Message reads:
F:\FingerVerify.exe "Only part of a ReadProcessMemory or
WriteProcessMemory request was completed."
The Public (L:) section [of the Wolverine, however, is accessible.
This error message appear when there is any kind of Hardware conflicts.
Open the Device Manager by typing the "devmgmt.msc" in the Run dialog box then select the Wolverine hard drive under the "Disk Drives" category.
Right click on the Wolverine hard drive then select "Properties". In the "Properties" window, click on the "Advanced" settings tab then check for the transfer mode and try changing the transfer mode.
Is this error message coming when you are trying to install software from disc? If yes, then try the following steps:
The Device Manager dialog box opens.
Warning
Do not change the Primary IDE Channel, Device 0, because this is
typically the system disk. Changing this transfer mode setting may
cause the computer to operate incorrectly or not at all.
First check in your fingureprint drive that writeprotection switch is not turn on .
Also cheeck jumper settings of drive and check that write or read protection is not set in jumper settings.
Also check drivers security rights.
Make sure you are enterd in computer operatign system with ADMIN RIGHTS.
Let me know if you need more assistanse.
Thanks.
I don't know where to find the "switches" you mentioned ...or the "jumper settings" you have mentioned. I also do not know the name of the manufacturer of the HD in the Wolverine.
I know not the location of the fixes described in the associated text. Can you help me with a clearer explanation than the one I have been previously given.
Thank you
The afore mentioned message comes when I try to ACCESS the secure section. It just refuses to give me the page wherein I am able to use the finger identifier OR the password. As I mentioned earlier, I DO have access to the non-secure side of the 4160 Wolverine
