Question about Whirlpool Dishwashers
The panel is displaying ERR4 - Whirlpool Dishwashers
  • 10,515 Answers
This error is mostly on Whirlpool Dishwashers.
E4 is telling you it is not recognizing that it has drained
#1 drain pump runs for more then 4 min.
#2 or drain pump not running at all
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 07, 2009
Err4 what can i do?
One of the thermocouple temperatues is more then 50 degrees. Please consult your service provider
Sep 23, 2014 | Science & Laboratory
Cyclone SX9 0 MAXPRO Treadmill
Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
God bless you
Jun 03, 2013 | Exercise & Fitness
Kettler axos Cross p crosstrainer. First Time use. Err4 On Display, no Reaktion On keys. What can i do?
adjust the REED switch see the diagram, clean, and tigh the wires connector very well.
2) tight the ribbon cables, clean it,very well
3) tight the display board connector vs lower board connector
Try again. 4) If this not function Try to RUN the software calibration for easy diagnose, troubleshooting, and fix it.
God bless you
Aug 31, 2012 | Exercise & Fitness
Carnt find manual/instructions the digital display screen keeps saying err4
Do a Google search on your model number and type in manual/instructions.
May 05, 2011 | Haier Washing Machines
Err4 message
On a Kitchenaid coffee maker, ERR 4 indicates a stuck button. Please double check to make sure none of your buttons are sticking in place and "freezing" the coffee maker. If you can not find any obvious problems, I would recommend calling Kitchenaid Customer Service to see what options may be available to you.
Their toll-free phone number is 1-800-541-6390.
Feb 06, 2009 | KitchenAid KCM511 Coffee Maker
Err4
ERR 4 in a Kitchenaid coffee maker indicates a button is stuck in place. Please be sure to check all of your buttons and see if any are stuck depressed into the machine.
If this is not the case, I would suggest contacting Kitchenaid Customer Service to see what other options may be available.
Their toll-free telephone number is 1-800-541-6390.
Dec 31, 2008 | KitchenAid KCM511OB 10-Cup Coffee Maker
I have Err 4 on my coffee maker... help
If “Err4” appears on the brew
timer display:
A button is jammed. Unplug the
Coffee Maker, press each button
several times, then plug the Coffee
Maker back in. (If the Coffee Maker
has been stored or used in a cool
environment, warm the unit to
normal room temperature before
doing this.) If “Err4” appears again
on the display, repeat this procedure.
• If “Err1”, “Err2”, or “Err3”
appear on the brew timer
display:
Press the On/Off Button to reset the
Coffee Maker. If the error codes
reappear, there is a problem with the
Coffee Maker electronics. Please refer
to the Warranty and Service section
beginning on the following page.
If the problem cannot be fixed with
the steps above, please refer to the
Nov 25, 2008 | KitchenAid KCM511 Coffee Maker
I have an err4 on my kitchenaid coffee pot. I have unplugged it several times and pushed each button each time but it keeps popping up with the error. It turns on every time I plug it back in before the...
Had the same problem after cleaning. ERR4 is the result of moisture in the electronics. FIRST UNPLUG COFFEE MAKER. Get a long philips screwdriver and remove the 4 screws at the bottom of the coffee maker. Pull the bottom off and carefully unclip the front panel. The circuit card is simply clipped in so it removes nicely by unclipping with your fingers. Now take a hair dryer and dry out the circuit card. Carefully plug the maker back in and verify that the LED nolonger reads ERR4. Reassemble and your back in business!
Sep 07, 2008 | KitchenAid KCM511 Coffee Maker
Dishwashers Logo
75 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
