Question about Ricoh Aficio 450 Copier
Parts and consumable of afficio 450
Hi....Im from Philippines, can any1 help me wer can i purchase the parts and consumable of afficio 450. dat has a cheaper price hir in philippines.......
  • thraser
    thraser Sep 18, 2009
    My problem is wer can i purchase consumable and parts of afficio 450... Consumable...drum,cblade,transfer cblade,developer,toner,transfer belt...etc.
  • Adorjani Laszlo May 11, 2010
    Please specify your problem.I have a parts manual.
  • 541 Answers
Send your parts requests to our website and we sill sell them to you auburntechnology.com
Posted on Sep 26, 2009
  • 143 Answers
Http://www.ricoh.com.ph/support/contact.html
Posted on Sep 07, 2009
How to calibrate the dv and toner...afficio 450.or gestetner 3245
Hello sir; Just follow the steps;
1, dump entire dv use vaccunm cleaner to cleanup don't leave any dv inside.
2, thorughly clean out magnet roller by rubbing alcohal.
3, pour in new dv evenly.
4.Do simulation 2801 & 2805, the procedure as follow;
press"clear mode", "107", press and hold "clear/stop" key for 3 seconds, then press 1 for copier sp then enter2801 press start, after that go to 2805. same procedure. Let me know the resolve.
Mar 02, 2009 | Ricoh Aficio 450 Copier
Afficio 450 olridy change developer but the copy is stil faded
There are two service codes that you need to run 2801 and 2805 after you put the developer in the machine.
Press the yellow button on the copier. press 107 on the keyboard. Press and hold the clear button. Then run the service codes.
You have to run the codes first after changing the developer. You might have to replace the developer again to get the correct mixture.
Jan 26, 2009 | Ricoh Aficio 450 Copier
Afficio 450 copy faded in some area...
If the image is good in parts, but light in others it is most often toner build up on the laser exposure glass which can be easily -but also VERY CAREFULLYremoved. If you lift the green handle for the toner bottle, you should see a narrow piece of glass protruding just underneath. You can grasp it with you fingers and slide it out for cleaning. Sometimes these have been removed (or broken) so they are not there. If the machine is also a printer, you should see much improvement (if this was the cause). If regular copying is still light in areas, then you may want to remove the copier glass - 2 screws on left scale, and 3 screws on rear scale (POWER OFF ON MACHINE), remove glass and clean with glass cleaner, then slide scanner to the left and clean the mirrors.
Hope this helps.
Jan 17, 2009 | Ricoh Aficio 450 Copier
Afficio 450 sc 322
1st laser synchronization error.  This should be looked at by a Ricoh technician to see what needs to be replaced.
Sep 11, 2008 | Office Equipment & Supplies
Copier.... afficio 450 vs konica 7025
You're talking about two really old machines, the 450 from 1998 & the 7025 from 2000.
Both are about the same class, but I'd give the edge to Ricoh since it was also sold under a number of other brands & replacement parts are readily available.
Hope this helps...
Sep 10, 2008 | Office Equipment & Supplies
Afficio 450 programs....
You have to have all the firmware in order to able to do that. It comes on a PCMCIA card that you plug into the copier. If you format the hard drive, there will be no way of getting the programs back unless you have that card.
There tough to get but I found a few of the cards on EBAY. Once you get that, then it's a matter of getting a hold of the software (if it isn't on the card already).
Aug 26, 2008 | Office Equipment & Supplies
Wer can i get service manual of afficio 450 free
http://www.ricoh-usa.com/downloads/manuals.asp?tsn=Ricoh-USA
The manual is in PDF format, however on the same page is a link to download the free acrobat reader if you don't have it so you can read this manual.
Please rate this solution and thank you for using Fix Ya!
Aug 21, 2008 | Office Equipment & Supplies
Afficio 450 camera lense alignment
You need a manual to calibrate the scanner do you have one?
There are some holes in the scanner that need to be calibrated with a tiny screwdriver. The manual teslls you the correct settings.
Did yiou remove the cable?
Aug 19, 2008 | Office Equipment & Supplies
Afficio 450
Goto to copytechnet.com. Someone can help you locate the error codes you are looking for. That one is supported by copier technicians.
Aug 05, 2008 | Ricoh Aficio 450 Copier
Fuser..?? afficio 450
The fuser probably will not help. I think you probably will need a PCU, and a service call.
Jul 20, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
142 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
