Question about Canon PIXMA iX4000 InkJet Photo Printer
Error code my canon ix4000showing one error code 4 times one by one its blinking orange and green leds.
  • Gaius Schutzstaffel
    Gaius Schutzstaffel May 11, 2010
    It is a purge cam sensor error [5C00] solutions: purge unit(QM2-3370), Replace logic board assembly(QM2-3393/QM3-1654)
Howdo you fix an error message 5C00 on a Canon iP90 printer.
Try this to reset the error.
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Please rate this solution, thanks!
Mar 07, 2011 | Canon Office Equipment & Supplies
Error code 5100 check printer
This is probably a Canon printer and code. If so, it is the "ink waste pad is full" warning. There are work arounds to keep from having to clean the pad. Here are two methods to eliminate the message. The only other ways are to take it to a repair shop or dismantle the printer and clean the pad yourself. Not advised, This is messy.
This works on many different printers.
Waste ink full reset
These are the instructions which worked for me on my Canon pixma mp470:
mp150 and simular printers:
printer powered off but connected on power source , you must:
1. Press & hold stop/reset button, and then press & hold [ON/OFF] button.
2. When Green power lit, leave stop/reset button & press twice stop/reset (see orange indicator).
3. Leave On/Off button. Printer in actually service mode.
4. Press stop/reset 4 times (see orange indicator) if not blink restart above process from top.
5. After press stop/reset 4 times successful press On/Off button 3 times. printer will off.
6. Press On/Off button.
Jan 22, 2011 | Office Equipment & Supplies
What is error code 6500?
This is an error indicating a problem with the Logic Board Assembly. It's probably not worth fixing, with printer prices being fairly low.\
According to the MP800 Service Manual:
2-2. Service Call Errors (by Cyclic Blinking in Orange (Alarm LED) and Green (COPY button), or
Alarm LED Lit in Orange)
Service call errors are indicated by the number of cycles the Alarm LED and COPY button blink, and the corresponding error
code is displayed on the LCD.
*Cycles of blinking in orange (Alarm LED) and green (COPY button) - 20 times
*Other hardware error - Error
*Error Code - [6500]
*Conditions - The PCI bus error is detected by the ASIC.
*Solution (Replacement of listed parts, which are likely to be faulty) - Logic board ***'y
Aug 21, 2010 | Canon MP830 All-In-One Printer
LED light keeps blinking
That is a service error code, but you need to count how many blinks between the longer green blink, and that tells the error code...
Oct 13, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
I have a canon iP90 printer and a code is coming up 5C00?
If it still comes up with this error there might be some paper down near the print heads. If there is no paper there, you might have an actual hardware issue.
Aug 29, 2009 | Office Equipment & Supplies
Error 5100 canon ip90
You may try this to rest the 5100 error:
Dec 07, 2008 | Canon PIXMA iP90 InkJet Printer
I need to know what the error codes 5100, and 5700 mean, and what causes those errors to come up on the screen. Thank you
Try resetting the printer:
Jun 20, 2008 | Canon PIXMA iP90 InkJet Printer
Canon mp160 E2; printer won't re-set
hi dear
may the error code or how many blinking can solve your problem
this is the list of error code
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber
full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
try this methode
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
cropp
Feb 16, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon i70 LED
The problem is your wasted ink tank it either needs to be replaced or you need to reset the error code like this
Try This
3) While holding the Power button, press the Resume/Cancel button 3 times, and then release the Power and Resume/Cancel buttons.
green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
After the function (menu) is selected, press the Power button. The LED lights in green, and the
*** 4 times Green Waste ink counter resetting Both the main and borderless print waste ink counters are cleared.
Dec 18, 2007 | Canon BubbleJet i70 InkJet Photo Printer
Canon PIXMA iX4000 InkJet Photo Printer Logo
640 people viewed this question
old marine
old marine
