Question about Baby Gear
Where cai I find the plastic foam (felizol) part
Where can I find the plastic foam (felizol) part inside the mazi cosi tobi car seat? When removing the cover, you see two white soft matelrial parts on each side. My daughter kind of took a small piece out of one of them...so I need to replace it...
  • 419 Answers
I would suggest that you contact Dorel (manufacturers of Maxi Cosi items) You can find their contact details at www.maxi-cosi.com
I hope this helps.
Posted on Sep 14, 2009
Is the maxi cosi combatible with a dodge grand caracvan
Hi Lisa
Please contact Maxi-Cosi customer care team USA & Canada for assistance - 380c2c95-927b-443b-80ce-6a556ec98186.jpg
Feb 09, 2014 | Maxi-Cosi Maxi Cosi Mico Infant Car Seat...
I need to clean a child's sickness from the base of my Toby. How do I seperate it?
Hi
It isn't recommended that you take apart the plastic shell of the carseat. You can remove the fabric from the carseat to wash it and then clean the shell with warm soapy water but it is not advisable to remove the harness or to take apart the factory seal of the shell.
Have a look at www.maxi-cosi.com and select the country you're in, then choose the Tobi carseat and select the instructions to view directions on how to remove the fabric.
Sep 24, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Maxi cosi tobi strap has jammed
It's not possible to loosen the belts of your Tobi?In this case you may need a repair of the quick-adjuster (the part where the buckle is attached to) or it may be appropriate to exchange the quick-adjuster.
Because this part is directly affecting the safety of the seat I would advise you not to try to repair it yourself; please visit a Maxi Cosi dealer to have it serviced.
I hope this helps.
Erwin de Raadwww.babycare.nl
Sep 20, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Washed the cover of maxi cosi tobi.... there are 2 springy things sticking up and don t know where they should be in the cover or on the seat.
If the springs are near where the childs shoulders would be, then these are supposed to attach inside the shoulder harness pads, you will notice that these make the harness spring open when you undo it.
Hope this helps.
Sep 02, 2011 | Maxi-Cosi 22371HFL Infant Car Seat
Need instructions for adjusting straps in maxi cosi tobi car seat also on how to remove covers to wash thanks tracy
Good Afternoon
Please visit www.maxi-cosi.com and select the country you're in, then select the Tobi carseat and download a replacement user manual which will have information on how to adjust straps and remove fabric.
Jul 13, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Pulled tensioner on maxi cosi tobi now i cant release it back
Just did it. It took two of us, but only a couple of minutes and no tools (except a table knife) once we'd worked out what the problem was. The reason the strap doesn't thread easily through the slot is that there is a sprung two-part mechanism that needs to be held open. One person threads the strap through while the other keeps the mechanism open.
Person 1:
1) Find the slot under the chair that the strap goes into - turn the seat upside down; it's a thin gap you can feel with your fingertip when you run your finger along the narrow back of the metal strip under the front of the seat (not the base).
2) Remove the metal rod that attaches the grey reclining lever. The rod is about 20 cm long and can be pushed out without tools. Removing this rod seems to make it easier to open the buckle mechanism. When replacing the rod later, you just have to line it up carefully with holes (we used a torch to help us see them)
3) Make sure the strap passes under the metal rod at the bottom of the seat back (you can see how here in a small photo here: http://www.englishforum.ch/attachments/sale-wanted/37565d1327058634-sale-maxi-cosi-tobi-car-seat-9mths-3-yrs-zh-maxi_cosi_tobu_small.jpg)
Person 2
4) Push back buckle as far as it will go (it goes back past vertical easily, then needs another firmer push,
5) Hold the buckle in this backwards position.
6) Insert a table knife (rounded and blunt, not sharp) into the space under the buckle and push back the sprung, hinged plastic part that the knife touches at the back.
7) Person 1 then threads the strap back through the slot, pushing until then end comes out.
8) Tie a knot in the end of the strap so you don't accidentally pull it through again!
9) Replace the metal rod in the reclining mechanism.
10) Done!
Mar 21, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Is it possible to purchase somewhere the white polystyrene inserts on around the headpiece of a maxi cosi toby? Many thanks. R
Good Evening
You can order the replacement polystyrene inserts via most authorised Maxi Cosi retailers or direct with our customer service department on 01284 413141 (Mon - Fri, 8:30 am to 4:30 pm)
Jan 08, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Maxi-cosi tobi strap tensioner not working. able to tighten straps when child is in seat but when buckle is pressed to release straps and get child out, unable to loosen straps tensioner will not let go.
Hi, Make sure that when you go to loosen the shoulder straps that the **** strap is pulled toward you, otherwise you cannot make the shoulder straps loosen, this is a safety feature. Hope this helps.
Jul 28, 2010 | Maxi-Cosi Baby Gear
How to alter the straps
how to adjust straps in maxi cosi tobi
Jun 16, 2010 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Maxi cosi tobi plastic part replacement
If you contact www.maxi-cosi.com you will be able to order this part.
I hope this helps.
Aug 17, 2009 | Maxi-Cosi Baby Gear
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
