Question about Dell Inspiron 6400 Notebook
Dell D630LCD inverter error, unable to turn lamp ON/OFF.
Hello, I'm hoping somone can help me.
I have Dell Lat. D630 and I get the follwoing error:
Error Code: 0326
Msg: 2000-0326
Msg Description: LCD Inverter Error, Unable to turn lamp on
The computer locks up and I can't do anything, screen becomes pixely and blurd, then locks and I have to pull the battery to resart. This happnens every day, once I reboot, it works for a littel while then repeats. Any ideas?
Thank you
Tim
  • tpenziner Sep 07, 2009
    Yes, I have th prblem w/ an external monitor as well. Is the graphics card on the Dell D630 part of the mother board? Thanks
    Sergeant:
  • 338 Answers
the interal graphics adaptor is making trouble, to find aóut if it just with your screen, hook up another external monitor and boot up.
Still the problem?
then you wil have to (let) the graphics card (be) replace(d), definitely.
Good luck
Posted on Sep 07, 2009
Dell error code 0326
Error Code 0326 means LCD inverter error, unable to turn lamp ON/OFF.
  • Update to the latest BIOS.
  • Turn off your computer and reconnect your LCD cable.
  • Repeat the diagnostics by turning your laptop on and tapping F12 and selecting diagnostics
  • if you still get that error then it could be these parts LCD cable+LCD needs replaced
Jun 16, 2014 | Dell Inspiron 1525 Notebook
I need a video card for my dell lat d630 and it has been up graded to win7 and missing alot of files how do i fix
Hi Melissa,
You can download the drivers for your Latitude D630 from the following website:
http://go4download.com/dell-latitude-d630-drivers/
Feb 03, 2013 | Dell Latitude D 630 D 640 D 520...
D630 lcd screen
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Dec 04, 2012 | Dell Latitude D630 Notebook
D630 screen is black once it starts up it illuminates but stays black
You must detect what parts is failure
Screen display, inverter board or lamp
Follow these step.
1.- Connect an external monitor (at VGA port) and check the image in external monitor
If show clear image. The failure may be the inverter board or the lamp backlight
Inverter boars is more easy to replace.
You can buy an used cheap price on
http://www.ebay.com/itm/Dell-Latitude-D630-Inverter-Board-K021048-00-/260809995144?pt=LH_DefaultDomain_0&hash=item3cb97cb388
Replace and your screen will work again
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Dell Latitude D630 PC Notebook
My son's 1525 Dell laptop screen is blank. I hooked it up to a External monitor and ran diags. I received a Error Code 0326 MSG: Error Code 2000-0326 MSG: LCD inverter unable to turn lamp off....
Yep, basically what it means is the ic on the board is shot. Order a new board. Or a complete lcd as it comes with the driver , The choice is yours and its up to you..!!
Apr 27, 2011 | Computers & Internet
This is a hardware issue. Unless you know much about soddering boards do not attempt to fix this yourself.
Jan 22, 2010 | Dell OptiPlex GX270 PC Desktop
Avision AV8350??? the error led is on, first time the led on & off For 8 number Sequence. then on for ever.
When you first turn the scanner back on, the READY light will blink, indicating that the diagnostics are in progress. If the Ready LED and Paper Jam LED blink 8 times, the error indication is "Light Check Fail (ADF)" or "Flatbed /ADF inverter check error".
Followings are the solution for the above problem:
1. Lamp is on? Yes. CCD error, Optical assembly is to be replaced.
2. Lamp is on? No. Flatbed or ADF Inverter error. Lamp inverter circuit is to be replaced.
3. Lamp is on? Yes. Issue resolved.
4. If the Lamp is still off, then Lamp is to be replaced.
5. If the issue still persists, then you may have to contact the authorized Avision Service personnel for further diagnosis and suggested repair or replacement.
Hope the above information is helpful.
Please revert if you have any doubt.
Thank you for contacting FixYa.
Regards,
TechSatya
Jan 16, 2010 | Avision AV 8350 Flatbed Scanner
My Dell Inspirion6400 screen wont come on. I attached it to an external monitor, and it came up with the error code:0326 LCD Inverter Error, unable to turn lamp on. If I replace the LCD inverter, will...
Check out http://www.ccfldirect.com. they have a wide variety of inverters and backlight tubes for LCD panels and laptops. I'd change out the tubes at the same time you replace the inverter. The cost is minimal, and will increase the likelihood that you'll be successful
Jul 13, 2009 | Dell Inspiron 6400 Notebook
Error accessing the lcd inventer
The error code 2000-032 (LCD Inverter error, unable to turn lamp ON/OFF) sounds like your LCD screen has a problem and needs to be replaced. The inverter circuit is located on a small circuit board on the LCD display panel. You can try reseating the LCD connector and see if this helps. Here’s a link to the service manual: http://supportapj.dell.com/support/edocs/systems/ins6400/en/sm/display.htm#wp1022270
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 26, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
3,286 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
