Question about Konica Minolta DiALTA Di200 Copier
How do u reset minolta copier im2520f CO5000 - Konica Minolta DiALTA Di200 Copier
  • Konica Minolta Master
  • 1,297 Answers
The CO 500 code is malfuction the fuser unit.Check the fuser heating lamp continuity and the fuser thermofuse and thermistor.
Posted on Sep 14, 2009
How to reset to factory default
Sir, reset what part like access code etc. Di450 series great machines rugged. Service mode Memory Clear?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 19, 2014 | Konica Minolta Minolta Di450 Di470 Di550...
Konica minolta bizhub c253
what is the question?
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Aug 21, 2014 | Konica Minolta Minolta Bizhub C253 Copier
Minolta Di 5520 code Solution C-13f5
Yes there are 2 soft switches...... left side is for trouble reset.
Remove fuser unit from copier
Reset code co05XX
The copier needs to give you a scree with wait for warm up; if not some thing else it's going on
If you get the wait for warm up ...eventually you'll get a C05XX code
Reset and test it with the fuser unit in.
Troubleshoot fuser unit in case you get another C05XX
Tom
Apr 09, 2014 | Minolta bizhub 250 Black and White Copier
Imagistics all in one copier/fax/scanner im2520f. All is working except the scanner which is giving error code EA21F7.
Try restarting your printer to see if the scanner lense moves properly and not jammed next you need to download the latest driver and suite from manufacturer`s website which shall definatly solve your problem.
Sep 30, 2013 | Pitney Bowes 460-4 Toner for Imagistics...
Minolta DI2510 Black and White Copier - Code reset minolta issues?
what code do you want to reset different code different reset procedures
Nov 22, 2011 | Minolta DI2510 Black and White Copier
Di151 All-In-One Laser Printer: Minolta Di151 copier. J2 Paper Jam Followed t...
Sensor may be bad, for that jam. cleaned the rollers?
also also mite need to replace the rollers for the draw try this ite you have alegacy Minolta machine Now Konica Minolta
May 15, 2010 | Minolta Di151 All-In-One Laser Printer
My Oce im2520f is giving me an error code: C0500. After about 3 minutes of giving me the error code, it beeps four times (long beeps) and then in shuts off. Anyone have any idea what it might be?
The C0500 error code is a fuser unit error code. The fusing unit is the part that gets hot and "fuses" the toner onto the paper just before it exits the machine. There is a special reset procedure for this code so as to prevent overheat of the fuser. You will need a service technician to diagnose the problem in the fuser and then reset the code. Most common causes are blown thermal fuse, bad thermister or rarely, a bad heater lamp.
Good Luck and Thank You for using Fixya.
Mar 19, 2010 | Office Equipment & Supplies
I am getting a C004A error on a Minolta 4000 copier.
Optical section fan motor failure.Change the fan motor.To reset open and close the front door or press the service reset button(placed in the left up side).
Oct 07, 2009 | Minolta Office Equipment & Supplies
MInolta Di 183
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Thanks.
Mar 25, 2009 | Minolta DiALTA Di183 Copier
Konica Minolta DiALTA Di200 Copier Logo
238 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
