Question about Canon PIXMA MP510 All-In-One InkJet Printer
Error 5100, screachy noise
It was printing fine, then suddenly made a weird screachy noise and said error 5100, turn off power and turn back on, if problem not reolved refer to user Manual. Can't find my manual and cant find a 'free' online manual. Please Help??
Canon pixma mg2120 error 5100
I just bought this Canon PIXMA MG2120 PRINTER about 2 weeksago, I've been able to print untillast night, it's giving me error message 5100, what do I do to fix this?
Jul 15, 2012 | Canon Office Equipment & Supplies
Canon MX7600 error 5100, 5C20
Yes, 5100 means the carriage is not moving back and forth properly or there is grease on the encoder strip behind the carriage assembly. Grease spots make it lose count and slam into the side and grind gears. You need to clean the strip with a Q-tip moist with alcohol, but very carefully, not too much pressure on the strip.
Dec 13, 2009 | Canon MX7600 Office All-In-One Printer
Hi, I am trying to print a report and I get a service error 5100. I have cancelled print job and pressed ok, done this a number of times, still get the error, please help
Service Error 5100
Cause : The movement of the FINE cartridge Holder is blocked.
Action : Clear the paper jam or foreign object that is preventing the FINE cartridge Holder from moving, cancel printing from your computer, then trun OFF the machine and turn it back ON again.
Hope this helps. Pllease rate my Response.
Thanks.
Have a good day. .top3Module { BACKGROUND-IMAGE: url(/images/Reviews/Top_3_BG_Asset.jpg); WIDTH: 310px; BACKGROUND-REPEAT: no-repeat; MARGIN-BOTTOM: 15px; HEIGHT: 361px } #RNR_rpt_div A { COLOR: #0033cc; FONT-SIZE: 12px !important; TEXT-DECORATION: none } #RNR_rpt_div IMG { VERTICAL-ALIGN: middle } .toptitleBest { MARGIN-TOP: 19px; FLOAT: left; COLOR: #4f81bd; MARGIN-LEFT: 19px; FONT-SIZE: 18px; FONT-WEIGHT: bold } .wrapperDiv:hover { CURSOR: hand } .wrapperDiv { FLOAT: left }
Dec 04, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Canon mx330 Error 5100 Error 5100 Printer error has occured. Turn printer off and then on again. If this doesnt clear the error, see the users guide for more detail.
Cancel printing, turn off the machine. Then clear the jammed paper or protective material that is preventing the FINE cartridge holder from moving, and turn the machine on again. If not remedied, turn off machine, unplug the power cord of the machine from power supply. Plug machine back in and turn power back on. If problem is not resolved, please contact service center. This info is from Advanced Guide Troubleshooting Section under An Error Message is Displayed on the LCD....error code 5100. This is a link to Canon to download Guides.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=18120
Nov 04, 2009 | Canon PIXMA MX330 Multifunction InkJet...
Last week i tried to print but it didn't work and appeared 5100 error. i have the pixma mp 170 printer... i don't know how i can fix it
Hello
The manual states that the error code 5100 is a result of:
Service error 5100 is displayed
Cause: Movement of the FINE Cartridge Holder is blocked.
Action: Clear the paper jam or foreign object that is preventing the FINE Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
You might see something blocking the printer head, check inside to see if there is a paper jam, staple, or some other object blocking the print head.
If this does not work, try resetting the device:
  1. Turn the printer off.
  2. Hold the button Resume / Cancel (red triangle in the circle), click POWER - indicator lights green.
  3. Release the button Resume / Cancel, keeping POWER.
  4. Click Resume / Cancel 2 times, keeping POWER, and then release all the buttons.
  5. When the indicator light Green - click Resume / Cancel 4 times!
  6. Turn the printer off button POWER.
Hope this can help you.
Best regards
Andrea
Oct 20, 2009 | Office Equipment & Supplies
Error 5100 on MP450
It sounds like the fine cartridge movement is being restricted.
Oct 18, 2009 | Canon Pixma MP450 All-In-One InkJet...
5100 ERROR
As per the manual...
Mar 27, 2009 | Canon PIXMA MP170 All-In-One InkJet...
CANON PIXMA IP1200 resetting
My converted iP1200 is currently blinking green, yellow, green, yellow on the power lights after start up and print request. The pop-up prompt suggests turning off the printer and turning it back on. Error 5100 is always seen.
Please Help Me...
rakibfuture
Mar 30, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Error code 5100
Error code 5100 /this error is an error within the printer. This error means that there is
something obstructing the printing process. Check inside your printer through the gears that
you can see under the lid. There should be something obstructing the gears such as dirt or
in my case popcorn. Check VERY thoroughly.
Mar 23, 2008 | Canon Pixma MP500 All-In-One InkJet...
Error 5100
Service Error 5100 is Displayed
Cause
Action
Sep 27, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
178 people viewed this question
old marine
old marine
