Hoover AAA160 Front Load Washer
Problem for Hoover AAA160 Front Load Washer
HELLO , I HAVE A HOOVER NEXTRA MEGA LOAD WASHING
By johnh1200 on Sep 07, 2009
HELLO , I HAVE A HOOVER NEXTRA MEGA LOAD WASHING MACHINE 7.5KG AND INSIDE THE HANDLE THERE IS A LITTLE PLASTIC BIT YOU SQUEEZE IN ALONG WITH THE DOOR TO OPEN IT . THIS HAS BROKEN AND I HAVE A NEW PIECE TO REPLACE IT BUT WOULD LIKE INSTRUCTIONS ON HOW TO DO SO, PLEASE CAN YOU HELP J. HORNER
Best Solution
posted on Sep 07, 2009
Helpful)
Nicesuit
Rank: Wiz
Rating: 84%, 26 votes
Hi John,
it has been a while since i worked on one of these, but I might be able to talk you through it, first make sure you have the correct bits to replace. i.e. the inside of the handle and the latch match the same that is on that you can see before you go any further.
using a torx size 15 I think remove the two screws on the door hindge, and then remove door by pushing up by a 1/4" then the hindge should pull away from the machine. using a torx size 10 then proceed to remove the four screws from the inside of the door frame, ease the door pannels appart and the glass bowl and lock should be exposed. there should be a further two screws holding the latch in place, just be careful when taken these out as they may be under load from a spring, note the positions of the latch and replace all back in reverse order.
Cheers,
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Somewhat Helpful)
yourmum_is
Rank: Master
Rating: 74%, 10 votes
i RATHER USE A ******** THAN A WASHING MASHINE!!
Was this helpful?
Yes
No
Popular Solutions for Hoover AAA160 Front Load
Questions and Unsolved Problems for Hoover AAA160 Front Load
Do you recommend Hoover AAA160 Front Load Washer?
Answer
Answer
I have a hoover vhd844db that has an intermittent error keep happening (E3). This is supposed to be... (More)
Answer
When I press start on a wash. It begins and then goes to a delay start setting and does not finish.
Answer
family 1300 mega load HF7 130M how do i change the drum bearings please, thank you
Answer
hoover wdm 130 motor wont spin fast , new bushes fitted did not fix problem all other cycles ok,... (More)
Answer
My hoover 1600 washer is flashing stop, ready to start but the start button doesn't work when... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hoover AAA160 Front Load...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14846
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
