Question about Briel Domus Due Espresso Machine & Coffee Maker
Where can I get spare parts for briel domus due
I need a replacement gasket for the brew head/heater. There is no doubt that this is where the water is leaking from. Any advise on where to get spares from the UK,and best way to fit it would be gratefully received.Thanks
3 Suggested Answers
  • 37 Answers
SOURCE: Spares for Briel Coffee Machine
You can obtain any part at:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Nov 20, 2008
SOURCE: Spares
Try these people
I got a new basket from them for about $6
Electra-Craft, Inc 41 Woodbine Street Bergenfield, NJ 07621 201 439 1700
Posted on Jan 17, 2009
I need a printable manual
yes, they make it pretty hard to find but I eventually found it on the Breil website, this covers several machines including the Domus Due:
http://www.brielbg.com/pdf_instrukcii/004.pdf
Jan 15, 2012 | Briel Domus Due Espresso Machine & Coffee...
Cleaning oils from briel domus
Yes, every pump driven machine has an over pressure discharge.
Jun 18, 2009 | Briel Domus Due Espresso Machine & Coffee...
Manual Briel ES161atb
Don't know about replacement parts but instruction manual can be downloaded from the website in PDF file.
Jun 13, 2009 | Briel Domus Due Espresso Machine & Coffee...
LEAKING DOMUS DUE
such tools can be purchased at Ace, Lowe's or homedepot.  I had to purchase one to get into my tivo and the hardest part is getting the right size.  you might try taking an impression of the screw with clay or by a rubbing with pencil and paper..
Jan 17, 2009 | Briel Domus Due Espresso Machine & Coffee...
While making espreso, the machine leaks water from underneith.
Please email me with your request and I will send you info to fix it.
irene@smithagy.net
it is basically info on removing coffee oils from the Brew Head Screen.
if that does not work you can contact the service center at phone 201-439-1700 or email:
Thank you.
Nov 17, 2008 | Briel Domus Due Espresso Machine & Coffee...
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Nov 12, 2008 | Briel Domus Due Espresso Machine & Coffee...
Spares
Try these people
Aug 27, 2008 | Briel Domus Due Espresso Machine & Coffee...
Espresso maker not workin properly
Your Brew Head screen and/or filter basket might be clogged with coffee oils. You can soak both pieces in a product that removes coffee oils from either www.urnex.com or Dezcal brand. Coffee shops will do this once a day. If you have the filter basket with the screw in the middle, you will need to remove the screw and soak everything as it can clog also.
If that does not work (it should tho) you can contact the Briel service center at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Jan 05, 2008 | Briel Domus Due Espresso Machine & Coffee...
Leaks From Filter Gasket
Sounds like you might have coffee oil build up. I would suggest soaking the Brew Head Screen and filter holder in a coffee oil remover by www.urnex.com or dezcal. Remove the screw if your filter basket has one. For home use it would be good to clean this every week or so. You can email me for more info: irene@smithagy.net. You also might just try purchasing a new filter basket (along with cleaning the Brew head screen and new basket).
Further technical info can be found at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Dec 20, 2007 | Briel Domus Due Espresso Machine & Coffee...
Espresso Machine
Possibly, if it is leaking from the bottom only, and if you have a Domus Due model, you might just need a new water reservoir as the water reservoirs are a different system than all of the other briel machines and a new reservoir will usually fix the problem of leaking on the bottom in the Domus Due machines. Something with the seal on the reservoir.
You can order just a water reservoir by contacting the service center at:
Electra-Craft
41 Woodbine St
ph 201-439-1700
If your machine is leaking over the filter handle, brew head etc, that could be the coffee oils have built up in the Brew Head Screen and/or filter basket itself. For that, remove the Brew Head Screen and soak along with the Filter Basket in a coffee oil remover (not descaler) you can get the Cafiza powder at www.urnex.com or any other brand and then use a brush to clean it after soaking. If you have the Briel filter basket with a screw in the middle, please remove the screw and clean in there as it tends to get clogged. Then just be sure not to screw it too tight again as this can cause leaking.
I hope the info was helpful.
Apr 16, 2007 | Briel Domus Due Espresso Machine & Coffee...
Briel Domus Due Espresso Machine & Coffee Maker Logo
634 people viewed this question
Top Briel Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Henry  Thomas
Henry Thomas
Are you a Briel Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
