Question about Toshiba SD-2800 DVD Player
Toshiba Sd2800 My brother gave this to me without any instructions. When i put an Disc in it reads ;" Loading " and makes a rewinding sound and ends up reading Disc error. I bought a DVD Cleaning Disc but I can't even get that one to Load. Please help.
  • 3 more comments
  • Anonymous Dec 24, 2007
    I have the same problem with my SD-2800. Any suggestion how to fix the issue?
    Mike
  • Anonymous Dec 31, 2007
    Started with disc freezing--now I can't get discs to load.....
  • Anonymous Jan 10, 2008
    Same issue Disc error on the read out and "Not Pal" message on the screen (It's a ntsc model and was working fine) Last movie we tried to play prior to this was "Shoot em up" ... DRM bug?
  • sexymarty Mar 16, 2008
    Don't watch a lot of t.v., put in a movie for the 1st time in about a year1/2. Dvd player read loading for about 25 seconds & made a sound so loud, I looked for the disc to be chewed up when the loading stopped. TV read disc error. Since the machine hadn't been used in such a long time, I assumed it was dusty and sprayed the disc area with canned air. I put a brand new movie that had never been played & it started playing right away. I took it out & put in the movie of choice & it started the loading process all over again. I worked on the dvd player for over an hour & got no where! Help! Marty-Teddy Bear Beads!
  • Anonymous Feb 01, 2009
    I have the same problem - stalling while loading and then only disc error. Hasn't been used in a couple of years.....how do you fix????
You may already have given up on this model and bought a new one, however, I have (sort of) a solution to this problem. I have a Toshiba SD-2800 that, over the years, has had limited use and today, when I tried to use it, I received constant "Disk Error" messages on all media, blank and pre-recorded. On other boards I saw a reference to shock-absorber feet on the drive mechanism that collapse over time, causing the drive to bind up. I put in a disk and, as quickly as possible, turned the unit upside down. The disk played normally. In order to eject the disk, I had to turn the unit right side up or else the platter would open and the disk would remain inside the unit.
Clumsy? Yes, however, it worked. I plan to open the case tomorrow and see if there is some way to prop up the drive mechanism to avoid the flip action. Doubt I can get new parts on a unit this old.
Posted on Oct 18, 2009
I have the same problem with my SD-2800 that Ruska has. Any suggestion how the unit can be fixed?
Posted on Dec 24, 2007
How unlock a Toshiba sdv398kc dvd?
Toshiba SD1200 / SD1600 / SD1700 / SD210E / SD2109 / SD2150 / SD220E / SD2800 / SD3750
  1. Insert DVD with foreign region code
  2. Wait for the error message to appear
  3. Press M (Memory)
  4. Press 1
  5. Press PLAY
Toshiba SD120E / SD125E / SD220E
  1. Get the multi-region update disc for the SD220E (http://www.geocities.com/its_yahell/toshiba_sd220e.html)
  2. Write it in DAO mode
  3. Switch on DVD Player
  4. Press SETUP
  5. Under the Picture option change Pal/Auto setting to Auto
  6. Press SETUP
  7. Insert the update CD
  8. The following images are displayed: ?'Nabe the Wiz?' and then ?'FIN?'
  9. Remove CD
  10. Switch DVD Player On/Off
Toshiba SD240 / SD350E / SD3960 / SD3980
  1. Open the disc tray
  2. Press 2, 4, 0, 3, 9, 6, 0
  3. Select region using ENTER (9 = multi-region)
  4. Close the disc tray
  5. Power off
Toshiba SD3109
  2. Insert foreign DVD
  3. Close the disc tray
  4. Press STOP before the error message is displayed
  5. Press "T" twice
  6. Enter a time of one second
  7. Press PLAY
Toshiba SD43HK
  1. Turn on the player (without a disc inserted)
  2. Press ENTER
  3. Press 8, 4, 2, 6, 9
  4. Press ENTER
  5. If the player doesn't turn off automatically, turn it off
Toshiba 23HLV84 / SD-24 VLSL / D-KR2 / D-R1 / D-R2 / D-R255 / D-R4 / D-VR30 / D-VR4 / MD13N1 / MD13N3 / MD13P3 / MD14FN1 / MD20FM1 / MD20FN1 / MD20FP1 / MD20P1 / MD9DM1 / MD9DP1 / MW20FM1 / MW20FN1 / MW20FP1 / MW20FP3 / MW24FM1 / MW24FN3 / MW24FP3 / RD-X2 / RD-XS34 / RDXS30 / RDXS32 / RDXS52 / RSTX20 / RSTX60 / SD1008 / SD100X / SD106E / SD114E / SD1209 / SD1209 / SD114E / SD1209 / SD1300 / SD130E / SD1402 / SD140E / SD145E / SD1850 / SD1900 / SD2006 / SD2008 / SD2108 / SD214E / SD22VE / SD22VL / SD245 / SD248E / SD24VB / SD250E / SD2600 / SD2650 / SD2710 / SD2715 / SD2805 / SD2810 / SD2815 / SD2850 / SD320V / SD324ES / SD34VL / SD35VF / SD36VESE / SD3860 / SD400V / SD412V / SD4205 / SD44HK / SD4960 / SD500E / SD5205T / SD5907 / SD5915 / SD5980 / SD6915 / SD9100 / SDH400 / SDK200 / SDK220 / SDK330 / SDK350 / SDK530 / SDK730 / SDK740 / SDK750 / SDP1000 / SDP1400 / SDP1500 / SDP1600 / SDP2500 / SDP2600 / SDV290 / SDV291 / SDV390 / SDV391 / SDV395 / SDV396 / SDV593 / SDV65HT / VTD1420 / VTD1431 / VTW2185
Dec 17, 2016 | Toshiba Televison & Video
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
I lost my disc for Brother Fax 210C. Can I get
Hello
I put it on my website for you not know what the windows version Please let us know.
I have put the software driver for you on my website you can download it from there all you got to do is click on the link I put for you, it may take time to download for you depending on the speed of your internet all the best.
Click Link= http://www.4all2sell.com/driver/Brother-MFC-210C.exe
When download save it to your desktop so you can find it easy and then just double click on the icon and follow the instructions.
All I ask is to call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
All files on my website are only there foe a limited time.
Mar 08, 2010 | Brother MFC 210C All-In-One InkJet Printer
Sony Portable Cd/DVD Player DVP-FX810, "loading", "check disc"
Hey Teddybearman, I have exactly the same problem as you have. Did you manage to find out how to fix it?
Regards,
Seqdarsca
19 July 2010
Jun 07, 2009 | Sony DVP-FX810 Portable DVD Player
Audiovox D1998 portable DVD player will no long read disc.
This of course may not be the exact same thing, but mine did the same thing. Sounding like it was loading, but in fact pressing the open button it I could see the disc not spining at all (normally you would.) With the power off of course. I took all the bottom screws out (where ever the arrow points to a screw) including to the display. There is one ribbon cable easily disconnected. I lifted the mount the DVD sits on and reseated it. I put a disc in it, turned on the power and the disc turned. Great I thought. I reconnect the cable, put the screws back in - and its working.
Apr 22, 2009 | Audiovox D1917
Atapi dh20a4p problem
OK... see if this:
Toshiba Satellite Pro C50 Laptop Optical DVD Drive Bezel Assembly K000888950 will work for you?
See eBay: 272402441049
$20 NEW ~ Including shipping from Denver.
The ONE thing that does bother me about this Auction is the word "BEZEL"... is it just the BEZEL without the actual drive? Please MESSAGE the seller and ask!
Final note: Be VERY careful about DVD Drives that are listed as "NEW" (other) ... MOST times that decodes to USED!
Anthony
Toshiba Satellite Pro C50 Laptop Optical DVD Drive Bezel Assembly...
Nov 01, 2017 | Toshiba (K000816870) for Satellite 1100,...
Toshiba 32'' Model 32HLV66 DVD/TV Combo - DVD won't play
you must do a optical head cleaning on the unit, could be the optical lens was dirty thats why it can't read any disc inserted.
you Lens cleaner for CD & CD-ROM player
With Voice instruction (English), Music and Automatic stop
Scientifically designed, easy to use and keeps your player's sound at optimum condition
Nov 23, 2008 | Toshiba MD13N3 13 in. TV/DVD Combo
No picture
I gave up on the cheap Coby unit and upgraded to a more expensive toshiba one.
Sep 07, 2008 | Coby DVD-224 DVD Player
Dvd video player
Your DVD player is having a problem reading the disc. This is what is accounting for the pausing and the slow loading times...especially if it plays other movies without hitches. Even if the DVD is cleaned, some scratching on the disc will prevent it from being viewed properly. Blockbuster shoudl give you another disc to try of the same movie if you ask. Also, you can try getting a cleaner for your DVD player to remove dust and help it read discs better.
Dec 26, 2007 | Toshiba SD-3980 DVD Player
Toshiba dvd player - SD-1200
Its actually in the troubleshooting manual. Pg 126. Try putting in the disk with the label face up, that might work too,
regards
Jim
Dec 22, 2007 | Toshiba SD-1200 DVD Player
Toshiba SD-2800 DVD Player Logo
463 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
