Question about Tag Heuer Formula 1 CAC1111.BA0850 Wrist Watch
Second hand is stuck on 58
By undoing the bevel I can change the 1/10th hand and 1/100ths hand how do I move the second hand back to 0
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
Nov 06, 2012 | Swatch Diaphane Chronograph Blooded Silver...
Just had the battery replaced on my Wenger Swiss Army watch Model : 7987X/T. The red second needle is no longer moving.. its stuck on the 30 min mark. Watch works fine otherwise. Could not find any info...
If the second hand of your watch isn't moving, but the watch is otherwise keeping time, you most likely have one of two problems. The simpler to fix problem is that the second hand might have come loose from the post onto which it's been fitted. It's a simple friction fit, and a watch technician would simply remove the watch movement from the case and very (very!) gently push down on the seconds hand to re-seat it. If that's the problem, that's all there is to the repair.
A second potential cause for this behavior could be that a speck of dust or crud has gotten into the gears that operate the seconds hand, preventing it from moving. This can easily happen when changing a battery--many watches tend to get somewhat of a buildup of crud where the watch back meets the case. Especially with screw back cases, the process of loosening the back also loosens the crud layer, making it easy for little bits to fall in. If you do have crud in your movement, you're a bit limited in what you can do. Unlike old-time mechanical movements, very few quartz movements are made to be disassembled and cleaned. Instead, a watch repairer may be able to blow some air (not compressed air from a can--that will probably wreck your movement) to try to clear the gears. If that doesn't work, there is a little device that some watchmakers have that runs your watch at about 50 time as fast as normal. Spinning the gears like that can sometimes generate enough force to clear a blocked gear train. I have done this to resurrect several watches whose hands were stuck. However, I was still able to see the "pulse" of the second hand on those watches, even if the hand itself never moved forward.
May 16, 2011 | Watches
My new nixon 42 20 when i reset the chrono the second hand doesnt go back to zero it goes to 16 seconds past how do i sort this problem its annoying !
  • Undo & pull the crown all the way out,then
  • undo the adjuster button (the one underneath the crown)
  • push the stop/start adjust button one push at a time and it will move in slight increments,keep going till you get the second hand on the 12 mark
  • then push the top adjuster and it will go back to the 12 mark.
  • Push the crown in and wind your adjusting buttons up and you have finished
Aug 20, 2010 | Nixon 4220 PU Chrono Watch Black
Hi my Guess chronograpah 123503G1 keeps getting stuck. First it appeared that the hand on the small seconds dial face was stuck. The watch wwill not keep time while this was stuck. If I shake the watch...
mcdevito75 here, Sounds like your Guess watch neds some service, cleaning, oil etc. You can check with the repairservice directory right here at fixya, bottom of this page click on repair service directory then watches.
Aug 03, 2010 | Guess 17558L1 17558 Watch for Women
My Tag Heuer chronograph will not reset to zero.
Try the following, which I discovered by accident on my Tag Professional. Pull the crown out to the first position, and then you may find that successive pushes of the upper pushbutton will move one of the chrono hands by one division, and the lower pushbutton will move a different chrono hand. Similarly if you pull the crown out to the second position, the pushbuttons will control the other chrono hands. In this way you can set each of the chrono hands to their zero positions. Hope this works for you. Geoff
Feb 11, 2010 | Tag Heuer Aquagraph CN211A wristwatch
Stop Watch not resetting
pulling the crown out to position 2 and pressing button to zero it out one increment at a time is the way to do it do touch the watch hands. Works on fossil watches as well as tag watches
Aug 27, 2008 | Tag Heuer Kirium Ti5 CL1181.FT6000 Wrist...
The second hand is not moving
make sure your mode is on time and not calender. if on calendar it sticks on the present month and does not move.
May 24, 2008 | Watches
Got the same problem guys. i have one of the new electronic diving eco drives.
First time i managed to get it going again, by forcing all the hands to the top for diving mode, then back to normal, this action ´nudged´the minute hand back into motion, but a little later it stuck again at the same spot.
I guess mines going back to the factory, and i´m gonna b watchless for a few weeks :(
Jan 23, 2008 | Citizen 8700 BL8000-54L Wrist Watch
How to align seconds hand for stopwatch feature?
If you pull out the crown to the 2ed postion the push the upper start button that should move the second hand up to zero then push crown in.
Jan 23, 2007 | Bulova Men's Black Leather, Black Dial...
Tag Heuer Formula 1 CAC1111.BA0850 Wrist Watch Logo
177 people viewed this question
Top Tag Heuer Watches Experts
Jimmy Accardi
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
