Question about LG WD14311RD Front Load Washer / Dryer
Machine has water in it but screen says "OE" what can we do to get the machine working?
  • 68 Answers
Try cleaning the filter, it in the little door on the bottom left side. If its full of water water will drain out. onto the floor. Also it may be over balanced. Switch off, wait a couple of minutes, open the door and rearrange the washing.
Posted on Sep 07, 2009
My daewoo washin machine shows error code OE & it wont work actually whats the problem ? tq
Error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. Remove the suspected hoses and clean out. Replace and your good to go.
Nov 21, 2016 | Daewoo Washing Machines
How do i fix "OE"code.
if it is like my dishwasher the oe code means the unit is over filled with water. My dishwasher had a major fault that blew up a circuit board and had a faulty front assembly. Still in repair shop waiting for parts.. I would deduct that the washing machine is not emptying water so I think a water pump could be failing. My dishwasher was not activating the washer motor and came up with the same code but..
Apr 03, 2015 | LG WD-12126RD Front Load Washer / Dryer
LG washing machine error code OE. Pump runs but will not drain.
There is most likely a blockage between Pump and house drain pipe.
Oct 29, 2017 | Washing Machines
I have the error code OE showing up, and the water is not draining from the washer. What should I do?
OE - drain error - 5 minute time out drain time error. check your pump/filter for blockages. Clean out the trap from the bottom, something is jamming the drain motor.
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Jun 22, 2011 | LG WM-2277HW Front Load Washer
Washing machine 12401td front load-on its digital screen tells m
hello,
what this means is that
The "oe" is an error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
an also means indication that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
what you need to do to fix up this problem is to do what is call general clean up on it by unscrew the key (stroll) and then clean the dry and any form of water in then make sure that all wire are well connected to the position.
Good lock and thanks for using fixya.
Jun 03, 2010 | Washing Machines
My lg front load washing machine is reading oe
oe is drain error, which means that the machine is slow/or not emptying..Most likely you have to clean the pump filter...This is accessed via the small door at floor level..Unscrew the pump cover andclean the filter...Remember that any water will drain from the machine from here, unless the machine is empty...Leaning the machine back can help...Good luck...Nomess
May 20, 2010 | Washing Machines
LG WM-2032HW front loader washer gives error goes OE and IE
"OE" is really "DE"= drain error. Clean out filter behind access door on lower left corner front panel of machine. (there will be some water in machine)
"IE" = inlet error. machine took too long to fill. clean out inlet water screens where the hoses connect onto machine.
Oct 02, 2008 | LG Washing Machines
LG WD14311RD Front Load Washer / Dryer Logo
97 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
