Question about GE JVM1630 Microwave Oven
My GE Microwave oven, blows the circuit after running for a short while
This was not happening for a long time and all of a sudden it started doing this. It blows the whole circuit in the kitchen. I noticed that the when it was running the power seemed to go up and down.
I have shut the microwave down until a solution is found.
My e-mail number is alicaap@frontiernet.net
  • Anonymous Dec 25, 2007
    I have an older model Profile and just recently started tripping the 20 amp breaker if the kitchen lights are on. What is the amp draw on this model? jjpinson@yahoo.com
  • GE Master
  • 9,098 Answers
I sent you private e-mail.
Door switches or problems with wiring or the breaker, or something esle on the same breaker (a "no no") are the most likely problems.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 09, 2007
Ge microwave blow the circuit breaker and when i try it in a different outlet it starts by itself
I have that problem at my house.
At my house, here is why.
The house was made in 1960.
The ground wire in the "Romex" cable inside the house everywhere is tiny, about a 20 gauge wire.
Because of that, the circuits are very easy to overload.
Kitchens today have lots of electric stuff.
At our house in the kitchen, we can run nothing but the microwave, or nothing but the toaster oven, or nothing but the blender, etc.
Rewiring would cost a LOT of money here, so we just "adjust".
God bless your efforts.
Nov 03, 2017 | GE Microwave Ovens
GE JVM1850CH06 MICROWAVE
the panel display is fried. you'll need to remove and replace it...this the sort of thing you enjoy doing?
May 23, 2008 | GE XL1800 1100 Watts Microwave Oven
GE microwave hums/ vibrates then blows fuse after about 3 seconds
Do not use this oven the klystron tube is likely shorted, it is real fire danger
Sep 21, 2016 | GE Microwave Ovens
My microwave blow the fuse after pressing start
There could be a bad interlock switch. I have seen this blow the fuse. The high voltage capacitor could be shorted. This will blow the fuse immediately. Take care around the high voltage circuit. Make sure you short the capactor terminals to groound before touching any connectors.
Oct 02, 2014 | GE SpaceMaker Microwave Ovens
Our GE built in microwave model # JKP62G suddenly started making a loud noise when we try to use it. It does this on any power level and on the defrost setting also. It does not seem to be heating...
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Jan 01, 2011 | GE Microwave Ovens
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
Hi, When my GE jvm1650bb microwave starts, it begins to work and then blows the fuse in the house. Does this every time, the circut is not overloaded. Is their a part that went bad that I can replace?
Try your oven on another circuit in your house. It is curious that your oven doesn't blow its own fuse before the house one. If it doesn't blow the fuse in the "new" circuit, check to see what is really on the kitchen circuit. It might, in fact, be overloaded. Good luck.
Nov 28, 2009 | GE JVM1650 1000 Watts Microwave Oven
I have a J HP60G 002 GE Microwave (older)keeps
If it blows the line fuse instantly when you push start.... it is either a shorted HV capacitor or shorted monitor switch.... most likely.
Sep 13, 2009 | Microwave Ovens
Fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Unit Electrical Problem
If it blows the fuse as soon as you hit the START button, it's almost certainly a shorted high-voltage capacitor.
If it blows a few seconds after you hit the START button, it's probably the high-voltage transformer. You'll possibly also smell a faint electrical burning smell from the rear vent after you shut if off.
Microwave can be very dangerous so it is best to have it looked by a professional
Would appreciate a solved rating for expert advise.
Oct 16, 2007 | GE JE1590 Convection / Microwave Oven
GE JVM1630 Microwave Oven Logo
127 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
