Question about Miele Touchtronic G892 Built-in Dishwasher
Miele Touchtronic G892 SC Water leak at base of door
Hello, We have a two year old Miele G892 SC Touchtronic which out of the blue started to leak water at the base of the door near the bottom and also at the lower right hand side of the door.
    Sergeant:
    Champion:
  • 362 Answers
Check the rubber seal around the door to see if its torn or smashed. if it is replace it, could someone have set somthing heavy on the door while it was open that would have stressed the hinges. it is most likely one of these problems take a nail file and slid it gently between the door and the body of the dishwasher if it slides in easy where it leaks you know the seal is bad and replace it.
Posted on Dec 09, 2007
Miele G892 dishwasher stopped working. No lights at all. There is power from the outlet to the block behind the kick plate. According to manufacturer, there should be lights even with the door open so this...
This seems to be a failure of the main program controller unit.It needs to be confirmed that the unit received power, if so the controller is faulty.
Check if there is any fuse , check if there is line break to the unit.
Mar 12, 2011 | Miele Touchtronic G892 Built-in Dishwasher
My Miele G892 SC Touchtronic dishwaser is leaving a powder soap scum over all the dishes. What do I do?
Make sure you have at least 125 degrees going into the unit. If your using detergent power make sure you don't over use rise aid. Many brands have rise aid already.
Hope that helps!
Dec 11, 2010 | Miele Dishwashers
Help ! I own a Miele Touchtronic W1113. I put to0 much Zero liquid soap , using cold water . Now the machine flashes " Fault " for intake and drain . I opened the trap door and let the water drain over...
Sounds like you may have flooded the base of the unit and activated the float switch. Tip the unit forward slightly with a towel at the base and all the water will pour out. You should be right to run the unit after that and any other water inside will dry up. it won't rust as it is stainless steel inside.
Feb 15, 2010 | Miele Touchtronic W1113 Washing Machine
It leaks from the left side when washing dishes
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
dddg
Nov 22, 2009 | Miele Touchtronic G892 Built-in Dishwasher
Do you have a meile g892 dishwasher?
Yes,
a G892SC - for over 6 years now. It's so quiet that many a time I've opened the door to put something in it, only to discover it'd been running (rinsing, etc., not drying!) the whole time! Despite 3 years in the Army and lots of Rock concerts, I have no hearing loss ;-)
One year ago, the little orange plastic detergent lid latch broke. And considering how well-made the rest of the unit is, it was not as robust as the rest of the DW. I Emailed Miele, and they sent out a repairman who replaced the entire soap unit on the door for FREE, even though it was well out of warranty. You pay more, and you get more.
Brad Wolff
Dec 15, 2008 | Miele Touchtronic G892 Built-in Dishwasher
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
check drain pump impelar is free, it can be found under the non-return valve below filter. also make sure drain hose and S trap is clear.
Mar 29, 2008 | Miele 24 in. G638 Plus Free-standing...
Miele G892 SC dishwasher not heating/cycle won't stop
Miele have cold inlet only. Either element is open circuit, or the relay that switches the element has failed. My money would be on the element first, then the relay. The machine will sit in that mode forever as it is waiting for the temperature of the water to reach a certain temp before telling the electronic unit to move to the next part of the wash. If you need assistance in how to test & how to get to these parts just let me know. But you will need an ohm meter to test the element. Regards
Aug 20, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Dishwasher ran with wrong soap
add some salt in the cabinet and a bit of water. salt acts as a foam suppressant
Feb 18, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Miele Touchtronic G892 Built-in Dishwasher Logo
1,245 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
