Question about Lexmark X5495 Printer
Cannot retrieve applications list
Please can anyone tell me what to do as my scanner will not scan it gives the above message each time i try. I have tried turning the power off etc...
Any suggestions?
Downloading application list - cant retreive application
If your pc tels you its downloading application, have a look a your printer drivers, your usb cable connecting your pc to printer and or the data cable inside the scanner might have gone faulty
Apr 18, 2013 | Lexmark X5470 All-In-One InkJet Printer
I want to scan a document. I click Scan Mode. The printer responds, "Retreiving Application List," then "Cannot Retrieve Application List."
A problem occurs with your scan driver. You will need to reinstall it to correct the problem.
Another way to scan is to use the scanner option in your computer. Go to Control Panel. Double click the Scanners & Cameras icon. Feed your documents in the printer before starting the scan process.
Try it.
Please give this answer a four thumbs up rating it this help you.
Thank you for using Fixya
Sep 12, 2010 | Lexmark X4530 InkJet Printer
I am unable to scan. While in the Scan Mode, the message says "Downloading scan application list from your computer, please wait" The next message says "cannot retrieve scan application list from my...
the reason why the printer is giving you that error msg is because the all in one center is not communicating properly with the programs on your computer to your printer.
try to scan directly to your computer using the all in one center instead.
Jul 23, 2009 | Dell 966 All-In-One InkJet Printer
Lexmark Scanner - "cannot retrieve application list" Won't Scan - HELP please!
delete the norton internet security as its blocking the scanner files of your printer software .or try reloading the printer drivers again but if reloading the printer drivers does not helps then removing the norton software is compulsary as the files of printer are getting blocked so scanner is not working.
Mar 07, 2009 | Lexmark X3350 All-In-One InkJet Printer
Microsoft Paint ----> 'File' ------> 'From scanner or camera' (when in scan mode on printer). Just tried this and it really works.
Oct 19, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470
is this scanner plugged into a power strip by chance.plug it directly into the wall power
Oct 05, 2008 | Office Equipment & Supplies
Lexmark x4530
frist you make secure that your scanner driver is properly installed or you can go control panel ADD/REMOVE .and select your scanner driver and related software and remove it in your pc and re- install it and make it OK.
Jul 12, 2008 | Office Equipment & Supplies
Scanner not working......
try uninstall it then install again
Feb 27, 2008 | Computers & Internet
Lexmark X5495 Printer Logo
88 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
