Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Changed the ICs but bad resistor
Can anyone Tell me what resistor goes into spot R850? and where i can order it?
  • jonze1 Dec 09, 2007
    Bill,
    Thanks for the help, The resistor does look like the one in spot R 846 but with different color bands. I replaced the convergence IC's with STK392-110's and nothing happened then i noticed the blown resistor. I checked the rest of the resistors that is the only one I need to change but I can't get a reading off of it to change it. Should I get a 1.5 ohm 2 watt? and Should I get new IC's and upgrade?? I will order from acme-sales when you write back....Thanks for your help I really appreciate it
    Jonze
    Bill,
    Also I am looking on acme-sales and there is no 1.5 ohm 2 watt, What should I get?
  • 934 Answers
Jonze,
I don't have a schematic here so I'm shooting entirely from memory... the 850 series position tells me you're in the convergence circuit and I would guess you're replacing some of the yoke return resistors.. Are there any color bandings on that resistor? How about compare it to R846 which I know is a yoke return resistor (it's a 1.5 ohm / 2w) and does it look about the same?
Now I'm going to be really pushy - - - the heading here says you changed the ICs and I would assume you're referring to the convergence Ics? Both are a STK392-110 factory, what did you change them to and where did you get them?? Reason I ask is that there are a lot of chineese knock-offs out there and they won't last sometimes past pressing the power button. And usually with these units I upgrade to a higher amp Ic for greater reliability like a STK392-150 or 180... In addition take a dmm or annalog ohm meter and test all the low ohm resistors in that youke return. A resistor doesn't have to look burned to have changed in value...
Where do you get them... Try Acme Enterprises in Florida.. They have quality Sanyo original Ics and prices are cheaper than anywhere else you'll find in the US... http://www.acme-sales.net/index.shtml
Have a great day and good luck on your repair!
Bill
Posted on Dec 09, 2007
  • William Rayburn
    William Rayburn Dec 09, 2007
    Personally I'd get the upgrade Ic's from acme and install them...
    I did also acquire the service manual this evening. R850 is a 2.2 ohm 1w which I would personally upgrade to a 2w... Acme sells those also in a bag of 10 for $1.99 and you might as well check and change out all the 2.2 ohm 1w for the higher 2w... BTW the color banding on that is red-red-gold-gold and you should see serveral others in that area...
    Bill
Don't have remote is there another way to line up colors I've already changed the convergence chips but not the resistors
Chances are the new ICs have failed since the 6.8 ohm resistors werent changed a phillips will almost always blow one or two of the 6.8 ohm resistors and if new ICs are installed without replaceing the resistors the new ICs are usually destroyed by the blown resistors. You will need the original remote or authorized replacement to adjust the convergence properly.
May 06, 2011 | Philips 55PP9401 55" Rear Projection...
Hitachi 61swx10b HDTV - Convergence problems. User 'gdroukas' mentioned in a post that it is probably the convergence amps and a few resistors that have changed value. Can anyone be a bit more specific? ...
Convergence ICs are Big Black ICs and will have the part number on them. STK392-110,
upgrade to 120s or 150s better ICs.
Resistors to replace are RK42 3.3ohms, RK46 1.8 ohms, RK50 2.7ohms,RK54 1.5, RK58 3.9 ohms. RK62 2.2ohms
Mats Electronics has STK ICs 1-800-628-1118 order convergence Kit that comes with resistors.
ACME has the Convergence resistors they must be 1 watt resistors 1-800-575-9833
Let me know if you need any more help Thank You.
Jan 13, 2011 | Televison & Video
We have a samsung rear projection tv with the same problem of fine wavy lines across the whole screen,more visible with light and dark colours, its like watching the tv with fine rain, sometimes the...
Your convergence ICs could be going Bad if so TV will shut down if the one that starts it goes out first STKs big black ICs also 2 resistors l;ow ohm 2.7 ohms near ICs.
Aug 14, 2009 | Samsung Televison & Video
Philips 51MP392H/17 PJTV. Green beam pulsating horizontally.
Most likely problem is the ACS panel if you have already changed the ICs and resistors.
Apr 06, 2009 | Televison & Video
No color adjustment or convergence
You need to replace both convergence ICs they are both STK3920110 Ics you may also need a couple of the 6.8 ohm 1/2 watt resistors as that chassis will usually open a couple of the 6.8 resistors. you can get repalcement ICs and resistors at the following link.
http://servicemanuals.vstore.ca/
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Manual convergence -service mode
you have some resistors that are still open . If the ICs go a resistor or two usually go open and you cant always tell unless you remove 1 leg out of circuit and check that the resistance is within 5% of the rated resistance. Trying to adjust it by the service menu will only place extra strain on the new ICs and they will blow on you. The resistors are located right next to the ICs there are about 8 of them all I dentical. Very easy to spot.
Mar 27, 2008 | Philips Magnavox 51MP392H Rear Projection...
Panasonic IC's
usually you can see the resistors being a little discolored as they dont have color bands on them. If you dont notice any discoloration on those resistor you should be good to go. There are about 7 or 8 resistors right next to the ics they stand up off the boards easy to spot, just look them over real good.if you notice any discoloration let me know the code stamped on the resistor and I will give you the ratings of the resistors.
Mar 01, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Convergence concern
They are located right next to the Convergence ICs easy to spot. There are numerous identical resistors.Usually 1 or 2 will be open.
Feb 10, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Bad Resistor
Jonze,
Guess I should have looked to see that you had a second post. I justa answered one and here's some of the answers to my questions..
Brown - green - grey - gold would be a 1500m resistor and I would HIGHLY doubt they used something that intolerent in the convergence circuit... It's more likely to be a 1.5 ohm resistor which is brown - green - gold - gold and the grey you're looking at my just be discolored from heat stress...
Take a look at my previous post and tell me what you find after you make some comparisons.
Bill
Dec 09, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
