Question about Electronics - Others
My SD cruzer micro 16gb can't open.. when want to open it will ask me to format the usb
  • 178 Answers
Windows wil give this message by default when the file system has gone bad, tryf first running checkdisk on it.
Goto Start/Run and use as command "chkdsk /x /f /r X:"
Where x is goes the drive letter of your usb stick, also type the command without quotes.
If this does'nt work use a quick format on the memory stick so that the files are still fisical there and use testdisk to recover them.
You can find testdisk here: http://www.cgsecurity.org/testdisk-6.11.3.win.zip
Testdisk is opensource, this is free software.
Succes.
Posted on Sep 07, 2009
Format a 16gb PNY Micro SD
Format it by using a device like a camera, the computer will not work to format this type of memory. I know this from own experience with 4 different computer in my house..
Jan 16, 2012 | PNY Attach? 16GB USB 2.0 Flash Drive
My sandisk cruzer blade 4GB is showing write protection when i formating it and it also not opening when i select open saying your disk is not formatted. plzzz help me.
if you will look into the side of your SD CARD. theres a small toggle switch there. just slide it to the other side inorder to disable the write protection
Jun 01, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk U3 Cruzer Micro 4Gb Cant Format
With your computer on and the SD Flashdrive fitted correct side UP in the USB port, go to 'My Computer' on the desktop and select the flash drive. The computer will ask you what function you want to perform on the drive and you must select 'format.' You did not say what kind of operating system you are using or I could give you more information. Let me know what happens,
Sciencewoman
Apr 01, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk cruzer 16gb, Macformat, tv won't recognize
Dowload codec Klite pack, via Google, and open the files with that media player, the tv should then pick it up, seeing as its a multi codec reader program, Hope it helps
Jan 16, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Format 8gb sandisk micro sd problem
Often times, these jump drives have a tiny, nearly invisible read-only switch on them. Check to see that it isn't set to read only, which will inhibit formatting, among other things.
Jun 14, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Can't open my sandisk cruzer 16gb
i have a 16 gb pendrive which is detected in my mac but not in any windows...............help me out here
May 10, 2009 | Electronics - Others
Dont worry about being prompted, that is an OS option and you may of turned off by accident. When you insert the flash drive into your USB port, does th elight on the drive ligh up? If not your flash drive may of gone bad.
If it does light up, click on "My Computer" and see if it shows up there.
Apr 03, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Why can't I put a 7gb video on my 16gb Cruzer
I think I know what your problem may be. Check to see how the drive is formatted. Drives formatted with FAT32 cannot transfer files 4GB or larger. Try reformatting the drive to NTFS.
1. Open My Computer
2. Right click on the drive
3. Select Format
4. Under “File System” change it from FAT32 to NTFS
5. Check quick format
6. Click start
I have not tried this yet but if that does not work try this:
1. Right click on My Computer and select Manage
2. Click on Storage
3. Click on Disk Management
4. In the right pane right click on the drive letter assigned to the San Cruz
5. Select format and choose NTFS
I hope this helps. Good luck!
Jan 03, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How do you open
u have to by a certin kind of sd card to insert the micro sd one
Oct 20, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Troubleshoot Sandisk SD micro CHip
Click Start>Control Panel>Administrative tools>Computer Management>Disk Management
Then find your SD card, right click it, and select "Format...". If that doesn't work, then try formatting it on another computer.
Mar 12, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Electronics - Others Logo
105 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
