Question about Imperial Kitchen Ranges
Induction cooker Error E5
I have a Neo Life Induction Cooker model no- 5349. When i turn on my induction cooker it is not detecting any vessel and showing E5 on the display. Error E5 is not available in my manual. What is this problem and how it can be resolved.
2 Suggested Answers
SOURCE: Vollrath induction cooker is not working. The display reads F9. Model # is 59500.
The range does not recognize the pan material. Only ferrous (magnetic) cookware will work with induction. This is a protection circuit to only heat proper cookware. When all else fails read the instruction book or call the service department for the manufacturer...save time, reduces frustration and assures safe operation. Good Luck
Posted on Nov 19, 2009
What should we do when the induction cooker appear E0?
Are you searching forInduction Cook-toperror codes? Here youcan find the error codesof all popular inductioncooktops and how totroubleshoot it. Theseare for your referenceonly, do not try to open your cooktop withoutproper safety measures, we advise you to call theservice person if any servicing is needed.
Error codes like E2, E0, E9, as we see in famous induction cookers like Pigeon, Prestige, Butterfly etc. are annoying at times, when we are in a hurry to go to office. Errors appear as numbers and finding it from the user manual will take days and leave us impatient. Here is a handy guide of induction cooker error codes usually seen in branded and un-branded induction cookers. You may save this page as pdf or as it is in your phone or PC for quick reference.
E0 -Cooking vessel is not placed correctly. Vessel is either removed or not made of a material usable with induction cooker.
Feb 03, 2017 | The Kitchen Appliances - Others
If induction cooker does not heat the pot
Induction-compatible cookware contains contains iron or has a layer with magnetic properties. Cast iron, enamel cast iron and most types of stainless steel cookware are all induction compatible (But not all types; for instance, All-Clad's MC2 line, which is made of aluminum and stainless steel, is not induction compatible)
Nov 25, 2014 | Winco Professional Induction Cooker -...
Induction is on but when i press start button than start and agin off
Check weather you are using correct size and material of vessel .some simple test is use a magnet to check right vessel.
Non magnetic material will not heat.
Nov 15, 2013 | Winco Professional Induction Cooker -...
Pressure cooker is not heated on induction cooker
Likely the pressure cooker base is not induction-compatible. This is the case with all aluminum pressure cookers and some older stainless steel models. Your cookware store will have a small metal plate that you can put on your induction burner to heat non-induction compatible cookware.
Nov 10, 2013 | Home
When have weight on induction cooker cooker can not cook
Remember that induction cookers are fussy that you have a special stainless steel pot or pan made just for induction cooking. It must be an 18/10 alloy (18% chromium and 10% nickel)
Oct 02, 2013 | Winco Professional Induction Cooker -...
Repair induction cooker
>> call a service agent with induction cooker experience
Sep 27, 2013 | GE Electric Induction Cooker
The induction cooker when put on it shows E6 after about a minute or so and no heating takes place.
There is a error message there, it indicate a problem with your induction cooker. It cause a defective winding wire or circuit controllers your know induction cooker works similar to the principle of electro magnet induction, it give heat to metal cooking pot. I hope I give you a idea regarding what happen to your unit.
Mar 23, 2011 | Microwave Ovens
I have a prestige Induction cooker... a new one. When I tried to turn it on for first time, it just shows "-- -- -- --". Post this, even after placing a induction cooker compatible vessel, it...
We have a Prestige Induction cook-top Model PIC 3.0. It gives the error "-- -- -- --" and a beep when the power is turned on. Can anybody help. My email is asbhambra@gmail.com
Mar 11, 2011 | Microwave Ovens
E1 and E4 error code desplay on the screen induction cooker. what is the fault in the induction cooker?
E0 error - ensure pot or pan is placed correctly
E1 error - the circuit has malfunctioned
E2 error - the temperature sensor is opening circuit or short circuit
E3 error - the voltage is higher (140 - 160V) for 3 seconds
E4 error - the voltage is lower (80 - 100V) for 3 seconds
E5 error - the cooktop surface temperature is too high
E6 error - Internal electronic temperature is higher than normal for 3 seconds
E7 error - Internal electronic temperature sensor is opening circuit or short circuit
Dec 12, 2010 | Stoves Heating & Cooling
Kitchen Ranges Logo
566 people viewed this question
Top Imperial Kitchen Ranges Experts
Dan Webster
Dan Webster
Thomas Perkins
Thomas Perkins
Are you an Imperial Kitchen Range Expert? Answer questions, earn points and help others
