Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Non grass cutter
I have a ryobi rlt30ces and although it starts ,it doesnt cut grass,the head doesnt move
3 Suggested Answers
  • 72 Answers
SOURCE: Ryobi RLT30CES line trimmer head problem
Many small line trimmers lack a clutch system by design so this could be normal.
Posted on May 24, 2009
SOURCE: Model rlt30ces serial no 0811007404
Thanks found a distributor in Townsville
Posted on Nov 30, 2009
Ryobie 40 volt lithium cordless trimmer has string jammed under spool head. Now it has stopped working. Please send instructions on how to fix it myself. Thank you, have a good day.
Replacing string in Ryobi 40volt cordless weedwhacker Restringing Ryobi 40v Expand it TrimmerTry and remove bump nut on bottom of cutter head. Try and lift spool out, if it doesn't want to come out take a pair of small side cutters and start cutting string until the head is free. IGod luck
Jul 04, 2017 | Garden
Ryobi trimmer Rlt30CES head slow down under revs
Sounds like a drive shaft/clutch type problem, I do not know the machine but suspect it uses a flexible shaft to the head has this union worn out or at the motor end there would be some kind of clutch which would leave the motor spinning on tick over (not the head) then engage on rev up. Perhaps this is faulty or has oil on it, could be its flexible shaft has got a worn end.
On my old B&D it throws a sprung disc out under centrifugal force to engage with its drive shaft coupler which at low revs the springs "win" to disengage it.
Its head end is easier first to check by removal of its line holder after that things are more complex with mine four screws remove what I call its nose cone to get into the clutch area.
If there is a wear issue run it at a gentle speed dabbing its head into some grass you may find the motor spins on but its head stops which will confirm the above.
Hope this helps..........
Apr 28, 2017 | Ryobi Garden
My ryobi 30cc grass cutter model rtp 3000 runs but no power to cut gass
I have seen the flex cable broken between the power head and the cutter head .
Feb 20, 2016 | Stihl FS 85 Weed Eater
Ryobi line strimmer hedge cutter attachment won't cut even though the blades are moving can you give any idea what he problem might be?
grass,string or vines can get wound around the motors shaft, you will need to take off the spinning head to remove debris from motors shaft
Jul 25, 2014 | Ryobi Garden
Stihl strimmer engine runs but wont cut grass the head wont turn what cuts grass
First take the head off and look for grass, weeds and string wound up in there. A lot of times that's the problem.
Next, with the head off and the switch in the off position, pull it over a few times and see if the shaft spins. If not, could be a broken shaft or a bad clutch.
Apr 04, 2010 | Oregon Scientific Complete Carburetor for...
Nov 30, 2009 | Ryobi Garden
May 24, 2009 | Ryobi 15" Electric Factory Reconditioned...
Engine/shaft stopped working. Need to fix Ryobi trimmer.
Hi, I have a Ryobi brush cutter and the engine has a tendency to move up and down the shaft. It also rotates around the shaft
May 16, 2009 | Garden
Ryobi rlt30ces trimmer
Hi there, takes a bit of working out without a manual, but try this....take bottom half of trimmer line spool off, get piece of spool line approx 60 cm, long and thread through centre holes, ( bit fiddly but ) pull line through until you have equal length on both sides, dont try and wind it up onto the spool, just put ends of line through outside cover holes, then lock spool in place in other half. now simply wind the knob at the end and the line should retract into the spool., sounds complicated but really isnt, best regards and good luck, Philbee
Oct 24, 2008 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
186 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
