Question about Microsoft Windows XP Home Edition
Cannot open windows/system 32.exe and cannot delete old files
Now that im installing a program it says cannot access files verify that u have acces to that directory. But i dont know how i can make verification
  • 284 Answers
Are you logged in using an account with admin permissions?
Has this program been installed on your system before?
You may need to uninstall and install it again.
You must make sure that none of the files are in use.
Nothing I know of should ever try to access system files.
What is the program you are trying to install. Are you sure it does not contain a virus?
Posted on Sep 07, 2009
  • 378 Answers
Change the attribute of the said file. MAke it read/write instead of read only.
Emachine will not run anything
Rundll32.exe errors typically occur in response to the inability of Windows to access an application, program or file as the result of a corrupted or missing DLL (Dynamic Link Library) file or in response to a rundll32.exe virus that has been designed to look like a normal Windows process.
Here are the easiest ways to fix rundll32.exe errors.
Click "Ctrl + Alt + Delete" on your computer's keyboard to open the Task Manager window.
Click the "Processes" tab and search for a rundll32.exe program.
If one is running and appears to be accessing a lot of your system's resources, click "End Process" as it is likely a malicious program and not a true Windows program.
Run software to seek out, detain and remove viruses, malware, spyware and adware. Often these malicious programs corrupt DLL files or cause them to be deleted or moved and, as mentioned, some rundll32.exe programs may in fact be viruses on your system.
Reboot your computer to update any changes you may have made recently to your files and programs.
Many programs and applications require a reboot for successful installation.
Uninstall a recently installed or changed program or application and then reinstall it using the default settings.
An installed program may not have loaded properly, an installation via the Internet may have been interrupted enough to create errors or the program may have a bug.
If you uninstalled a program and see a rundll32.exe error, reinstall the program and then uninstall once more.
Retain the services of a Microsoft certified technician, if all else fails, to review and fix your system's Registry.
Dec 01, 2013 | E-Machines Computers & Internet
Wat is winlogon that appear in my desktop
The process "winlogon.exe" runs in the background.
Winlogon is a part of the Windows Login subsystem, and is necessary for user authorization and Windows activation checks. http://www.neuber.com/taskmanager/proces...
Note: The winlogon.exe file is located in the folder C:\Windows\System32. In other cases, winlogon.exe is a virus, spyware, trojan or worm! Check this with Security Task Manager."
Microsoft designed Windows so many small applications perform their tasks without a user knowing about it.
Normally, this will run smoothly and without flaw, but every once in a while, an issue can come up.
Winlogon.exe is an application that runs on start-up, and its primary function is to monitor the use of other applications.
Winlogon.exe typically only runs for about a minute or two when Windows first boots up, so if for some reason it is still running five or 10 minutes later, it could be infected.
Spyware and other malware would infect this application because it can manipulate other programs in Windows, causing problems.
If this is the case, the file might need to be removed.
if you want to remove this from
Open "My Computer" and select the "C:" drive.
Double click the "Windows" folder, then select "System 32." Navigate through the System 32 folder until you find "Winlogon.exe."
Click the "Winlogon.exe" file and hit "Delete." Select "Yes" when asked if you're sure you want to remove the program.
hope this helps
Sep 17, 2012 | Microsoft Windows XP Professional for PC
SysMech.exe Access violation
Please follow the steps below to perform a thorough uninstall and reinstall of your iolo product. Depending on which iolo product(s) you had, some of these items may not be present.
1. First uninstall anything from iolo from your system and restart the computer.
2. Right-click on the Windows Start button and select Explore.
3. Navigate to C:\Program Files and delete the iolo folder.
**If any of these folders state a file is in use, open your Windows Task Manager and end any iolo processes that are running and try again. Ultimately, Windows Safe Mode will allow all of the folders to be removed.
- Starting Windows in Safe Mode
http://www.iolo.com/customercare/kbarticle.aspx?ID=KBA-01932
4. Once the folders are removed, click on the Windows Start button, select Run, in the Open field type REGEDIT and click OK. This will open the registry editor.
5. Navigate to HKEY_CURRENT_USER, Software and delete the iolo key.
6. Navigate to HKEY_LOCAL_MACHINE, Software and delete the iolo key, should it exist.
7. Navigate to HKEY_LOCAL_MACHINE, Software, Microsoft, Windows, CurrentVersion and double-click on Uninstall.
8a. When it expands, look for any of the following items and delete them should they exist:
{BBD3F66B-1180-4785-B679-3F91572CD3B4}_is1
{78E33B36-2103-49FC-B058-8CF44B6E75FD}
System Mechanic_is1
System Mechanic Professional_is1
System Mechanic 6_is1
System Mechanic Professional 6_is1
System Mechanic 7_is1
System Mechanic Professional 7_is1
System Mechanic 8_is1
System Mechanic Professional 8_is1
DriveScrubber 3_is1
8b. Please also delete these two keys:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ioloSystemService
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ioloFileInfoList
9. Remove residual antivirus files
a. Right-click the task bar located at the bottom of your desktop and select Task Manager.
b. From the Windows Task Manager select the Processes tab.
c. Locate and click on the process named Dvpapi.exe to highlight it.
d. Click the End Process button, then click Yes to confirm.
e. Navigate to C:\program files\common files and right-click the folder named Authentium.
f. Click Delete, then click Yes to confirm.
g. Download and install the Microsoft cleanup utility. You can download this file from Microsoft’s web site at: http://download.microsoft.com/download/e/9/d/e9d80355-7ab4-45b8-80e8-983a48d5e1bd/msicuu2.exe
h. Run the utility by clicking Start>All Programs>Windows Installer Clean Up.
i. Highlight Authentium Antivirus SDK and click Remove. Click OK to confirm.
10. Close all open windows, restart the computer & re-download.
Regards
Apr 22, 2010 | Iolo Technologies System Mechanic: Windows
Cannot run application (*.exe)
what is the application?
It sounds like you are trying to run a Win 16 (Windows 3.x) program
Jul 26, 2009 | Dell Inspiron 1420 Notebook
Cannot delete unwanted *.exe & *.acc files
google for "star unlocker assistant" this program will unlock the folder so it can be deleted.
good luck
May 05, 2009 | HTC Tilt 8900 Smartphone
Problem with Run Program
It is probably a leftover problem from spyware or a virus.
Open Windows Explorer and go to C:\Windows\System32
Click Folder Options on the Tools menu.
Click the View tab
Select Show hidden files and folders, under Hidden files and folders
Now find cmd.com and delete it
Don't touch command.com, only cmd.com.
Check also for the file ping.com and delete it if it exists.
Warning: Don't delete cmd.exe and ping.exe only the files with .com extension. Be careful, because you are working with system files here.
Good luck
Please post some feedback or if you need more help
Apr 24, 2008 | Dell (04U621) for Latitude D600, Inspiron...
Funny UST scandal virus
first download taskiller in http://www.rsdsoft.com/task_killer/index.php4
and install it to
your computer because you cant use taskmanager to terminate the virus(the
virus automatically close taskmanager).
-run taskiller and left click it on the system tray(the one with a skull icon)
-click processes
-to close the virus, select process and click yes to the question
(process to close)
1.killer.exe
2.lsass.exe
3.smss.exe
note: close only file that have the same icon of Funny UST Scandal.avi.exe
CMD STEPS
1-now, click "start" then "run"
2-type "cmd" without quotes
3-type "cd\" without quotes
4-type "attrib -h -s smss.exe" without quotes
5-type "attrib -h -s autorun.inf" without quotes
6-type "start c:" without quotes(a new window will open)
7-select smss.exe,autorun.inf,Funny UST Scandal.avi.exe and delete it
-if theres any drive or a partition type "d:" in command prompt without quotes
"d" is the drive letter then repeat the CMD STEPS number 4-7 above.......
-now type this on the command prompt "cd windows" without quotes(na naman!)
-type "attrib -h -s smss.exe" without quotes(uli)
-type "start c:\windows" without quotes(hay naku!)
-delete the file smss.exe
-now, goto c:\documents and settings\all users\startmenu\programs\startup
-delete lsass.exe
-click "start" then "run"
-type "regedit" without quotes then delete the registry entries above....
Note:
If you have problems opening drives in My Computer open regedit find
"\smss.exe" then erase values like: "c:\smss.exe", "d:\smss.exe" etc..
Hope this helps
Jan 16, 2008 | Computer Associates eTrust PestPatrol...
Printer
A support tech at Canon suggested I try this.
find the file ImageCache.ic - I found it in application data folder in My Documents, delete it.
Uninstall CD Label Print, search for any other "CD Label Print" files or folders and delete them too.
Re-boot and re-install CD Label Print.
This worked for me. Hope it works for you too.
Cheers
OM
Dec 30, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
