Question about Iridium X- PC Desktop
Iridium Starbook 710 (amd) Notebook
Can anyone help with a problem with the above notebook, It seems the power-point where the lead plugs in is in need of a solder,but to get to it is a bit of a nightmare as it means taken most of the notebook apart has anyone got or know where to get a manuel for the said notebook, or should I just get into it and fix it
  • 749 Answers
If one of your hobby if to fix things including electronic stuffs... well, I guess you can fix it on your own... just remember to arrange and remember where those screws and parts are supposed to be... then use at least 30W soldering gun or soldering iron and a "lead" to fix those connectors..
good luck!!! ;)
Posted on Dec 09, 2007
How do I upgrade an AMD Phenom II x3 710
I suspect you mean the Motherboard that has the AMD Phenom II x3 710.
If so then find specifications on that motherboard to see what better, faster? CPU is compatible with it.
4th Core is Disabled by AMD and you need to know how to enable it?
Maybe this can help.
Overclocking Phenom II x3 710 2 6GHz to 3 5GHz unlocking 4th core
Hope it helps
Oct 11, 2014 | AMD Computers & Internet
Hi everyone. I'm having an issue with my samsung
sounds like you need to change the 'power options' in the 'control panel'.
start--> control panel -->power options
or just use windows search for 'power options'
there are settings where you can change how it acts when plugged in vs on battery. There are usually options to lock brightness.
Sep 23, 2017 | Samsung NP535U3C-A01UK 33.8 cm 13.3inch...
What is the correct spark plug for a 2005 yz125?
hope this information helps these are Denso Plugs
YAMAHA
YEAR 2004-1999 ENGINE 125 cc APPLICATION INFORMATION STANDARD STK# 4049 STANDARD PLUG# W27ESR-V IRIDIUM POWER STK# 5317 IRIDIUM POWER PLUG# IW27 IRIDIUM RACING STK# 5714 IRIDIUM RACING PLUG# IW01-27 GAP 0.024
Apr 11, 2011 | 2004 Yamaha YZ 125
Firing order Datsun 710 (4cyl. L20B engine)
Remove the rocker cover.
Turn the engine until it's at TDC on No.1
Both No.1 rockers should be loose.
Remove distributor cap and look where rotor is pointing, this is No.1 plug lead.
Dec 23, 2009 | Datsun 720 Cars & Trucks
Finding it hard to put leads back on to motherboard to boot up
From the motherboard number you gave, I think it's made by ECS. Take a look at the picture on this page at the ECS site and see if it looks like your board:
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&DetailID=530&DetailName=Feature&MenuID=52&LanID=0
If it's the one you have, you can download the manual just by clicking the link below the picture. You can also get any other information and driver updates that you might need.
Please take a moment to give this solution a good rating if it's been helpful.
Mar 02, 2009 | Computers & Internet
HP Notebook not powering up
First, try powering the Notebook by pressing the Quickplay button as if the issue is with the Power Button, it should start.
You need to get the Power Button of the Notebook repaired if the Notebook starts by pressing the QuickPlay button.
However, if the issue is different and the notebook doesnot start by pressing the Quickplay button, I recommend you to try removing the RAM of the Notebook and try with One RAM stick at a time to boot the Notebook and also by checking the Memory sticks in both the Memory Slots.
You can find the required instructions to remove and replace the RAM modules in the Notebook from the Manual of the Notebook which is available through the link below :
http://h10032.www1.hp.com/ctg/Manual/c00737799.pdf
You can find the required instructions starting from page number 104 of 233 in the Manual.
However, if the issue persists, it can be a Hardware issue for which you may have to get it repaired.
Additionally, I would like to inform you that HP had identified some hardware issues with few Notebooks installed with AMD Processors and is providing free repairs for notebooks purchased and currently available in US and Canada.
You need to get the Product Number of the Notebook which is indicated with P/N and is printed on a white sticker pasted at the bottom of the Notebook.
Check if the Product Number of your Notebook is listed in the list available in the link below :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01300427
If your Notebook product Number is listed in the link provided above and if the Notebook is installed with AMD Processor, you need to contact HP Chat Support and provide the required details and get the Notebook repaired by HP for free.
You can find more information about this repair offered by HP from the link below :
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c01087277&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
You can contact HP Chat Support for DV6000 Notebooks preinstalled with AMD Processor by clicking on this Link.
Hope this helps...
Oct 31, 2008 | HP Pavilion dv6000z Notebook
Dv9000
First, get the Product Number of the Notebook which is printed on a white sticker and paste at the bottom of the Notebook indicated with P/N.
Now, check if the Product Number of your Notebook is listed in the weblink provided below or not:
NOTE : Notebooks that are installed with AMD Processors are only covered under the free service plan from HP.
If your Notebook Product Number is listed in the link provided above, you can get the Notebook repaired for free....
Find out more information about this free repair program offered by HP for few Notebooks installed with AMD Processors from the link below :
NOTE : Clicking on the link may give an error message. Copy entire link and paste it in the address bar of a new web browser and press Enter.
Hope this helps...
Oct 22, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion DV notebook wont boot up
First of all, if you are getting 1 short and 2 long beeps, the graphic card of the Notebook might have failed. Get the Notebook repaired by HP if under warranty.
However, if your Notebook is installed with AMD processor, it is having a known issue and can get it repaire for free if purchased in US and the related information is available from the link below :
I am sure that this information helps...
Aug 10, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Open Questions:
Protecting your data from ransomware • DataAlign Are you witnessing issues in your Toshiba laptop like your laptop isn't working since you installed an app, driver or update? Many Toshiba laptop and pc users report issues they face in their day to day life. Toshiba technical support is always available to help customers confront such situations and resolve issues for better working laptops and their longer productive lives. In case your Toshiba laptop is not letting you peacefully open the start menu or you are facing troubles installing any update or your newly installed update is not working the way it was supposed to then this article will help you in getting all the right answers for your issues. Toshiba support email is always available to help its customers at any time of the day and they even provide on-site support facilities. Toshiba support is provided by experienced and professional technicians who use industry authorized advanced technical tools and techniques to cater fully effective measures used to counter all possible issues that interrupt the productive working of Toshiba devices. In case you are facing issues in your Toshiba laptop you simply call our Toshiba laptop support , you can find out the cause of those issues by restarting your pc in the safe mode. Taking this option will remove all those apps, drivers and updates you have installed after the restore point was created but nothing will happen to your personal files. For using the restore point, you have to go to the control panel and type recovery in the search bar of control panel window. After that you have to choose the option of open system restore and click on next. You have to then select the most recent apps, drivers and update and click on the option of scan for affected programs. You can always contact Toshiba customer support using their toll-free helpline number +1888784-9316. They will provide on-site and on-line support assistance over the phone, email or chat. If restoring from the restore point doesn't help then you can reset your pc and wait for issues to get resolved. Resetting results in reinstalling of Windows after choosing which files you want to keep or remove. Resetting option is available in the settings menu. Under the sub section of update and security, there will be the option of recovery which will further have an option of reset this pc. For assistance in technical issues you can contact Toshiba customer care anytime.
Sep 26, 2018 | Toshiba Computers & Internet
See all Iridium X- PC Desktop Questions
Iridium X- PC Desktop Logo
149 people viewed this question
Top Iridium Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Iridium Computer and Internet Expert? Answer questions, earn points and help others
