Question about Epson Stylus CX4800 All-In-One InkJet Printer
Satuarated pad in epson 8400 how to replace it
Does anyone know how to replace saturated pad for the epson cx 8400 or reset the printer
EPSON R545 waste ink saturated
You need to reset your printer. Goolgle search for "indoreset for rx595" and download it. That is the program you need to use to reset the waste ink pad counter back to zero.
Jul 20, 2010 | Epson Office Equipment & Supplies
Waste Ink Pad Saturated
Will have to go in for service, no one sells the waste ink cartridges or pads. Had this problem with a HP printer i had. HP said i need to send it in and they swapped out the full part and sent back cost something like 20$.
Jun 23, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Ny epsom r360 reads ink pads saturated
don't replace the ink pads install a external waste ink tank instead, then reset the printer using reset program . . search on eBay for epson waste ink tank it incudes the reset program.
Jun 07, 2009 | Epson Stylus Photo R320 InkJet Printer
Epson cx 8400
Start, Click Printers & Faxes. Right Click EPSON CX 8400.. Find & Click Printing Preferences. Select the Paper Size (Choose what printing size you want). GOOD LUCK!
Pls! Don't forget to rate me.
Mar 04, 2009 | Epson CX8400 All-In-One InkJet Printer
EPSON r360
Are you sure it is staurated or it just the printer showing the error. Apparently there is a usage timer in the printer firmware that will display this error after so many hours of usage. Epson has a small program to reset this error but warns that if the pad is saturated it may leak out onto you table/desk. My R220 displayed this error and I reset it with Epsons resetter program. If you are not sure of the pad, I would put something under the printer just in case it is saturated and leaks. I don't think you can buy replacement pads from Epson as they say the printer is disposable. I also don't know what material the pads are made of but I have never seen one overflo in all the years I have used Epson printers. There is always a first time so if I were resetting mine I would defininately put something under the printer to watch for leaking ink. The program to reset the ink counter is EpsonIPRUtility.A10.exe and is available at www.Epson.com
Lou
Aug 23, 2008 | Epson PictureMate (C11C556001) InkJet...
Saturated ink pads
You need to reset counter, see my other post, use GEM link, should suit r310
http://www.fixya.com/support/t311089-epson_printer_parts_end_life
Dec 25, 2007 | Epson Stylus Photo R320 InkJet Printer
Rx650 chip reset and ink replacement pads
No crack for 650.
Suite 20, Level 3, 1060 Hay St, West Perth WA 6005 is Epson W.A. or any epson dealer can fix.
Dec 24, 2007 | Epson Stylus RX650 All-In-One Printer
Pad Saturated
The machine counts every dot it prints and estimates when pads should be cleaned then it shutdown to prevent spillage, athough you've cleaned the pads the machine needs to be reset by being connected to Epson's Eagle Download, which they have made very secure from the anyone but Epson agents.
Dec 11, 2007 | Epson Stylus Photo 925 InkJet Printer
Epson Stylus CX4800 All-In-One InkJet Printer Logo
118 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
