Question about LG Secret ? KF750 Cellular Phone
LG KF755c sends blank SMS's
All messages sent from phone are blank, won't even save in draft folder.
How do I make a draft sms message and save it. How do I then send it to someone?
To make draft messages on your phone..First go to message menu create message..Type message you want,after typing click OK button of yuor phone there are options that says save messages..To access that message ,go to the message menu choose draft or save message,select the message you want to send click OK and select edit then Click OK button of your phone select SEND then choose the number in your phonebook..Hope this helps..
Jun 20, 2011 | Cell Phones
My lg cookie is not sending messages or saving drafts!
Go to messages, settings and be sure you have selected the Message format text (not email, paging, ERMES), the expiration of the SMS to be set at maximum, SMS center set correctly ( operator provided number, should be like a phone number ).
Nov 02, 2010 | Cell Phones
My email are not delivered though yahoo says it has been sent. Any one can help?
hi this is kamal here to help u...
The message was never actually sent. Make sure you actually sent the message by checking in your Sent folder. Is it there? If not, you might not have sent it. Do you remember seeing the "Mail Sent" confirmation page that appears after clicking "Send"? It's a page that confirms your email message has been sent successfully.
The message was saved as a draft. Did you click "Save Draft" by accident? It's the button right next to "Send." Check to see if you saved a draft by clicking your Draft folder.
The message was not addressed properly. You might have accidentally entered a different email address than the one you intended, or entered a typo that actually turns out to be a real email address. Check to see if this happened by looking in your Sent folder. Take a close look at the address information. Did you write something weird?
The message was delayed. Most messages are delivered within a few minutes. But messages can sometimes be delayed while in transit due to heavy Internet traffic or routing problems. This kind of delay can last for several hours or more.
Other possibilities. Occasionally, interruptions or disruptions in email transmissions over the Internet render your message undeliverable. This is very rare, but it does happen. Unfortunately, aside from waiting, there is no way to know for certain whether a message has been delayed or whether it has been rendered undeliverable. The best solution is to re-send your message. You can find it in your Sent folder.
thanx for choosing fixya
regards
kamal singh
Oct 10, 2009 | Yahoo Mail
All the messages sent are blank upon receipt
Are these MMS messages?
If so contact your Network Service Provider to make sure the MMS service is activated on your number.
Ask your Network Server Provider to send you MMS settings OTA (Over the Air). These will come in the form of a text message so just follow the instructions accordingly.
Aug 31, 2009 | LG Secret ? KF750 Cellular Phone
My E71 can't send SMS but it can RECEIVE text messages. I have already tried the following: 1. Changed message center number 2. Changed SIM cards 3. Inquired with my network provider. I am enrolled on a...
Try the following steps. I fixed the same problem on my E71 with these.
1. move the sms which can not be sent into the draft box.
2. switch the phone to offline mode.
3. enter draft box, and send the sms
4. after the notification of "saving into sending box..", power off the phone.
5. turn on the phone again, select "no" for the question, then, wait several second, u can see the sms is sent.
Aug 16, 2009 | Nokia E71 Smartphone
Deleteing txt messages on a LG enV2
Hi, try this
Using the Internal Keypad 1. Open the flip and press[MENU]. 2. Press Messaging. 3. Press the Right Soft Key [Options]. l Press Erase Inbox to erase All (read and unread) Messages or Only read Messages in the Inbox. l Press Erase Sent to erase all unlocked messages stored in the Sent folder. l Press Erase Drafts to erase all unlocked messages stored in the Drafts folder. l Press Erase All to erase all messages from the Inbox, Sent, and Drafts folders (except locked messages). You can choose whether or not unread messages will be erased. 4. Select Yes to erase the messages selected. A confirmation message is displayed.
Mar 24, 2009 | Cell Phones
Texts go to outbox but are not sent
Had a similar problem myself (Sony Ericsson W890i) - just a plain old SMS message got 'queued' in the outbox, and all further messages I tried to send got sent to the outbox too without ever being sent.
What I did was delete all the messages that I could from the outbox (5 out of the 6 which had been 'queued'), and the one remaining message that I could not delete I cancelled, sent it to the Drafts folder, and then Saved it (to the SIM). I then switched off the phone, took out the SIM card, put it in my old Sony Ericsson handset, switched that on, went to the Messages folder and deleted this one troublesome SMS message from the 'Saved' sub folder. Replaced the SIM in my current handset, and sending messages thereafter was no problem. Hope it works for you too!
Dec 10, 2008 | Sony Ericsson Walkman W810i Cellular Phone
SMS Inbox Disappeared
Hello Brian, The SMS folder dissapears most probably because another program interferes with it. The same happens on some HP's with camera, where this options dissapears from menu because of some user installed programs. In your case, it doesn't have to be a SMS - messaging related program, there are some compatibility issues and programs that apparently doen't have anything to do with messaging are causing this. You should first try a master reset (hard reset) (save your data first). However in some cases this doesn't help, even if the program that's causing the problem is removed, and you will need a firmware rewrite/update. In order to perform this, or if you don't want to risk performing it yourself please contact me on the live assistance for step by step instuctions. Good luck, Bogdan.
May 10, 2007 | HP iPAQ h6315/h6365 Pocket PC
LG Secret ? KF750 Cellular Phone Logo
211 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
