Question about AOpen AX4SPB-UN (91.8AT10.013) Motherboard
Wont post led 3 flashes
When i turn on the tower the power light comes on and there is another red light flashing it will send power to the moniter for about 3 secons and send the moniter back into stand by wot could the problem be
  • sarahandmike Sep 07, 2009
    its on the mainboard and its called led 3 and it does not post
  • 43 Answers
If its the red flashing light on the tower, its the hard drive activity light.
when the monitor goes on stand by, does the tower retain power? (green light on and flashing red light sometimes?) Does your keyboard's scroll lock/num lock/caps lock keys and keyboard lights work?
Posted on Sep 07, 2009
2 Suggested Answers
  • 19 Answers
SOURCE: red light flashing when turnign on board
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. via
adfsdfs11
Posted on Sep 08, 2009
When I turn on the tv it beeps 4 times then the power button light will flash 3 times in a row but the power will not come on it just keeps flashing 3 times
power will not come on Linda, could be bad capacitors or cracked/bad solder joint,bad main logic board.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Samsung TV won turn on blinking red light explained fix 18
Sony Bravia TV kdl red blinking led light error codes solutions
Apr 02, 2016 | Televison & Video
PT54DL50
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
My sony wont turn on the red light keeps flashing
Need to check all your switches and connections.
The Red led indicated and device function problem and you need to respond with the sequence of flashes. ( Example 1 long and two short. or Flashes 3 times ? )
Let me know if the fan is running and the age of the power supply.
May 07, 2014 | Sony KF 50SX200U Compatible TV Lamp
It works intermittenly
3) The LED turns on or flashes red during initial boot up :
When the temperature inside the car is too high or too low, the red LED flashes. In this case,
follow the steps below.
Turn the product power off and ventilate the car to return to normal ambient temperature.
Turn the power on after a little while and observe the LED color.
If the red LED still flashes under normal temperature, contact customer service.
Ref: Plenio VXA3000 Users Manual Pg 5/6 1-4 Troubleshooting
DVSSynchrome_VXA-3000_UserManual.pdf
Download Files At MS Skydrive Email jeffreydrescher@Bellsouth.net For
Login and Password
Dec 23, 2013 | Digital Video Systems Plenio VXA-3000 GPS...
Tv wont power on red light continuously flashes
Hi,you need to have the capacitors in the powersupply replaced
Oct 15, 2013 | Samsung UN46D6400 46 Inch 3D 1080p Smart...
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
My xbox 360
Call Microsoft and send it back or go to www.llama.com to get the parts and instructions to fix it yourself.
Aug 22, 2008 | Microsoft Xbox 360 Console
AOpen AX4SPB-UN (91.8AT10.013) Motherboard Logo
807 people viewed this question
Top AOpen Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Iqbal Husain
Iqbal Husain
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
