Question about Olivetti JP 192 InkJet Printer
Paper not pick - Olivetti JP 192 InkJet Printer
    Genius:
  • 1,689 Answers
One way to resolve this is clean your pickup rollers, this is the rubber roller where the paper enters the printer.
Posted on Sep 07, 2009
Printer wont pick up paper even though the paper tray is full
There probably is a small piece of paper stuck in the paper path. Please take the ink/toner out of the machine and check the paper path. Please turn off the machine before doing this.
Jul 09, 2015 | Office Equipment & Supplies
Hp officejet pro l7780 all in one printer, Cleaned the pick up roller still not picking up paper
The pick up roller may be worn and in need of replacement. The slight grinding noise is the pickup roller trying to work but slipping
Oct 30, 2012 | HP Office Equipment & Supplies
I have a Laserjet p4014dn printer. it warms normally but once it picks up paper, it jams. i have dried clearing jam several times but on starting to print it jams
Three areas you need to check.1.Pick up area: While pick up roller picking up the paper,delay pick or no pick causes paper jam..
2.Registration assembly area: Once paper picked from the tray, paper leading edge registered by the paper sensor located under the registration assembly.. In case this sensor dusty malfunction or flag damage, paper wont sense. result paper damage..
3.Fusing area. If the paper travels up to fuser area, check paper jammed before entering in fuser(Teflon not rotating properly, replace teflon sleeve) or just crossed?(check paper sensors in fuser unit, clean the sensors & check flags,flag springs.
Aug 31, 2012 | HP P4014DN Laserjet Printer
PAPER NOT RECIVE
Paper not picking up?..shoot print command and observe printer trying to grabbing the paper?..see any marks on paper leading edge? Remove cartridge and see inside paper pick up roller,might be its dusty or warn out, remove the pick up roller releasing the side locks, clean with wet cloth, fix it back then try once, if its success..end the process.. if not replace pick up roller..observe similar kind of machine: 2_4_2012_9_32_43_am.gif2_4_2012_9_33_08_am.jpg
Feb 04, 2012 | HP LaserJet M1005 Printer
IF PAPER HAS NOT JAMED BUT MACHINE ARE SHOW PAPER JAMED
Try cleaning the rubber paper feed rollers. If it fails to pick up the paper in a pre determined time it will show paper jam. The pick up tires must pick up paper when turning, if not the paper will not feed into the machine and it will show paper jam with no jammed paper.
Mar 16, 2011 | Canon imageRUNNER 400S Copier
Paper is not being picked - giving Jan message. I have changed paper to Lazer type whilst frequency has reduced there is still an issue. Machine is about 18 months old.
Can you hear the machine trying to pick up the paper?
Normaly its a paper feed roller that gets dirty.
But if the machine does not attempt to pick up the paper, the problem may be a paper sensor
Feb 10, 2011 | Office Equipment & Supplies
Printer does not attempt to pick up paper but gives out of paper message and or flashing paper sign on panel
steps:
(a) driving a pickup roller, picking up printing paper stacked in a paper cassette, and then, feeding the picked up printing paper to an image forming unit
(b) after picking up the printing paper in step (a), checking to determine whether or not the printing paper has been fed to the image forming unit(c) when it has been determined in step (b) that the printing paper has not been fed and a paper feed error has been generated, again driving the pickup roller, so as to attempt to pick up the printing paper stacked in the paper cassette again.
Apr 21, 2010 | HP Officejet Pro K5400 All-In-One InkJet...
The printer will not pick the paper from the lower tray. It tries to pick the paper from the upper tray even though it is set to auto pick the source but will not pick from the lower tray.
Hello, just clear paper pick up roller.
Open front cover, remove toner cartridge and you will find paper pick up...use wet cloth or alcohol to clear it... Good luck!
Oct 29, 2009 | HP LaserJet 1020 Printer
Unexpected message: 6B22
That is a pre heater fault.
Preheater exit sensor in unexpected state during fault.
Preheater exit sensor in unexpected state during stage.
  1. Check system grounds.
  2. Check the Drum Maintenance Kit NVRAM contacts during oiling for continuity.
  3. Check the waste tray.
  4. Replace the Preheater ( REP 2.0.17).
B2M
B2N
B2P
B2Q
The preheat flag tripped unexpectedly while picking paper from Tray 2.
The preheat flag tripped unexpectedly while picking paper from Tray 3.
The preheat flag tripped unexpectedly while picking paper from Tray 4.
The preheat flag tripped unexpectedly while picking paper from Tray 1.
  1. Test the Preheater Sensor using Service Diagnostics.
  2. Check system grounds.
B3M
B3N
B3P
B3Q
B3S
B3T
The preheat flag timed out waiting for the paper picked from Tray 2.
The preheat flag timed out waiting for the paper picked from Tray 3.
The preheat flag timed out waiting for the paper picked from Tray 4.
The preheat flag timed out waiting for the paper picked from Tray 1.
Preheater sensor timed out during stage.
Apr 17, 2008 | Xerox Phaser 8200 Laser Printer
My Laser Panasonic Fax won't pick up papers when sending faxes
There is a sensor in paper tray .u will see just its lever at the other end of lever there is a sensor .i think it is dirty .just clean it properly.now when u will put paper u will listen beep.now sensor is working .fails to pick up mean that fax try to pick paper but not pick the paper .there is a ruler justclean it with cloth and some licquid.and properly check this ruler is movi ng or not moving.
Nov 16, 2007 | Panasonic KX-FL521 Plain Paper Laser Fax
Olivetti JP 192 InkJet Printer Logo
53 people viewed this question
Top Olivetti Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you an Olivetti Office Equipment and Supply Expert? Answer questions, earn points and help others
