Question about Brother DCP-135C Flatbed Digital MFC All-In-One InkJet Printer
Can i put 200 gsm card in this printer it seems to not take it
I hv airtel sim card &Nokia Asha 200. but in my mobile mess nt sending showing mess center nd centre name..
contact your service provider.They have to give you their sms center number .They will guide you on the steps as to how to.
May 24, 2014 | Nokia ASHA 200 Dual Sim Gsm Unlocked...
I NEED THE UNLOCK CODE FOR A SPRINT HTC HERO 200
you can Unlock your HTC HERO 200 with imei unlock code. it is very simple and eaisiat way to unlock your HTC HERO 200 . get your HTC HERO 200 Imei Unlock Code . and use any gsm sim card.
i hope this will help you .
Oct 05, 2011 | HTC Hero Smartphone
I wish to use my HP Photosmart C8180 to print heavy weight cardstock... is there a setting that I can select to do this?
Step Three: Check the paper type Verify that only recommended paper is being used for printing. The recommended paper types and weights for most HP printers include:
  • Plain paper, 20 to 24 lb (75 to 90 gsm)
  • Legal size paper, 20 to 24 lb (75 to 90 gsm)
  • Card stock, up to a maximum of 110 lb (200 gsm)
  • Envelopes, 20 to 24 lb (75 to 90 gsm)
  • Photo paper, 145 lb (236 gsm)
NOTE: Supported paper weights and types vary by product. Check the Specifications sheet for your product for more information.
If you use card stock up to a maximum of 110lb then there should be no special mode to enter to print on this type of paper. Photo paper weighs in at 145 lb maximum which is heavier and can be printed on without selecting any special 'mode.'
Good luck on printing on heavy card stock.
Jan 21, 2011 | HP Photosmart C8180 InkJet Printer
The printer wont print on heavy paper is there a special setting i need to do
Paper types you can use:
Plain paper - 20 to 24 lb / 75 to 90 gsm
Photo paper - 6.5 to 12 mils (up to 290 gsm)
Card stock - 110 lb / 200 gsm, max
Envelopes - 20 to 24 lb / 75 to 90 gsm
Transparencies - inkjet variety with white stripe
Labels - all commercially available inkjet varieties on 8.5 x 11-in. or A4 sheets
There is no setting to allow printing of thicker paper stock.
For more information on your printer, please see the ESP 7250 All-in-One Printer Knowledge Center:
http://wwwcaen.kodak.com/global/en/service/products/ekn036791.jhtml?pq-path=2300285
Dec 20, 2010 | Kodak ESP 7250 All-in-One InkJet Printer
What is the meaning of cdma? is it normal sim card
In cellular service there are two main competing network technologies: Global System for Mobile Communications (GSM) and Code Division Multiple Access(CDMA). Cellular carriers including Sprint PCS, Cingular Wireless, Verizon and T-Mobile use one or the other. Understanding the difference between GSM and CDMA will allow you to choose a carrier that uses the preferable network technology for your needs.
for wiki answar http://en.wikipedia.org/wiki/Code_division_multiple_access
Aug 10, 2010 | Cell Phones
I want a print on card thickness paper , will a hp-5600 series print ?
Theoretically yes, but it's too close to limit. Try, but you have a 50% chances of paper blockage inside the unit.
Nov 29, 2009 | HP Officejet 5610 All-In-One InkJet...
What is the heaviest weight paper I can feed through my Office Pro 7680?
Aug 09, 2009 | Office Equipment & Supplies
Paper thickness allowed
Type Paper weight Input tray capacity Plain paper 70 to 90 gsm (20 to 24 lb) 100 Cards 200 gsm (110 lb) 20 Envelopes 75 to 90 gsm (20 to 24 lb) 10 Transparency film N/A 20 Labels N/A 20 10 x 15 cm (4 x 6 inches) Photo 236 gsm (145 lb) 20
Dec 27, 2008 | HP PSC 1315 All-In-One InkJet Printer
I have a F2100 three in one printer. What thickness paper is the best to use for making business cards. I have used 200 gsm and I think it is too thick. I also want to use my 1310 series printer for the...
I just use glossy cards from Avery. seems to do the best for me. not sure the thickness. I personally like thicker just cause I know cards get put in places they should then they have a better chance of survival in their life span haha.
Aug 02, 2008 | HP Office Equipment & Supplies
Paper; gsm
I'm not sure how this'll translate to your paper weight, but the printer is engineered to use 18-24 pound paper. You can safely run heavier paper through it using the MP tray and opening the rear face-up exit tray so the paper feeds straight through front-to-back with no U-turns. I personally don't recommend running anything heavier than a 65 pound paper, which is about as heavy as the cardboard they use when they package dress shirts. Let me know if that helps!
May 09, 2007 | HP LaserJet 4 plus Printer
Brother DCP-135C Flatbed Digital MFC All-In-One InkJet Printer Logo
182 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
