The front rubber seal on my zwf1220w is all filled with dirt
The front rubber seal on my zwf1220w is all filled with muck can i remove it for cleaning
  • 15,935 Answers
A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn't cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
Step 6--Removing the door. After you remove the three screws in Step 5, there is only one screw to remove in step 6 on my model. It was hidden behind a plastic cover that makes the hinge look pretty. You'll see on the inside of the door that two plastic prongs/tabs extend into holes in the hinge. If you push on them laterally and pull out, the tabs will pop out. Outside the door on the left side of the machine, you'll see the plastic cover that is connected to those plastic tabs and is hiding the hinge. On the outside cover piece, there is a flat tab that extends up into the plastic housing above it. If you gently pull the cover downward and out the whole plastic cover will come off revealing the one screw that needs to be removed to take the door off.
Step 7--Removing the Kick Panel. The middle screw is more difficult to reach than the sides. You may need an extension for your screwdriver and/or shims or a helper to prop up the washer while you remove the middle screw.
Step 8--Removing the washer casing. The step says to remove the screws and set the casing aside. My model (2005-ish) has wires connected to it. Rather than being able to remove it, it swings open like a door with the wires as the hinge. I simply used a box to prop up the outside part of the door so it did not sag and stress the wires.
Step 9--After you remove the old rubber bellow, you will likely see a lot of dirt, mold, and junk where the bellow was. Clean that stuff off with a cloth sprayed with a gentle cleanser before installing the new bellow. We replaced our bellow because of mold and mildew and bad smelling stuff. That dirt and junk is part of the problem. Clean it up before you install the new clean bellow.
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 15, 2010
Change The front suspension oil ring
u mean ooil seal, there are some great litle tols out, you slide a thin plastic plate into the seal between the seal and the stanchion, and slide it round the leg, it cleans all the muck out and save s the seal these do not often split it is a bit of muck that allo0ws seapage, if it needs a seal, a pain in the bottom, I do all my opwn but a pain
Oct 03, 2014 | Motorcycles
How to clean the seal on the door?
Whether it can or not white vinegar should clean it pretty from a spray bottle
Jul 26, 2014 | Whirlpool LHW0050PQ Front Load Washer
Zanussi zwf1220w
Pressure system fault probably
Jun 17, 2013 | Washing Machines
Lg washer leaving black greasy marks on clothes
This is usually to do with fabric softener. Dilute it with more water. The fabric softener makes clots, and these make the marks on your clothing.
Hope it helps
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | LG WM2077CW XL Front Load Stackable Washer...
Hotpoint Aquarius WF740 My washing is coming out with dirty marks and bits of slimy dirt. I wonder if it is from the door seal as this is dirty or could it be something else? I used the persil gel filled...
Your pipe to the water pump exit is probably blocked with bits of old fluff or missing sock, i found that the clothes had slimy bits on mine, i tilted it up and removed the rubber water exit pipe from under neath, cleaned out all the rubbish and works a treat now.
Oct 19, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Why does my magic chef refrigerator leak water on the floor
Could many problems causing this. From were is the leak, below the doors, that means the door seal is going bad, from under the fridge, it can mean the drip pan is full of dirt and muck. Pull her away from the wall and check the drip pan, some you can get to from the front some from the back. Under here is where all the stuff collects to muck things up. Get a Vac and clean her up, pull out the pan wash it off outside put it all back together, forget it about.
Jun 30, 2009 | Magic Chef (CSD2610KRW) Top Freezer...
Duet 6hw9150p leaks when i put a full load
Is the door seal dirty?
A dirty door seal can cause a leak. Remove and clean any dirt or deposits around the inner door seal with a damp cloth. The door glass seals against the rubber seal; dirt or deposits can prevent a proper seal and cause leaks.
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Continuously fills with water
You have dirt in your inlet valve (could be hot or cold) you will have to determine which valve is faulty and replace the valve, there will be dirt on a sealing face which is not worthwhile fixing the chances are you will make it worse. plus these are sometimes sealed units. turn off the power before removing any valves these could have a pernament neutral supply to them. one bolt and two pipes and it can be removed with the top off.
Aug 31, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Washer tub slowly fills with water
Is your problem a SLOW FILL problem, or a problem with WATER DRIPPING FROM THE RUBBER DOOR SEAL - or BOTH? If you have a slow fill problem, this is generally caused by a bad fill valve, which can be attributed to hard water deposits or well water mineral deposits. Sometimes the fill valve can be removed, cleaned and reinstalled, but most of the time a new fill valve is required. If you are experiencing water leaking from the rubber door seal (bellow), it may be time to replace it. Sometimes the seal can develop a wrinkle or crease where it meets the glass, which can cause leaks. Water dripping from the door when you open after washing a load is normal. Water dripping during a load is NOT. The bellow may also have started to rip or tear inside the door which may not be noticeable until you pull the folds of the bellow back and look underneath it. I hope this helps.
Jan 17, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
