Question about GE Kitchen Ranges
I have had my new Range about 4 months now. It is a G.E. model # JS968K-K4cc. When I reached to the cabinet above the range I must have leaned on it wrong and it set the cleaning cycle. I immediatly tried to cancel but it wouldn't. It also will not start the cleaning cycle either. It keeps showing ''door'' on the pad. I have pushed the door, jiggled it and so forth. The timer is making a fast clicking noise. I have tried to reset the breaker and anything else I could think of but nothing works. Can you please help?
  • vickibchrist Sep 09, 2009
    Thats it. Just turn the oven light off and back on?
Need to re-light oven
Posted on Sep 07, 2009
Remove microwave built in range
I) empty the cabinet above the unit.
2) unplug the unit from the outlet in the cabinet
3) locate the two bolts near the front edge in the floor of the cabinet and remove them. the unit will tip down to the range below.
CAUTION SUPPORT THE UNIT WHILE TAKING OUT THE BOLTS OR THE UNIT WILL CRASH
4) Two people can then lift the unit from the support on the wall.
Aug 22, 2014 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
I bought a kitchen aid gas range 4 monthes ago. The model no is kgss907sss. The oven takes more than 1 hour to preheat to 375F. Sometime it even can't reach the temperature forever.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 12, 2010 | KitchenAid KGRS807S Gas Kitchen Range
I'm trying to remove but unable to determine how
most over the range micos are secured by either 2 or 4 screws from above usually inside a cabinet or storage above remove those disconnect or pull away venting if vents above,, u willl need two people sometimes to help hold micro..... i would have to see the unit some might also have trim pieces if its more of a built in situation hope this helps
Jan 31, 2010 | Panasonic Microwave Ovens
How do I remove my Hotpoint microwave RVM 44004? Two bolts visible from the cabinet down into the microwave. Removed them with zero result. No other fasteners visible in top or side cabinets.
It is much easier for two people to remove the microhood. If attempting alone, please move the range out so you can get under the micro to support the weight. If the range stays in place, protect the top from damage.
1. make a landing site to the side to protect the floor when putting the micro down after removal.
2. Disconnect the power cord in the cabinet above.
3. loosen the two screws in the bottom front corners of the cabinet above. When removed the front of the micro will drop, be ready for the weight. Busy times, tools in hands microwave coming down in front.
4. tilt the front down. pull the cord out of the upper cabinet.
5. with micro still tilted down in front, lift the back of the unit upward to free it from the wall plate.
6. remove the fasteners in the wall plate and remove.
Congrats, begin celebration.
Jan 20, 2010 | Hotpoint RVM1435 Microwave Oven
How do you install an over the range micro-wave, i can't seem to figure out how to insert the micro wave onto the bracket on the wall.I'm having trouble with the clearance from the cabinets above .
Use the template that came with the microwave to insure proper height of the wall bracket. If height is correct and you have drilled the three holes in the top cabinet, (one for power cord two for mounting bolts), the unit must be tipped forward (front lower than back) so the bottom can be hooked to the wall bracket. Once hooked, start the power cord throught he hole into the upper cabinet and the unit can be tilted upward to allow you to start the bolts that support the front of the unit. It is nice to have help with the weight of the microwave. If attempting alone, make sure that everything is within reach when you start and if possible pull the range and move it aside. Good luck.
Aug 25, 2009 | Magic Chef Kitchen Ranges
How to remove maytag microwave over the stove about 10 yr old
There is a considerable amount of weight to lower. It is an easier removal with the range pulled out and moved to the side. If you choose to move the range, be sure to protect the floor. Unplug the microwave. The plug should be in the cabinet above the range. There are two screws in the cabinet above that screw down into the top and support the front. These are the only fasteners that hold the machine directly. An assistant would be nice to have to help with the weight. While supporting the microwave, remove the two screws and slowly lower the front of the microwave pulling the cord out of the cabinet above as you go. Once the cord is free, tilt the machine down in front until the back can be lifted up off the plate that is fastened to the wall.
Jul 12, 2009 | Maytag MMV4205 Microwave Oven
Kenmore mirowave # 72162643200 handle is broken
I have the exact same problem and the cost for a tech to replace the door is $80 less than buying a new one. They have to remove the unit from the cabinets and pull off the exterior box to unscrew the door hinge. Mine is only 3 years old. I also bought a new oven range. Never really use it. Decided it was time to use the self cleaning. It did not work. $280 to put a new board in. 4 months later I went to clean it and again it did not work. The f*^ing thing only cost $500. Decided Easy off will have to do. Kenmore s*&ks
As for the door... I very CAREFULLY used super glue/ gel and it did the job!
Mar 27, 2009 | Kenmore 62643 Microwave Oven
Granite installation didn't get flush with slide-in range
suspect your contractor didn't allow for the tiled floor. the range legs are usually adjustable up and down. have you checked this?
Sep 04, 2008 | Cooktops
Microwave installation under cabinet, no rear wall
Your model weighs 41 pounds empty.
That - plus maybe adding another 8-10 pounds for safety - us what your installation needs to be able to handle.
I would think the average cabinet could handle that, but it may be better to add a small steel plate or large washer surrounding the mounting screws to help disperse the weight load.
The owner's manual describes the installation kit you can use to mount it in a cabinet or in the wall, etc. That may be helpful.
If you don't still have your manual you can download it here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 17, 2008 | Sharp R-408HS Microwave Oven
Hi , I would like to suggest to visit near appliance center to purchase hanging for oven . ace hardwares.
Jan 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Kitchen Ranges Logo
61 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
