Question about Hotpoint Dishwashers
Dshwasher tablet wnt come ut and dshes very wet
Dshwasher tablet wont come out and dishes very wet
  • Hotpoint Master
  • 19,396 Answers
The detergent tablet dispenser door is energized by a solenoid wired directly to timer control board. The drawer will normally open releasing the tablet when the machine starts filling.
If the Drawer does not release the tablet, then either dispenser solenoid is faulty, or timer board mast be replaced.
If the machine is functional but does not release, then the technician will probably need to replace the detergent table dispenser solenoid, that often is built in with dispenser assembly.
You can call support ringing the number listed at the end of the owners manual.
Posted on Sep 07, 2009
On completion of cycle -dishes cold and v/wet.Tablet partially dissolved, dishes nearly clean!!
It is no longer heating the water. It could be a blown fuse on the heater circuit, or a failed temperature sensor, but more likely the heater element itself has failed.
Oct 17, 2015 | Dishwashers
Washed bsking dishes in dishwasher j had hotshot iin disher when i did wash of fishes we baked snd ate off dshes can we get sick?
If you are in any doubt about the ability to properly clean your dishes etc, then get an engineer to check it out.
You could always wash the dishes yourself?
Jul 21, 2014 | Dishwashers
I packed the dishwasher, switched it on the water was running in and after about a minute the tap symbol came on and the dshwasher kept going the for a a couple of hours with no dishes being washed. there...
Hi.
Its possible that water is entering the base of the machine below the washing chamber and therefore the machine thinks it is flooding so it tries to drain continuously and will not let the wash pump come on.
There are a lot of reasons why the base could be flooding ranging from a blocked delivery pipe to a faulty inlet valve.
Pull the machine forward. Remove left hand side cover and look into the base of the machine. If water is found then it is leaking there from somewhere. Then the fun begins finding how its getting there.
Might be a Technician job from there on.
Regards Sam
Sep 18, 2013 | Bosch 24 in. SHU43 Built-in Dishwasher
Not cleaning the dshes. Material lrft on dishes. Suspect poor water flow.
Fill with salt. Clean out all rotary arms. And put a dishwasher cleaner through. The rotary arms get blocked with lime scale.
Sep 16, 2012 | KitchenAid 24 in. KUDM25SH Built-in...
Hi. The dishwasher appears not to heat up all the time. The soap drawer does open, but open the tablet does not disolve. This leaves the dshwasher very cloudy and often still dirty. I have also noticed...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker
Mar 28, 2011 | AEG 24 in. Favorit 40850 Free-standing...
My bamboo pen wont move my arrow around anymore
I've had this issue; the software drivers that make your tablet work aren't installed. Go to Wacom's site (I've provided a link) to download the software for your tablet.
http://www.wacom.com/downloads/drivers.php
Jul 13, 2010 | Computers & Internet
KITCHENAID DISHWASHER WONT REPEATEDLY WONT RINSE DETERGENT OFF
Fist what detergent are you useing is it dishwasher detergent and second the dishes wet and stemy how long do you wait after the machine has completed the cycle before opening it
Jan 21, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Wont start
ok you said it has fire from the coil but no spark? pull a plug if it wet put in all new and use one to ck fire at plug wire end
Sep 23, 2008 | 1994 Volvo 850
Dishes are wet and the not drying
Try using just the rinse aid in the tablets, don't put anymore rinse aid in the dispenser(This may take a while for it to empty) this should help with the drying.
failing that look at manual that will tell you how to put the extra heat programme on
Deep Diver
Dec 22, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwashers Logo
361 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
