Cant find how to remove the stand on our newly purchased Soniq QSL323CT1 anywhere in the manual. We are trying to mount it on the wall.
  • 601 Answers
1. Disconnect all cables.
2. Cover a level and stable surface with a thick and soft cloth.
3. Gently lay the TV, face down, onto the cloth. Make sure the Table-Top stand is hanging over the edge.
4. Rotate the cable holder 90 degrees, and pull it out completely.
5. Remove the screws (3 or 4 in rear next to cable holder, depending on which model wall-mount kit you have) being sure to hold the Table-Top-Stand firmly while removing the last screw.
6. Do not remove any other screws from the TV.
They also say not to remove the stand for any reason other than wall-mounting the TV. Their should be instructions with the wall-mount kit.
Hope this helps!
Thanks
Smith.
Posted on Sep 07, 2009
How do you take a stand off
There are 4 screws found in the center bottom of rear plastic back. 2 at top and 2 at bottom - approx 1/2 inch from bottom the 1st 2 will be about 3 inches apart - then directly above there are 2 more. These screws hold the bracket that holds the stand. Once you remove the bracket there should be no parts sticking out further than the actual television and can now be mounted to the wall with a mounting system.
Jul 20, 2014 | LG 42LH30 42 in. LCD TV
Could you please advise me how i can take the stand off my television so i can mount it on the wall??
hi there, swivel stand of the TV is all detachable by screws. try to locate them underneath or sometimes it is cover with rubber caps so it is not easily noticeable. if you remove the stand then you need to purchase a lcd wall mounted frame, I suggest the universal one for this is adjustable up to 42 inch LCD monitor. hope this helps please rate and vote.
Mar 30, 2011 | Televison & Video
I cant remove the base from the L42S10A soniq tv. i need to wall mount it but i cant seem to remove the circular base. how do i remove it
Hi. On the back panel just above the inputs and in the centre of the unit you will see 5 X phillips head screws (4 in a square pattern and 1 in the center of these). If you remove these screws completely the base will withdraw from the unit. Note that the washers will be a tight fit when removing and only just fit through the rear panel so use a magnetic driver or blue tack to help. Cheers. Slavious.
Aug 24, 2010 | Televison & Video
I have a Proton tv that was mounted in my motorhome on a wall mount. We have removed it from there and want to use it on a stand instead. Is there a generic stand we can purchase for that purpose since the...
Tries websites like Ebay.com,Amazon.com to dicuss with those vendors that sell LCD,Plasma tvs wall mounts and base stands,they'll help with the right choices with base stand.
Jul 07, 2010 | Televison & Video
Removing back stand supports
First I am not to sure about the brand you got there, But if it is not wall supportable you do not need to reove anything but by a wall mount that will hold the bottom in place and yes there are wall mounts for this tpye of arrangment see not all flat panels go on walls thus hence you cannot remove the stand easy. Try finding a wall mount the has a L shape to it, it will hold the bottom of the tv and it comes with a little strap to hold it back into securement. Please do not try to remove the stand I would suggest a diffrent wall mount- Rulds2008 TV expert for 20 years
May 14, 2009 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Monitor stand
I have one or two nice used Original ones available.
Where are you located ?
email bammbamm@ptd.net if you want pictures and costs
Mar 05, 2009 | Acer AL2017 20" LCD Monitor
Mounting to TV Stand
there are two types of stands, some are wall type which needs to be mounted using rawl bolts, nuts are suppose to hold a stand, some are ground stands which are suppose to be put on a flat surface in order to balance.
Jul 29, 2008 | Panasonic TH-50PZ77U 50" Class Plasma HDTV
Akai 32"
I just purchased this unit and briefly looked at removing the stand though I haven't taken it off yet. Anyways, I think you need to remove the black metal mounting frame from the TV before trying to unscrew the stand (4 screws) from the metal frame. After the frame is off the TV, I think you can then get at a couple of hidden screws to remove the stand from frame. I don't know if the frame goes back on the TV or not.
Dec 01, 2007 | Akai LCT3201AD 32 in. LCD Television
Broken stand
Another solution for this problem would be to by a wall mount and hang it on the wall. You can buy universal wall mounts almost anywhere.
Nov 17, 2007 | Protron PLTV-32 Television
Televison & Video Logo
242 people viewed this question
Top Televison & Video Experts
Electro Med Services...
