecting the speaker wire from the SX-316 to the subwoofer's + and - LEFT only, RIGHT only or BOTH left and right speaker inputs. Do not connect wires from the SX-316 to the speaker OUTPUT terminals of your subwoofer.
Finally, adjust any variable low pass filter knob or setting on the subwoofer to the lowest frequency that your main speakers are capable of producing. If you're not sure what that value is, try setting the subwoofer to 100Hz and judge how it blends with the main speakers. If it seems a little too bass heavy and thick then reduce the setting to 80Hz. On the other hand, if the sound seems to be slightly thin and lacking weight, try increasing the setting to 120Hz. By careful listening and a bit of patience you will be able to get the sound to seem balanced and well blended.
Apr 06, 2014 | Audio Players & Recorders
Owner manual for pioneer sx 316s
You may download a copy of the operating instructions here.
Mar 17, 2013 | Pioneer Sx-316s Stereo Audio Video Home...
Front left speaker stopped working. I use the system with my computer (full volume on computer), and usually half volume on the speaker. I've had the speaker for a few months now. I looked the wiring to...
You 'looked' at the wiring but have proven it is defective by swapping the speaker independent of the wiring. What's next? Replace the bad wiring.
What happens when you put a working speaker and wire on the front left output?
Apr 14, 2011 | Samsung HTC550 Theater System
5.1 Dolby system does not work with the T.V.
Solution: connected the rear right and left wires to the Front , left and right wires......................and everything works the way I anticipated without any technical problems....... the woofer works on a separate circuit, so I continue to receive the "low" frequency..
Oct 01, 2009 | Memorex MiHT5005 Theater System
Sound Issues
Ah that's the problem, Pioneer has been famous for audio problems. Your model is a newer one that uses a system scanner to detect audio problems. Check your wires and see if they are connected correctly. To be honest, as an expert on Home Theater systems, Pioneer is not the best way to go, Boston Acoustics is a really good system, pricey, but good.
Jul 01, 2008 | Pioneer HTS-GS1 Theater System
PIoneer Htp 2700 stopped working
Unit still under warranty. Best bet is to contact Pioneer for the location of their closest authorized factory repair center and ship unit to them for warranty repair. Or check out ebay for a used unit or parts being sold.
Jul 28, 2017 | Pioneer HTP-2700 System
Pioneer HTP-100-SW
i just installed my htp 100 sw. the scheme was atached to the back of the woofer for me tho. easy. front speakers go into the sub in the two botom inputs from the receiver. the two upper are outputs to the actual speakers. hope it helps
Dec 24, 2007 | Pioneer HTP-102 System
Pioneer SX-315 Logo
1,267 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Morne Olivier
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
