My washing machine tripped the main fuse box I reset it and now my machine won't work, all the lights are on but it won't do anything. any advice please.
  • 35 Answers
Is the machine getting proper voltage--120VAC? Need voltmeter to check while machine powered on. If so try unplugging for 30 secs or so and replug. If not working probably bad control board.
Posted on Sep 19, 2009
How do I open washing machine door
check mains going into mechine
Feb 27, 2015 | Miele Washing Machines
Washing machine wont work
If it's more than 6 years old, it's time for a new one. Or maybe you blew out your fuses. Try resetting the fuse box and switch off and on. Then after you switch back the power, go and try to turn on washing machine again.
Feb 13, 2015 | Washing Machines
Trip switch cuts out when i use washing machine
Main board power circuit fault.disconnect main PCB and reconnect power cable .you can identify the fault. Replace main pcb.
Sep 01, 2014 | Indesit Washing Machines
Why is my washing machine tripping my main fuse box even when I change the plug socket
by "tripping main fuse" do you mean the high amp (eg 60 amp or 100 amp) fuse that feeds the whole fuse box? if that is the case, there is too much stuff on in your house that's drawing power. The fuse box is too small to power all the stuff you have plugged in and running. Suggest turning off other high draw appliances in the house, like large TVs or microwaves or air conditioners, when running the washing machine.
Nov 18, 2013 | Washing Machines
My washing machine kkeps tripping my fuse box
This is related to a fault in the main control panel, it is possible there is a short if the fuse keeps tripping off. You need to remove plug and pull out the panel to check for short in the power supply to the main control panel usually a SMPS unit. Use a multimeter to check for short, if so this must be replaced.
check for tips from the link below:
http://www.espares.co.uk/advice/washing-machines/a/7/1298/how-to-replace-washing-machine-controls-hotpo.html
Apr 30, 2012 | Hoover Nextra HNF 3157 Front Load Washer
I have a washer kemore 600 series, it pumps water in but will not do anything else. Is there a reset button on the motor or pump?
Hello there and welcome to fixya
If your washer doesn't seem to work at all, check these:
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? try to unplug for 15 min then reset the home breakeer than plug in the machine again and try Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. To determine if the lid switch has failed, watch the part testing video . at repair clinic.com Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse. or it will fill but will stop after that
Sep 12, 2011 | Kenmore 600 3.5 cu. ft. Top Load 110-2962...
Indesit washing machine WIXE127 switches off main fuse
Have you added anything else that is drawing juice on the same breaker?
If so try turning those off.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Jan 31, 2009 | Indesit WA 125 Front Load Washer
Turn washer dryer on ok, then close door then curcuit trips
check the wiring and make sure nothing metal is on the motor because your dryer has a short in it somewhere
Dec 23, 2008 | Hotpoint Ariston Aquarius WD420 Front Load...
Washing Machines Logo
128 people viewed this question
Top Washing Machines Experts
