Question about Pentax Espio 105S 35mm Film Camera
I have a pentaz zoom105-R and I have an error code of 37 can anyone help me with fixing this
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
Epson B-310n inkjet Printer Shows Printer error Code 0x95
Hi, i would like to know, does anyone have experience with this error? In service manual also is not informations about it! I checked with adjustment program for last errors, and there showed 95 H : VOUT. can anyone help me?
for more help visit https://cbrtechsolutions.net
Jun 17, 2011 | Epson Business Inkjet B310N Network Color...
I have a phillips 42pf7220a/37 and 7 blink led
The Ymain Board is out if you have the back of the tv exposed disconnect the ymain board and then plug in the tv set and turn it on. the light should remain green and no longer flash. If this happens the Y main and upper and lower buffer boards should be replaced
Jun 15, 2009 | Philips Televison & Video
Optiarc 7563a
I had the same error code. There weren't any mention of any fixes for this code. So, tried the solution mentioned at PCHell (http://www.pchell.com/hardware/cd_drive_error_code_39.shtml) for the error code 39. Ran through the usual things before, like trying to update the driver and deleting and reinstalling the device--no avail. In my registry, only had to delete the Upper Filter and Lower Filter, no .bak in listing. I did not re-delete the hardware prior to editting the registry, rather left it listed in the Device Manager, with the yellow triangle/exclaimation point. Haven't tried to burn and cd or dvd, but, at least I can now view a dvd. One step at a time. Good Luck. Paul
Jan 15, 2009 | Gateway (5500652) (  5500652)...
Philips HDTV error code
Changed power board and it is working. Has been for about 1 hour.
Dec 27, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Mitsubishi wd52525 shows error code 37
error code 37 is either the dmd fan or the lamp fan. you can see the dmd fan with the cover off. you cannot set the lamp fan as it is under the light engine. I guess the easiest thing to do is get a lamp fan 299P282010 and a dmd fan 299P283010 and change them both.
Nov 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62327
The error codes are all different for the various models. But your WD62327 is the VK26 chassis DLP heres the error codes and the meaning for your model. Let me know if you need more help.
12 No Error detected, check Power Supply
32 Lamp Cover is open
33 Air Filter Cover is open
34 Lamp abnormality
36 Light Engine (DMD or LAMP Fan stopped)
37 Exhaust or Lamp Ballast Fan stopped
38 Lamp temperature high
39 DMD temperature high
41 Short is detected
44 DVI cable between FMT & Engine disconnected.
May 23, 2008 | Mitsubishi WS-55907 55" Rear Projection...
Codes for Olevia 37" HDTV LCD
It's definitely an error code. Call Olevia tech support. They should be able to tell you what the problem is.
Jan 04, 2008 | Olevia LT37HVS 37 in. LCD HDTV
PHILIPS HDTV 30PW8420/37
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
Well I think that if you would have a service manual for this set that would help a lot, I can send it to anyone who wants it via email/gmail. Let me know if anyone want one.
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Dec 06, 2007 | Televison & Video
Philips 37pf9631d/37
Dec 05, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tv. does not turn on sometimes? philips 63pf9631d/37
Dec 01, 2007 | Televison & Video
Pentax Espio 105S 35mm Film Camera Logo
108 people viewed this question
Top Pentax Photography Experts
Bill Eager
Greg Cann
Greg Cann
Are you a Pentax Photography Expert? Answer questions, earn points and help others
