Question about Frigidaire FRS23R4A Side by Side Refrigerator
Amana side by side
Water that comes from any foset is clear and also from the ref. But when I take ice cubes and put them in the water all kinds of white particles come out of the ice and float around. I even changed the filter and flushed the system for ten minutes. I still get the particles.
  • 4,066 Answers
Undissolved minerals can appear when ice cubes are added to chilled drinking water. Freezing tap water causes dissolved minerals to solidify and scatter, giving a cloudy appearance. When ice cubes melt, any undissolved minerals settle to the bottom. These mineral compounds in our drinking water are naturally occurring and safe.
Sometimes we see black particles which can be the non-stick surface of the ice mold flaking off.
Posted on Sep 07, 2009
  • Frigidaire Master
  • 4,654 Answers
To answer your question is going to take research and the process of elimination. Here are some of the reports from home owners, professionals and people just like you and I.
Today my wife filled her clear plastic water bottle with cool water from
the dispenser on the front of the refrigerator door and ice from the automatic ice maker. Some hours later when she went to drink it she noticed a large number of small white flakes in the water, kind of like snowflakes, not to gross you out but to give you some size perspective, like dandruff suspended in water. The flakes appear to be slightly heavier than water since they will suspend if the water is agitated but will settle slowly to the bottom eventually. I get similar white flakes when using ice cube trays filled with tap water in southern California. Given the hardness of the local water, I think they're just mineral deposits that form into flakes when the ice has had a chance to sit and evaporate/sublimate for awhile. Does the ice in your ice maker sit for a while (sometimes a few days will do it) before it gets used? Maybe you can try cleaning out the whole ice maker, wiping it down with a mild vinegar or soap solution, then see if the fresh ice has the same flakes in it. Also, if the water for the ice maker is going through your old filter,(your is new now) and if the filter is the kind that removes minerals from the water, replacing the filter might solve the problem. We sometimes have dark flecks in our ice. I think it's breakdown of the lining of the ice maker. I'm not sure but I suspect that the ice maker is lined with a nonstick surface to let the ice slip out more easily. Some believe some sort of mineral condensation. Ice cubes freeze from the outside in. Ice is formed from pure water (hydrogen and oxygen) therefore the minerals such as calcium and magnesium normally found in the water sometimes end up as visible particulates in the core of the ice cube. The white particles are not toxic. And some people even say that to claim this is happening that digital photos of this happening is worth more than a thousand words. I would also like more input from you or anyone that has this problem so I can add this Q&A to our forum and here at Fixya
We depend on you the customer.
We have heard ( from forum comments ) a number of complaints recently that the chemicals used in water treatment facilities are causing the material the water reservoirs are made from to break down and particles appearing as white flakes in the dispensed water. In that case, replacing the reservoir is usually necessary.
Water contamination cases have made it necessary for treatment plants to improve the water quality.
Most manufacturers originally used a molded plastic water reservoir which is what seems to be breaking down. Many fridge manufacturers are now selling a coil of plastic tubing (like used in the rest of the water system) in place of the molded plastic reservoir. You can see some of the replacement kits at the following link:
Whirlpool fridge water reservoir replacement kit
Frigidaire water reservoir replacement kit
Maytag water reservoir tube kit
It is unknown at the moment if GE has gone to one of these tubing kits but you can see an original molded plastic water reservoir that is used on GE refrigerators at the following link
General Electric fridge water reservoir
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
SEA BREEZ TIP's
NO ICE FROM ICE MAKER
You have a bad water valve or the fill tube where the water comes into the ice maker is frozen full of ice. Check the second problem first then if the fill tube is clear the valve needs to be replaced.
Apr 25, 2012 | Amana Refrigerators
My ice maker in my side by side refrig/freezer leaks water so that a solid block of ice is formed in the tray maker. This prevents dispensing of cubes. What can I do?.
The cause of that is the water inlet valve is not fully closing but instaed its staying open a little and seeping water through it all the time which is dripping into the storage bin for the icemaker and freezing all the ice into one huge block. To repair that the water inlet valve on the back of the ref. where the house water supply line attaches to would need to be replaced.
GENE
Sep 22, 2011 | Amana Refrigerators
Amana ice maker clicking - still makes ice just really slow
level the refrigerator. i/m not level causing it to jamb and cause low ice production
Aug 25, 2009 | Amana 25.8 cu. ft. Side-by-Side...
Water does not reach ice tray, ice maker appears to be cycling
Pull the filltube from out of the back check for ice inside, use warm water to melt.
Mar 12, 2009 | Amana 22.6 cu. ft. Side-By-Side...
My amana sise by side fridge wont drop the ice
hi thanks for the question probably have a problem with ice maker the timer in ice maker is not advancing to the drop off cycle need a new ice maker thanks the appliance doc
Jul 03, 2008 | Amana 22.6 cu. ft. Side-By-Side...
11 year old amana frig icemaker
you most likely have a short in the ice maker ..the ice should be ejected before the water is call for... you need a new ice make or if you can change the ice maker head let me know and I can help
Jun 27, 2008 | Amana SXD524VW Side by Side Refrigerator
Kemore
i bought a ice make fridge and hook it up but there is no water come up from ice water foset can somebody help
Feb 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice Maker not bringing in water
Not sure what u mean my supply valve.. that would be in back.. never seen one freeze... check the water vave in back... thats where icemaker water is supplied from.. check for continity or make test wire and put power to valve and see if water makes it to the icemaker.. only need to power for few seconds
Sep 02, 2007 | Amana ACD2232HR Side by Side Refrigerator
No water for ice maker
make sure wire is in down position this is like the on and wire up is off
Jul 14, 2007 | GALAXY Microsystems 25.4 cu. ft....
Frigidaire FRS23R4A Side by Side Refrigerator Logo
407 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
