Question about Sharp KB6024MK 1000 Watts Microwave Oven
Sharp Microwave oven model no R953M, I need a front control board the numbers of the board are FA657DR ZL 392 - 1 FA 129 can you supply and what would it cost
5 Suggested Answers
  • 184 Answers
SOURCE: Replacing lightbulb in Sharp R953M combi microwave oven
most microwave ovens built in the last 20 years do not have an
access panel to the light bulb. you must remove the screws on the back of the microwave that hold the outer sleeve in place.
Then pull upward and backward on the sleeve to disengage it
from the front lip of the chassis. the light bulb should be close to the front of the microwave behind the control panel. Some lights
are not unscrewable from the socket, but the socket and bulb
come as an assembly.
Posted on Mar 27, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: I have a Sharp R-930AK microwave oven. Not heating
That would be a problem with the secondary interlock (lower door switch) or its mount.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
You can order other parts from Encompass here or you can call them toll-free at 866-779-5835.
Posted on Jun 02, 2009
MicrowaveSvc
  • 9086 Answers
SOURCE: I need a manual for Sharp Microwave/ Convection R7A85
You can download that here free.
Posted on Aug 30, 2009
SOURCE: Does model, R 4A94 sharp carousel microwave oven have reset butto
I don't know of a reset button but there is a fuse that you have to remove the outer cover to get to that has a habit of blowing
Posted on Sep 01, 2010
Sharp carousel2 microwave convection model number r-8350 flashing but control panel won't work
Many parts for this model are long since no longer available, but many generic parts are available.
Chances are your control circuit board needs repair. After all these years, the electrolytic capacitors dry internally and that can cause bizarre symptoms.
I can repair your board, normally for $54.95, which includes insured return shipping, but if your membrane keypad is bad, it cannot be repaired.
For details and more free DIY and other help & advice, feel free to contact me directly.
Please include FULL model number*, FCC ID number*, + detailed symptom information.
* (on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 29, 2017 | Sharp Microwave Ovens
Model R1800 Sharp Microwave Looking for Sharp Carousel Convection Oven Control Panel Model R-1800
What are your sympotms? I repair those boards.
Feel free to contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
Nov 22, 2016 | Sharp Microwave Ovens
Sharp R 209KK-W number buttons
The keypad control board will probably need to be replaced, however the part alone will cost more than some microwave ovens.
May 26, 2012 | Sharp Microwave Ovens
MICROWAVE OVEN MODEL R-1405 THE INDICATOR NUMBERS ON FRONT PANEL DO NOT WORK WHAT DO I NEED TO FIX PROBLEM?
A faily common problem. You need a new display panel to fix that. The display panel comes separate from the control board.
Feb 12, 2011 | Sharp R-1405 / R-140 Microwave Oven
The led readout is not readable, the numbers are just partially lit
The control board needs replacing. The cost is usually 75 dollars and up just for the board. You can order it from your neighbourhood appliance parts store. Just give them: Manufacturer, Model, Serial no's.
Changing the board can take about an hour. It is an easilly replacable module.
Jan 20, 2010 | Sharp R-530ES Microwave Oven
Bought microwave but no manual...need to find out how to program each number pad for heating usuage
SHARP is not a hard one to get info for . try this web sight as they supply manual 's and also try googling sharp with your model # / and order one on line .. **** feed back pls ..
Dec 23, 2009 | Sharp R-23GT Microwave Oven
Display problem on Microwave/Convection Oven
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
http://www.microwavedisplay.com
Aug 07, 2009 | Sharp R-1502 Microwave Oven
The Display is Dim. Hard to read the numbers.
I have the same model and problem. The time display is totally unreadable. Looking for a solution as well. I suspect given the cost (I believe around $60), it's time for a new one. Anyone have any suggestions or easy repair ideas?
Mar 12, 2009 | Sharp R-314FS Microwave Oven
Sharp R953M combination microwave oven
No this lcd card is only a diffuser to even the light out over the display . The part you require is SH3816 Pcb display available from CIS £68.43.
Jun 16, 2008 | Microwave Ovens
Mar 26, 2008 | Microwave Ovens
Sharp KB6024MK 1000 Watts Microwave Oven Logo
345 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
