Question about Sony KP-43T90 43" Rear Projection Television
Hue red on a double image
Why this red hue on a double image screen? what is the solution eventhough I tried to adjust it but did not work. how much to fix it?
Thanks
Mark
    Brigadier General:
  • 4,090 Answers
Lots! the convergence chip and some capacitors are involved as well as some tuning inside the set. The projected cost is about $300 to $500 depending on travel distance and the company you use So contact a Sony se4rvice centre and get an aproximate quote
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Posted on Sep 07, 2009
What is the perfect amount of red,blue,and yellow hue for the screen
that's got t o do with personnel preference and room lighting , but as a general rule adjust color hue's till the edges of a white color object on screen has just lost its primary color edge
the older projection TV's actually have voltage numbers for the service tech to adjust them too , but im not remembering seeing any in the LCD manuals
Mar 29, 2016 | Element Electronics FLX3210 32 in. LCD TV
Screen has a red hue
adjust it through the settings menu.
go to color, hue settings.
Nov 13, 2013 | Dell Televison & Video
Sony KP-57WS510 Red Hue to screen.
Misaligned grey scale adjustment. Do a white balance adjustment, after entering its service mode. Contact the authorized service center of any experienced service technician. http://elektrotricks.blogspot.com/
http://electrotechnician.blogspot.com/
http://homenol.blogspot.com/
Please visit these sites to get some details.
Jun 15, 2017 | Sony KP-57WS510 57" Rear Projection HDTV
Double image on my Sony KP 43t90
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Feb 22, 2009 | Sony KP-43T90 43" Rear Projection...
Color off seems amber
Double check the wb settings in camera, (and be sure to check WB Shift) I'd suggest adding a Blue shift to your images to compensate for the Amber until you find something thats a decent trade off, if you can't eliminate the amber shift.
Dec 14, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Blurred TV - double vision with red hue
I was searching online about what could be the problem with our TV and I came across your page. We have a 52" JVC Projection TV that now has a "blurred" screen. We can see the channels but it looks like it's has a shadow around the images. The screen in in a red hue with green blur.
If you have any suggestions on what caused this and what we can do to have this fixed, I would greatly appreciate your advice.
Sep 07, 2008 | JVC AV-56WP74 56" Rear Projection...
Red Bowed Lines / Red Hue
I tried the solution that was posted for this problem and it worked!
Just remove the Low front panel by removing the two bottom screws that are covered by two screw covers, then remove the second panel (black) by removing the 4 screws then you'll notice a module with 6 adjustment knobs, get a small screw driver, and with the t.v. on, being carefull , and with somebody accross the room looking at the screen begin with the lower left knob and turn left very slowly and ask the person across the room to let you know if the screen is better or not, after this I had to adjust the green as well so, I adjusted the next knob over to the left. Do this adjustment carefully and try to remenber the original position of the knobs in case you have to go back.f
Good Luck,
Californian.
Jun 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Red color appears missing from display
Push your red component cable firmly in the tv and the cablebox and you will be good to go.
Thanks
Josh
Mar 23, 2008 | Akai LCT3785TA 37 in. LCD HDTV
I have 47 inch with double color in picture, reds and green
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
convergence amp ic bad
Oct 14, 2007 | Samsung HCL552W 55" Rear Projection...
Sony KP-43T90 43" Rear Projection Television Logo
236 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
