Hp laser jet 2200dn error 40 - bad connection betwin EIO card and printer - can i fix it or have to replace something?
Hp laser jet 2200dn
To configure the HP printer for a Network printer go to this link and follow my instructions.
http://www.fixya.com/support/r3559242-setting_up_hp_jetdirect_print_server_p
Mar 27, 2012 | HP Office Equipment & Supplies
Heloo can you help me my hp laser jet cant print its reads 82.0180 EIO 2 error
The error message "83.0180" shows that an EIO error has occurred.
Perform the following workaround and see whether the issue still persist.
1. Ensure that the printer is connected directly to the wall outlet.
2. Turn off the printer and then power on and see whether the issue persist.
3. Reseat the Jetdirect card and see whether the issue still persist.
4. Reseat the jetdirect card on a different slot and see whether the issue still persist.
5. Remove all the accessories from the printer and then power on the printer. See whether the issue still persist. If the issue does not persist, add on the accessories onee by one.
6. Power on the printer and check whether the issue persist, each time an accessories are added.
7. Swap the Jet direct card with a known good jet direct card and see whether the issue still persist.
8. Perform a cold reset and see whether the issue still persist.
Mar 02, 2011 | Office Equipment & Supplies
82.0180 EIO 2 ERROR
This is an problem caused by the jet direct card in your printer.
1. Move the Jet Direct card from port 1 to port 2 on the printer.
2. Replace your jet direct card with one that you know is good.
Test to see if either of these resolves the issue.
Its usually a bad card
best of luck
Mar 01, 2011 | HP Office Equipment & Supplies
My HP 4100tn will not print and I am getting error message as follows: 82.0180 EIO 2 ERROR I printed a document and then when I tried to print another document I got the error message. How can I fix...
Thank you for contacting FixYa with your printer inquiry.
This is an error caused by the jet direct card in your printer, try one of two things.
The problem is usually a faulty card.
J7934-69011 JetDirect 620n internal print server - 10BaseT and 100BaseTX LAN interface board - Plugs into peripheral EIO slot - Has an RJ-45 connector
Vender
http://www.dectrader.com/J6057-61001-New-HP-JetDirect-615N-internal-print-server-10Base-T-and-100Base-TX-LAN-interface-board-Plugs-into-peripheral-EIO-slot-Has-one-RJ-45-connector.html?utm_source=googlebase&utm_medium=shopping&utm_campaign=parts
image.php?type=p&id=223008&t250=y
Hope this helps helps. Please keep us updated and remember to rate this answer.
Feb 22, 2011 | HP LaserJet 4100n Printer
Problem with the HP LaserJet 4050 Printer 82.0180
The 82.XX error represents that the External Card which is located in the formatter of the machine, either is bad or the port in the formatter is bad (This could be a Network Card or a Hard Drive really depends on your machine.)
Recommended Solutions:
Please make sure you turn off the machine before removing the card!
Remove the card from EIO slot 2 and plug it into the EIO Slot 1 is the card still does not work then the card will need to be replaced.
If both the EIO slots do not recognize the card. It's most likely the card, however it could also be the formatter.
Oct 20, 2010 | HP LaserJet 4050 Printer
Laser Jet 2420d. Error code 49. What is it? How do I fix it?
This is a firmware error and this error is usually caused by a bad formatter board.To troubleshoot this issue here are some steps that you can try .
1. Press CANCEL JOB to clear the print job from the printer memory.
2. Turn the printer off, and then turn the printer on.
3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.)
4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. 5. Turn the printer off.
6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.)
7. Remove all EIO devices from the printer. 8. Turn the printer on.
9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device.
10. Replace a DIMM or EIO device if you determine that it causes the error.
11. Remember to reconnect all cables that connect the printer to the network or computer.
12. If the error persists, replace the firmware DIMM. 13. Replace the formatter.
all the best
Jun 02, 2010 | HP LaserJet 2420dn Printer
HP 4200 Laser Jet Printer Error Code 82.0180 EIO 2 Error
The error message "83.0180" shows that an EIO error has occured.
To do a Cold Reset:
1. Remove all cables.
2. Press & hold the Test button while applying power & continue to hold it for 10 seconds, then release it for 10 seconds, then unplug it again.
3. Connect all cables & power it back up.
4. Wait 2 minutes for discovery & DHCP. If desired, change the DHCP & address settings.
May 07, 2010 | HP LaserJet 4200 Printer
EIO 1 ERROR
There's probably a problem with the card in the printer. It may need a firmware upgrade, you may need to adjust settings or even change the slot. The EIO 1 means it is now in slot 1. Here are some steps to try from the HP website:
Press (Select) to enter the MENUS.
Press (Down arrow) to highlight INFORMATION.
Press (Select) to select INFORMATION.
Press (Down arrow) to highlight PRINT CONFIGURATION.
Press (Select) to select PRINT CONFIGURATION
Check if the I/O card is on ready state.
Make sure that TCP/IP status is ready.
Check the network statistics for any bad packets or bad transmition.
Try to use another slot then the one that the JD is installed on.
If the problem persist,try performing a cold reset with the JD inside.Warning: This will reset the printer's configuration to the default settings,and also to the JD so you will need to set again the network values.
May 19, 2009 | HP LaserJet 2420 Printer
82.0180 EIO 2 ERROR
Dec 31, 2008 | HP LaserJet 4050 Printer
Printer Problem
error occurred
Mar 19, 2008 | Computers & Internet
111 people viewed this question
k24674
