Question about Delta Plumbing
Delta Faucet, bath and shower type, Model: Monitor, series 1700, leaks at the tub outlet when water is shut off. Can you provide information on problem and how to fix. Bob
  • 1 more comment
  • eshelbrenner Sep 07, 2009
    You referred to a bad washer. Is this the O-Ring. A diagram on the Delta site doesn't show a washer. Either way, can you provide more detailed instructions.
    Bob
    Thanks protek, a picture is always helpful. I plan to get the gasket on my way home this week, and fix the control next weekend.
    I will let you know if I have further questions and when I completed the the task.
    Bob
  • eshelbrenner Sep 11, 2009
    Please provide instructions on how to dissamble the faucet. The Delta site provides only limited information.
    Bob
    President:
  • 1,922 Answers
Replace your hot or cold faucet seals, feel temp of water to see which one is leaking,but as long as your at do them both its not expensive and a few common household tools later youll have it fixed,w/o an expensive plumber,go to a hardware store and they can even coach you on how to install the parts they sell you for the repair
Posted on Sep 11, 2009
    President:
  • 1,865 Answers
You have to remove the handle and replace the washer. The following link will take you to the delta site for more info
http://www.deltafaucet.com/customersupport/faq/Leaks/index.html
Posted on Sep 08, 2009
    President:
  • 1,723 Answers
I'm giving you a photo where the gasket is, you will need to replace this gasket to stop leak.
Posted on Sep 07, 2009
  • 601 Answers
I think it have a bad washer on the valve stem in the faucet that needs to be replaced.Call a proffessional plumping contractor for assistance.
Hope this helps
Thanks
Smith.
Can't get both hot water running at the same time. Delta Shower faucet
  • The spool and sleeve, the part of the Scald-Guard pressure balance valve that blends the hot and cold water, is not working properly. This can is caused by mineral deposits that build up over time resulting from hard water. To fix this, follow the steps below based on your model.
  1. Shut off water supply.
  2. There are two types of valves. Choose one or the other below depending on your series.
  • 1300-1400 Series: Remove handle.
  • 1700-1800 Series: Remove temperature knob, cover and handle.
  1. Twist and pull sleeve to remove it.
  2. Unscrew brass bonnet nut.
  3. Remove cartridge.
  4. Soak cartridge in a 50/50 vinegar and water solution for 24 hours to remove any mineral deposits.
  • **NOTE** Unless both hot and cold water supplies are turned on, the pressure balance valve will allow only a dribble of water to flow through the valve.
  • I have put up a picture to make disassembling it just that much easier for you.
Regards, Tony
May 23, 2011 | Delta & Single Handle Shower Faucet
How do I turn the shower on? I just moved into a place that has a Delta series 1400 Monitor shower handle, a smooth faucet, and NO mechanism whatsoever that I can see for switching from bath to shower. Is...
There should be a dirverter on the tub spout. It will be either a knob to pull up or a ring to pull down on and hold untill the water comes out the shower head.
If there is no dirverter go buy a new tub spout with one.. The prior owners may have installed the wrong spout.
Apr 01, 2011 | Delta & Single Handle Shower Faucet
I recently move into a condo that has a Delta single lever Series 1400 single lever bathtub fixture. The bathtub has a shower nozzle that looks like it has been used. I cannot find where there is a button,...
Is there a button on the tub filler? How about the spout on the tub, does it lift up? If there is not a tub spout then it should be shower only, if it has a tub spout it has to have a lifter of some sort, the foto I found showed the little button lifter. Hope this helps.
May 29, 2010 | Delta & Single Handle Shower Faucet
Adjust the hot & cold water for delia monitor 1700
Remove handle and check to see if there is a dial to take out to repostion back in to adjust cold and hot water flow. take it out and move it a little put handle on and turn on see if it changes,
May 05, 2010 | Delta Home
Bath tub water faucet leaks. It is a single handle type.
You will have to replace spring ang washers behinde valve cartridge.
Oct 24, 2009 | Delta & Single Handle Shower Faucet
Moen - Single lever bath tub faucet - cold water only
moen does not have a ball and washers....sounds like a Delta maybe. Moen uses cartridges. Either way sounds like a balancing spool problem....but you will need to make sure of the right name for the faucet to get the parts.
Aug 17, 2009 | Plumbing
I have a Delta Series 1400 faucet in the tub/shower. The handle turns left and right for Hot & cold, but I do not know how to adjust total volumne. Is the round know supposed to pull out? It does not...
hi roger,
Sorry Delta 1300 and 1400 series valves do not have a volume control. Kinda odd but that is how they are made.
Please rate this response and Good Luck, Phil
Dec 30, 2008 | Delta T13420 Chrome Classic Single Handle...
Plumbing Logo
82 people viewed this question
Top Delta Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Craig Butler
Craig Butler
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
